What is VLAN partition?
Answered Question
Feb 15th, 2013
Hello all,
I saw this statement in some documents said "Certain configurations of bridges may cause partitions of a VLAN on a link. For such configuration, a frame sent by one bridge to a neighbor on that link might not arrive, if tagged with a VLAN that is parittioned due to bridge configuration."
What does VLAN partition mean? Could anyone share your understandings? thanks a lot!
Correct Answer by Peter Paluch about 1 year 2 months ago
Hi Steve,
I have not yet encountered a similar term as VLAN partition. What the statement says, though, appears to me as a bridge misconfiguration where either the VLAN is not created on the bridge at all, hence the bridge will not forward frames in that particular VLAN (a common behavior for VLAN-aware switches), or the VLAN is created but is not configured to be bridged between a particular set of ports, resulting in two or more discontiguous domains.
Apart from this - I do not know
Best regards,
Peter
Average Rating: 0 (1 ratings)
Correct Answer
Peter Paluch Sat, 02/16/2013 - 02:02
Hi Steve,
Best regards,
Peter
zhoucengchao Sat, 02/16/2013 - 19:04
Hi Peter,
thanks for your help. I have the following up as below:
(1) The problem is mainly caused by  configuration issue on the bridge. I agree with you that the link bridge might be misconfigured which in turn partitioned a VLAN.
(2) How do you understand the workd "link" in the context? If let you draw a topology, would the "link" actually another bridge interconnecting other bridges.
(3) If we changed the bridges here to switches, would the result the same?
thank you
Peter Paluch Mon, 02/18/2013 - 11:31
Hi Steve,
I really do not know. Can you perhaps post a bigger section of the document where you read this, or if it is a public document, can you post a URL to it?
Yes - in fact, I was talking about switches.
Best regards,
Peter
zhoucengchao Mon, 02/18/2013 - 17:40
Actually, I'm reading RFC 6325 page 17. Anyway, thanks a lot for your help, Peter.
Peter Paluch Mon, 02/18/2013 - 22:58
Hi Steve,
Oh, I see. In that case, the RFC 6325 in Section 1.3 indicates:
   In this document, the term "link", unless otherwise qualified, means
   "bridged LAN", that is to say, the combination of one or more [802.3]
   links with zero or more bridges, hubs, repeaters, or the like.  The
   term "simple link" or the like is used indicate a point-to-point or
   multi-access link with no included bridges or RBridges.
Does this explain your question?
Best regards,
Peter
mhnedirli Sat, 02/16/2013 - 10:35
if you read sentence begining from end it says, if you configure vlan on a switch and a frame sent by one to a neighbor on that link might no arrive.
zhoucengchao Sat, 02/16/2013 - 19:08
Hi mhnedirli,
sorry, I didn't get your points, do you have the same view as Peter?
thank you!
Login or Register to take actions
Posted February 15, 2013 at 11:43 PM
Stats:
Replies:7 Avg. Rating:
Views:415 Votes:0
Shares:0
Categories: Switches
Discussions Leaderboard
Rank Username Points
1 15,007
2 8,155
3 7,745
4 7,088
5 6,742
140
80
78
64
40
