Warning message
SPA3102 as simple FXO/SIP gateway, no router?
Answered Question
Has anyone set up a SPA3102 as a simple gateway between the FXO PSTN line and an internal SIP PBX (Asterisk or similar)?  I don't want the thing trying to act as a router; it will be on the same LAN segment & subnet as the PBX machine and just needs to provide a 2-way SIP trunk that's actually the PSTN line.
Would this work with just the WAN port connected, or perhaps with both ports on the same segment & subnet, or would that confuse it?
Thanks!
Jeff
Correct Answer by Patrick Born about 4 years 6 months ago
Hi Jeff,
You could deploy it in bridge mode if you don't want it acting like a router:
    Router tab > Lan Setup > Networking Service > Bridge
Patrick---
Overall Rating: 0 (1 ratings)
Correct Answer
Patrick Born Mon, 02/18/2013 - 14:55
  • Cisco Employee,
Hi Jeff,
Patrick---
