aironet 2600 in standalone mode
Feb 19th, 2013
hi,
I have to set up the AP in a standalone mode to support voice and data traffic through the wireless network.
for this, i was trying to look for the config guide so i know how to go about it, but all the doc was refering to controller based setup.
i followed this link
http://http://www.cisco.com/en/US/partner/docs/wireless/access_point/2600/quick/guide/ap2600getstart.html
I have never worked on wireless in a standalone mode, so this is the first time i will be doing it. If you have any suggestions along with the links where i can read more about it that would very helpful. thanks!
regards,
mohit
Mohit Chauhan Wed, 02/20/2013 - 23:32
Thanks Scott. I read through the links you advised and also came across the comprehensive guide from cisco at
http://www.cisco.com/en/US/docs/wireless/access_point/12.4.25d.JA/Configuration/guide/cg_12_4_25d_JA.html, thought i should share with all.
So finally I have been able to draft a simple template for my config, but just wanted to clarify it:
my setup is fairly simple, just one SSID to use, so this is how i think i shuold be doing:
dot11 ssid test
vlan 100
authentication open
authentication key-management wpa version 2
wpa-psk ascii
int dot11radio0
encryption mode ciphers aes-ccm
mbssid
speed  basic-12.0 18.0 basic-24.0 36.0 48.0 54.0 m0. m1. m2. m3. m4. m5. m6. m7. m8. m9. m10. m11. m12. m13. m14. m15.
station-role root
no shut
interface Dot11Radio0.100
encapsulation dot1Q 100
no ip route-cache
no cdp enable
bridge-group 100
int dot11radio1
encrption mode ciphers aes-ccm
mbssid
no dfs band block
beamform ofdm
channel width 40-above
channel dfs
station-role root
no shut
int dot11radio1.100
encap dot1Q 100
no ip route-cache
no cdp enable
bridge-group 100
int go
no ip address
no ip route-cache
duplex auto
speed auto
no shut
int g0.200
encap dot1Q 200 native
bridge-group 200
no cdp enable
int g0.100
encap dot1Q 100
bridge-group 100
no cdp enable
interface BVI1
description ***** AP Management Network *****
ip address 192.168.200.10 255.255.255.0
no shut
ip default-gateway 192.168.200.1
The switch port on the other side would be trunk with native VLAN 200 and allowed 100 and 200.
My concern above is also the BVI1, do I need to change the number 1 (default) to 200 which is my native vlan or that should be fine.
Thanks in advance!
Mohit
kcnajaf@25070 Wed, 02/20/2013 - 23:54
Hi Mohit,
You will have to use the bridge-group 1 under the interfaces to map the BVI 1 interface with radio and physical interfaces. So you can modify your configurations as below.
no ip route-cache
no cdp enable
bridge-group 100
interface Dot11Radio0.200
encapsulation dot1Q 200 native
no ip route-cache
no cdp enable
bridge-group 1
int g0.200
bridge-group 1
no cdp enable
int g0.100
encap dot1Q 100
bridge-group 100
no cdp enable
bridge 1 route ip
Hope that helps.
Najaf
Please rate when applicable or helpful !!!
Mohit Chauhan Thu, 02/21/2013 - 00:03
Hi Najaf,
thanks for the above.
Could i also do the other way, like
int bvi1
no ip address
shut
int bvi200
no shut
and leave the int  g0.200 config as it is.
Also wanted to confirm why would i need to use int "dot11radio0.200" here? I dont intend to use vlan 200 on the wireless. is it still required?
Mohit
kcnajaf@25070 Thu, 02/21/2013 - 00:18
Hi Mohit,
You could give a try :-) But i'm sure that you will not be able to remove the BVI1 interface.
Hope that helps.
Najaf
Mohit Chauhan Thu, 02/21/2013 - 00:25
Alright no worries i will try that out and let you know. The only thing is that it will take some time cos i just got to know that my client havent received the hardware yet, so i will need to wait until that happens.
shall keep you posted.
PS: just realised that i did not see your comments regarding my second Q which was:
thanks Najaf!
kcnajaf@25070 Thu, 02/21/2013 - 00:46
Hi Mohit,
Access Points does bridging, which means takes the traffic on the BVI interface (since ip address is assigned to this interface this interface is used for routing) and bridges this traffic to both radio and physical interface and vice versa.
So the BVI interface which you are planning to use has to be mapped to one radio and physical interface. So inorder to achive this mapping we are creating the dot0.200 interface.
Hope that helps.
Najaf
Mohit Chauhan Thu, 02/21/2013 - 00:56
alright but by doign this we are not propagating that as an SSID unless we create one explicitly?
kcnajaf@25070 Thu, 02/21/2013 - 02:03
That is right. This is notthing to do with the SSID. SSID propagation should have specific configurations and just creating an subinterface will not propagate an SSID.
Hope that helps.
Najaf
Mohit Chauhan Tue, 03/12/2013 - 01:04
Hi Najaf,
Finally i have got the APs to start working on it.
Quick Q, i was geting the AP ready with the discussed configuration but somehow realized that the laptop couldnt see the SSID i had programmed on the AP until i removed the "mbssid" from the radio config, i could start seeing the SSID.
no ip address
no ip route-cache
encryption vlan 100 mode ciphers aes-ccm
ssid ABC
mbssid
Having this turned off should not cause any issue?
Also, I was trying to run
"encryption mode ciphers aes-ccm
ssid ABC"
This was giving error that
"Mar 12 07:09:28.143: %DOT11-4-NO_SSID_OR_NO_VLAN: No SSID configured. Dot11Radio0 not started."
