VPN client internal error 2738
Answered Question
Feb 24th, 2013
Hi.
I'm having internal error 2738 on unstall. How to solve the error?
Ghana you.
Correct Answer by jawad-mukhtar about 3 years 10 months ago
Thats Nice.
Have a Nice Day
*** Rate Helful Posts***
Overall Rating: 5 (3 ratings)
jawad-mukhtar Mon, 02/25/2013 - 06:27
When you attempt to install Cisco VPN client in Windows Vista or Windows 7, you receive the following error:
Internal Error 2738
This error prevents Cisco VPN client from instlaling properly.
Solutions
There are two steps to the following solution. If the first
To resolve this error, do the following:
  1. Make sure the Cisco VPN client installer is closed before you begin.
  2. Click Start > All Programs > Accessories
  3. Right-click on Command Prompt in the Accessories section of the Start Menu and select Run as Administrator.
  4. Type cd C:\Windows\System32 and then press Enter.
  5. Type regsvr32 C:\Windows\System32\vbscript.dll and then press Enter.
  6. You will receive a message that says, "DLLRegisterServer in C:\Windows\System32\vbscript.dll succeeded." Click OK.
  7. Keep the command prompt window open for now.
    • You  can close this window once you're able to install Cisco VPN client. If  the steps above did not resolve the error, you will use the command  prompt window in the instructions below.
You should now attempt to install Cisco VPN client. If you get the same error as before, proceed with the instructions below.
Step 2
Important: These  instructions require you to edit the registry, which is a potentially  dangerous task. Do not follow these instructions unless you are  confident that you know what you're doing. It is recommended that you  make a registry backup prior to editing the registry. Refer to 1115: Backing up and restoring registry keys in Windows.
  1. Click Start and type regedit in the box.
  2. Browse to the following location: HKEY_CURRENT_USER\SOFTWARE\Classes\CLSID\
  3. Locate and delete the registry key named {B54F3741-5B07-11CF-A4B0-00AA004A55E8}.
    • We recommend making a backup of this registry key before deleting it.
  4. Close the registry editor.
  5. Go back to the command prompt window you used in the instructions above.
    • If you closed this window, follow steps 1 - 4 above to open the command prompt window using the Run as Administrator option and navigate to the C:\Windows\System32 directory.
  6. Within the C:\Windows\System32 directory, type regsvr32 C:\Windows\System32\vbscript.dll and then press Enter.
  7. You will receive a message that says, "DLLRegisterServer in C:\Windows\System32\vbscript.dll succeeded." Click OK.
  8. Close the command prompt window.
You can now install Cisco VPN client.
jmp780718 Wed, 02/27/2013 - 22:50
Thanks the second Step works for me
Sent from Cisco Technical Support Android App
