I have a FCIP tunnel running netween two sites. I want to use additional ports on my MDS to setup another tunnel and use it if the primary tunnel goes down. what would be the most effective way to accomplish this task. I would not like to use FSRP method using HSRP. Can I setup two tunnels and make adjustments using fspf or is there a backup command that does the failover automatically.
you can use port-channel bundle mutiple FCIPs, if one FCIP link or tunnel failed, it will fail to the survival link.