And thats the reason I switched to "encryption vlan 100 mode ciphers aes-ccm"
maldehne Tue, 03/12/2013 - 01:37
If you have single ssid yo be broadcasted all you need to do
is to add guest-mode command under the ssid configuration mode
to have the ssid broadcasted in the AP beacon frames.
If you want to have more than one ssid to be broadcasted in beacon frames
you have to add mbssid guest-mode command under the ssid configuration mode
and then add mbssid command under the radio interface cofiguration mode.
For the error message , if you have your ssid mapped to certain vlan
you should add
encryption vlan mode .....
Please make sure to rate correct answers
Mohit Chauhan Tue, 03/12/2013 - 21:07
Thanks for the info there. I am going to the site tomorrow to test this with the wireless phones. shall update how i go?
Quick Q, these wireless phones will roam easily from one AP to the other? there wasn't anything that I remember like RF domain on the APs to be programmed so I am not sure how the wireless client would roam from one AP to the other?
The single SSID is set the same way on both APs and both connecting to the same switch via the trunk ports.
kcnajaf@25070 Tue, 03/12/2013 - 21:21
Hi Mohit,
Sure...
Any wireless device are programmed in such a way that they will try connecting to the SSID if both device and AP have the same SSID. In your case both your AP's are configured with the same SSID and wireless phones are also configured with same SSID. So by default wireless phone would connect to any one of the AP (there are various parameter a client will consider before connecting to an AP). One of the factor which all most all client consider the received signal strength from AP. If wireless phone get signals from both AP it would most likely conenct to the AP which offer highest signal strength. So while phone is moving it would be able to seamlessly roam between the AP as long as it is able to pick up signal from each AP.
One thing you have to understand is that the AP does not have any role in roaming. It is the clients which decided when to roam and which AP it has to roam.
Hope that helps.
Najaf
Mohit Chauhan Tue, 03/12/2013 - 21:25
Hi Najaf,
thanks for the quick reply.
While I was waiting for someone to reply, i was reading through the cisco website and came across the term WDS which it says is needed for quick roaming, especially for delay sensitive traffic such as voice. So you reckon I should go on that path and see how i can program it on the AP?
Mohit
kcnajaf@25070 Tue, 03/12/2013 - 22:07
Hi Mohit,
How many AP's you have on your network? If is this 1 or 2 there is nothing much WDS can offer you. Also another factor is what authetication you are planning to use. If this is some sort of EAP flavour WDS will benefit while if you are planning to use pre-shared keys then i dont think WDS will help you.
Hope that helps.
Najaf
Mohit Chauhan Tue, 03/12/2013 - 22:32
Hi Najaf
yes we just have 3 APs in all. And we are only using PSK for authentication.
So if that is the case you reckon the below config should be good enough....likewise rest of the APs are configured except of the BVI ip address.
hostname AP1
enable secret 5 $1$Ffyw$jgy4scPLYfBlprgAP1KFL/
aaa new-model
aaa authentication login default local
aaa authorization exec default local
aaa session-id common
no ip routing
ip domain name XYZ.com
dot11 syslog
dot11 ssid XXX
   vlan 100
   authentication open
   guest-mode
   wpa-psk ascii 7 1331470B5B18241D0B
dot11 arp-cache
dot11 phone dot11e
ip ssh version 2
bridge irb
ssid XXX
antenna gain 0
stbc
packet max-retries 3 0 fail-threshold 100 500 priority 6 drop-packet
packet speed  5.5 11.0 6.0 12.0 24.0 priority 6
station-role root
rts threshold 2312
no dot11 extension aironet
no cdp enable
no ip route-cache
bridge-group 100
bridge-group 100 subscriber-loop-control
bridge-group 100 spanning-disabled
bridge-group 100 block-unknown-source
no bridge-group 100 source-learning
no bridge-group 100 unicast-flooding
no ip route-cache
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Dot11Radio1
ssid XXX
antenna gain 0
no dfs band block
stbc
packet speed  6.0 12.0 24.0 priority 6
channel dfs
station-role root
no cdp enable
interface Dot11Radio1.100
no ip route-cache
bridge-group 100
interface Dot11Radio1.200
no ip route-cache
bridge-group 1
interface GigabitEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
interface GigabitEthernet0.100
no ip route-cache
no cdp enable
bridge-group 100
interface GigabitEthernet0.200
no ip route-cache
no cdp enable
bridge-group 1
interface BVI1
ip address a.b.c.10 255.255.255.0
no ip route-cache
ip default-gateway a.b.c.1
no ip http server
ip http secure-server
access-list 111 permit tcp any any neq telnet
bridge 1 route ip
line con 0
access-class 111 in
logging synchronous
line vty 0 4
access-class 111 in
transport input ssh
line vty 5 15
access-class 111 in
transport input ssh
end
maldehne Tue, 03/12/2013 - 23:37
connectivity wise you should be ok.
If you need some tuning on voice , can you let me know what is the phone model that you have ?
kcnajaf@25070 Tue, 03/12/2013 - 23:47
Hi Mohit,
It would be ideal for you to reconfigure the channel since you are using three AP's. After applying the above configuration you can mannually configure non-overlapping channels (1, 6 & 11) on each AP as below.
AP1
conf terminal
int dot11radio0
channel 1
AP2
conf terminal
int dot11radio0
channel 6
AP3
conf terminal
int dot11radio0
channel 11
Najaf
Mohit Chauhan Wed, 03/13/2013 - 00:29
Thanks Najaf, I'll do that and let you know. But how about the 5GHz speed, shall i leave it as it is?
kcnajaf@25070 Wed, 03/13/2013 - 00:48
Hi Mohit,
You can leave 5GHZ as is. You will not be able to change it :-)
Najaf
