6248UP - Fabric Interconnect [id], HA functionality not ready
Mar 1st, 2013
Hello
Having an HA issue with a FI cluster and have not able to find much info.
The error I get (in the subject) leads me the the below URL with 5 steps to check.
http://www.cisco.com/en/US/docs/unified_computing/ucs/ts/faults/reference/2.0/UCS_SEMs.html
Step 1 - Not sure how to check this - Any input on this ?
Step 2 - Have checked and even replaced the cables
Step 3 - Checked and confirmed under Equipments -> Rack-Mounts -> Fex ( 2 x N2K-C2232PP-10GE)
Step 4 - Checked and confirmed under Equipments -> Rack-Mounts -> Servers ( 4 x UCSC-C220-M3)
Step 5 - New installation no active contract as yet.
Anyone had similar issues, any assistance would be appreciated.
Neil Stewart Fri, 03/01/2013 - 02:21
Step 1
Management all setup with initial setup-script, confirmed in extract from running config below
scope fabric-interconnect a
     set out-of-band ip 172.16.1.4 netmask 255.255.255.0 gw 172.16.1.1
scope fabric-interconnect b
     set out-of-band ip 172.16.1.5 netmask 255.255.255.0 gw 172.16.1.1
scope system
     set virtual-ip 172.16.1.6
Double confirmed via show commands below
CTCPFIHA-A# scope fabric-interconnect a
CTCPFIHA-A /fabric-interconnect # show detail
Fabric Interconnect:
    Product Name: Cisco UCS 6248UP
    PID: UCS-FI-6248UP
    VID: V01
    Vendor: Cisco Systems, Inc.
    Serial (SN): SSI163308YF
    HW Revision: 0
    Total Memory (MB): 16232
    OOB IP Addr: 172.16.1.4
    OOB Gateway: 172.16.1.1
    OOB Netmask: 255.255.255.0
    Operability: Operable
    Thermal Status: Ok
    Current Task 1:
    Current Task 2:
CTCPFIHA-A /fabric-interconnect # scope fabric-interconnect b
    PID: UCS-FI-6248UP
    VID: V01
    Serial (SN): SSI16330FY1
    HW Revision: 0
    OOB IP Addr: 172.16.1.5
    Thermal Status: Ok
    Current Task 1:
    Current Task 2:
CTCPFIHA-A /fabric-interconnect # scope system
CTCPFIHA-A /system # show detail
Systems:
    Mode: Cluster
    System IP Address: 172.16.1.6
    System Owner:
    System Site:
    Description for System:
Step 2
L1<>L1 L2<>L2 confirmed and new cables tried.
padramas Fri, 03/01/2013 - 03:54
  • Cisco Employee,
Hello Neil,
Can you please SSH into FI and share the output of following command ?
show system firmware
show cluster extended-state
Padma
Neil Stewart Fri, 03/01/2013 - 04:02
CTCPFIHA-A# show system firmware
UCSM:
    Running-Vers: 2.1(1a)
    Package-Vers: 2.1(1a)A
    Activate-Status: Ready
CTCPFIHA-A# show cluster extended-state
Cluster Id: 0xb72022187f3511e2-0x9307547feeed8b24
Start time: Mon Feb 25 14:15:07 2013
Last election time: Tue Feb 26 14:40:01 2013
A: UP, PRIMARY
B: UP, SUBORDINATE
A: memb state UP, lead state PRIMARY, mgmt services state: UP
B: memb state UP, lead state SUBORDINATE, mgmt services state: UP
   heartbeat state PRIMARY_OK
INTERNAL NETWORK INTERFACES:
eth1, UP
eth2, UP
HA NOT READY
No device connected to this Fabric Interconnect
Andreas Linde Fri, 03/01/2013 - 04:11
Could it be that You haven´t connected any chassis yet? The FI´s look fine to me.
padramas Fri, 03/01/2013 - 04:17
  • Cisco Employee,
Hello Neil,
The output is as expected as we do not have any chassis or rack server connected to FI. SEEPROM in chassis or file in rack server management flash serves to decide active FI during spilt brain scenario.
The message would disappear once you have chassis or rack server connected to FI.
A good blog about this topic
http://ucsguru.com/2012/11/07/ha-with-ucsm-integrated-rack-mounts/
Padma
padramas Fri, 03/01/2013 - 04:50
  • Cisco Employee,
Hello Neil,
Can you please share the output of following command
show server status
Are you able to connect to CIMC of the servers ?  ( connect cimc )
Padma
Neil Stewart Fri, 03/01/2013 - 05:28
Hello Padma
I have left site and will be back next week wednesday day,
I will update the dicussion then.
Neil Stewart Fri, 03/01/2013 - 06:29
CTCPFIHA-A# show service status
Service Profile Name Server Assignment Association   Power State   Op State
CTCPVM01             1       Assigned   Associated     On             Ok
CTCPVM02             2       Assigned   Associated     On             Ok
CTCPVM03             3       Assigned   Associated     On             Ok
CTCPVM04             4       Assigned   Associated     On             Ok
Old                         Unassigned Unassociated                 Unassociated
VM-Host-Infra               Unassigned Unassociated                 Unassociated
padramas Fri, 03/01/2013 - 23:00
  • Cisco Employee,
Hello Neil,
We need more logs to investigate the issue.
Please open a TAC service request with UCSM and one rack server tech support bundle.
Padma
drhallahan Sat, 03/16/2013 - 17:33
Was it just that shared storage wasn't connected or configured?
Neil Stewart Mon, 03/18/2013 - 00:19
A Cabling Issues caused the problem.
We had the servers cabled as below.
CIMC -> FI A
LAN1 -> FI_B
Strangely, FI_B coulds see the CIMC, FI_A could not.
We recabled the servers the (as below) and re-acknowledged the servers.
LAN1 -> FI_A
LAN2 -> FI_B
Both IFs see the CIMC and HA up - all is good.
