VPN Client Connects but no Remote Network Access
I have one user who is unable to Access Remote Network resources when connected to the VPN on his home network.  VPN shows connected and he is given a remote IP from the VPN Pool, but he cannot ping any IP on our network.  When connected using Sprint Wi-Fi card he is able to connect and access remote network from the same laptop.  Maybe there is some network overlap that I am missing.
Please see attached firewall config (zzz... being firewall public IP) and remote user route table.
ASA 5505
VPN Client 5.0.07.0290
Your help is much appreciated.
CSCO11543336 Fri, 02/15/2013 - 10:51
Is the User Router table printed out while connectiong from Sprint or your network?  I would also start by comparing the user route table in both connection modes
CSCO11543336 Fri, 02/15/2013 - 11:05
Based on your first post, the tunnel comes up.  That tells me udp port 500 is not blocked.
Andrew Phirsov Fri, 02/15/2013 - 11:17
  • Silver, 250 points or more
Is everything correct with routing from your internal network back to the vpn address-pool subnet?
Yes, I believe the routing is correct, VPN Statistics is showing Secured Routes to our two internal networks (172.20.0.0 and 172.30.0.0).  Tunnel Detail shows Bytes received but none Sent.  I don't believe there is any network overlap either, user is given a 74.195.255.0/24 address and we assign a 172.29.151.0/24 address from the VPN Pool.
I ran across this document https://supportforums.cisco.com/docs/DOC-10272, when I tested it failed on port 500.
