02-19-2013 08:56 AM - edited 03-07-2019 11:47 AM
I need to break into a 2901 router to recover the passwords. Cisco's methodology for password recovery on 2900 seriews routers
says to remove the compact flash card and reboot into RMON. There is no external compact flash card on a 2901. Is there a
compact flash card inside the box? Or can you use the older method of rebooting and then hitting ctl+break to boot into RMON?
Howard Davis
CCNP
Solved! Go to Solution.
02-19-2013 02:19 PM
Yes there is. It's hidden underneath a dust cover at the back (opposite side of the power outlet).
There should be TWO CF slots. Just pop the "0".
02-19-2013 02:19 PM
02-20-2013 06:03 AM
You're right.. I found two cf card slots on the back, lower left. cf 0, to the right, and cf 1 to the left.
Thanks for your help on this Leo
Howard
02-20-2013 11:42 AM
There is another way if u have given read/write snmp community string and u remember that this can help you recovering password from router.
If not follow recomended way to recover password by cisco
http://www.cisco.com/en/US/products/ps5854/products_password_recovery09186a0080b34901.shtml
02-20-2013 07:29 PM
Howard,
If this has answered your question(s), can you mark this thread as "Answered" please?
02-21-2013 03:27 PM
Thanks Howard.
05-23-2014 08:05 AM
Thanks to all,
It was a big support for me.
