Small Business Support Community
Explore what Cisco has to offer for your small business IT needs. Learn from your peers and Cisco experts.
Browse the Community
Routers - Small Business
Routers tailored for small businesses, providing efficient and reliable connectivity for your growin...
Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small busi...
Wireless - Small Business
Stay connected on-the-go with our Wireless solutions, designed for small businesses to boost product...
Cisco Business Dashboard
Stay on top of your business performance with the Cisco Business Dashboard, providing real-time data...
Activity in Small Business Support Community
CBS350-8XT too noisy
I own a CBS350-8XT that is far too noisy. I even purchased a sound meter to obtain a measure and it goes up to 70db where the maximum indicated in the user manual is 41.3db. I would like to open a ticket or something for cisco to fix my unit. How sha...
Fan noise of 350x-24
Dear all,I just received a 350x-24. The fan is quite loud, but that isn't a problem as no one sits beside the rack.I just wondered if a noise of 49.2dB average is normal or if it is a indiaction for a hardware or config problem?The noise level was ju...
crypto keyrings command not found
Router>Router>enRouter#conf tEnter configuration commands, one per line. End with CNTL/Z.Router(config)#Router(config)#Router(config)#Router(config)#crypto key ?decrypt Decrypt a keypair.encrypt Encrypt a keypair.export Export keysgenerate Generate n...
CBS350 Setup guidance
Hello,I have an ISP router/modem, along with assignable public IP addresses for use. Leaving default VLAN1 alone (mgmt), I created VLAN10 (192.168.0.0/24) and VLAN20 (172.16.3.0/24) on the CBS350.ISP router "internal" ip 172.16.2.1/24On CBS350 port G...
Adding new switch to old stack
We have 2 SG350x-48 switches in a stack.  and we need to add another switch.  but I know that SG350x-48 is no longer sold.  what are my options?  these were replaced by the "Cisco Business 350 Series Managed Switches".  can one of these switches be a...
SCOTT No2 by Level 1
  • 124 Views
  • 2 replies
Access Point WAP150 Single Point
I have questions in cluster settings.   (1) Number of WAP devices per single point setting WAP150:4 Does the setting 'WAP150:4' indicate that a maximum of 4 WAP devices can be connected in a single cluster?   (2) Registering an AP in a Created Clu...
Translator by Community Manager
  • 65 Views
  • 1 replies
Limited internet Connection
Hi, I have Mikrotik Cloud base router its connect with cbs 100 switch (WAN) and its connect with cbs350(LAN). I am getting this error. Kindly this one is from swx side or WAN side and what's the solution. Thanks @
8MFT-T1/E1
how to activate the module on cisco 4400 router for E1 connections.#card type e1 0 4 showing error, card not found or command wrong
CBS350-24p-4x not possible to use all TE Ports
Hey GuysFor a Lab device I've got a cbs350-24p-4x. With it's 4 TenGigabitEthernet ports I'd like to use port TE1/0/1-2 for lacp to my firewall and with TE1/0/3-4 ports I'd like to connect to my vsphere ESXI host.The Switch is running on the latest FW...
joel157 by Level 1
  • 101 Views
  • 1 replies
