02-22-2013 09:35 PM - edited 03-01-2019 10:53 AM
6248-A manager ip1.1.1.2
6248-B manager ip1.1.1.3
cluster VIP 1.1.1.1
cisco6248-A# show cluster extended-state
Cluster Id: 0xd59a70527a4111e2-0x8b74547feebbcd64
Start time: Sat Feb 23 12:44:03 2013
Last election time: Sat Feb 23 12:55:11 2013
A: UP, PRIMARY
B: UP, SUBORDINATE
A: memb state UP, lead state PRIMARY, mgmt services state: UP
B: memb state UP, lead state SUBORDINATE, mgmt services state: UP
heartbeat state PRIMARY_OK
INTERNAL NETWORK INTERFACES:
eth1, UP
eth2, UP
HA READY
Detailed state of the device selected for HA storage:
Chassis 1, serial: FOX1618GW6D, state: active
Chassis 2, serial: FOX1625GAB0, state: active
Chassis 3, serial: FOX1613G1LV, state: active
MY PC IP 1.1.1.10 can ping all 1.1.1.1/2/3.and https all
but when i reload 6248-A ,can not ping 1.1.1.1,but can ping 1.1.1.3.
also can not https://1.1.1.1 (login error:failed login info:ucsm is not available on secondary node)
when 6248A reload ok,can ping 1.1.1.1/2/3,and https all
if fi6248 cluster is not ok?
02-23-2013 12:25 AM
When you reload FI-A ( active primary ) , virtual IP is owned by FI-B, and should be become primary. Once it becomes primary, you should be able to access UCSM or SSH into FI via Virtual IP address ( 1.1.1.1 ).
1) How are these FI mgmt ports connected to upstream switch / L3 gateway ?
2) Are you able to SSH into FI-B with 1.1.1.1 ( when FI-A is reloading ) ?
3) Have you configured any mgmt interface monitoring policy ?
Padma
02-24-2013 05:31 PM
when FI-B becomes primary,(login error:failed login info:ucsm is not available on secondary nodeashould) unable to access UCSM or SSH into FI via Virtual IP address ( 1.1.1.1 ).
1.all FI mgmt ports connected to upstream switch ,and have a L3 gateway.
2.i able to SSH into FI-B with 1.1.1.1 ( when FI-A is reloading ).
3.i have not configured any mgmt interface monitoring policy .
other place have same question.
03-25-2013 10:49 AM
Dear,
I'm having exactly the same issue on my Fabrics, running 2.04b.
Did anyone resolve this issue?
Thanks in advance and kind regards,
Gerald.
03-25-2013 02:21 PM
Hi, is your upstream core Juniper?
03-25-2013 06:26 PM
noT JUNIPER .it is h3c.
03-26-2013 04:20 AM
We ran a new test with a linux host on the same subnet than the UCSM.
By looking at the ARP table on the linux host, we noticed that the VIP address changes within a minute.
So, it should be an upstream issue towards the subnet from where we access the UCSM.
Can you also run a test within the same subnet and verify if the VIP changes within a minute?
I believe we also have Junipers upstream. I'm investigating this now.
03-26-2013 06:34 AM
We had experienced the same with Juniper, BUT when we upgraded to one of the latest JUNOS, it took less than a minute for the VIP`s arp to point to FI-B.
03-26-2013 06:44 AM
You might want to check that you have Juniper's equivelant of "PortFast" configured on the ports. This might speed up the STP bring up process.
Robert
