Does CUE loose the licenses if I reset it to factory default?
sayeedibrahim
Site A- CUCME + CUE
Site B - CUCME
CUE from Site A to be pulled out and used at Site B. I have already installed the ISM module at Site B and i can access it but it not able to communicate with CUCME to fetch phones information as it was previosuly configured with a different CUCME IP.
I am confused it resettign to factory default will remove my licenses already installed.
Thanks for your suggestions/support.
Ibrahim SAYEED
With Factory default the CUE will loose ONLY the configuration and not the license
chrysostomos
Please rate all useful posts Regards Chrysostomos ""The Most Successful People Are Those Who Are Good At Plan B""
Chris Deren
Yes it will. You can use the licensing web portal to convert the license though very easily.
Chris
Thanks Chris.
Would it be ok, if i replace the old CUCME IP with new CUCME IP inside the cue configuration console.
Can you provide me the link to access the licensing web portal. Would it better if i send an email to licensing team.
Ibrahim SAYEED
I belive you should be able to re-direct without any issues.
The web portal is cisco.com/go/license
HTH, please rate all useful posts!
Chris
chrysostomos
