03-04-2013 10:59 PM - edited 03-07-2019 12:03 PM
I set a password for the 'VTY lines', the Console, I set an 'enable secret' and an 'enable' password,
but when I log in via ssh I get this:
Switch15>en
Password required, but none set
Password:
Switch15#sh run
Building configuration...
Current configuration : 28178 bytes
I type in the 'enable secret' and get into the enable mode...
I always get this "Password required, but none set"! But all passwords are set.
It's a WS-C2960S-48TD-L with IOS Version is 15.0(2)SE2 (C2960S-UNIVERSALK9-M)
What am I missing?
Kind regards,
Andreas
Solved! Go to Solution.
03-08-2013 10:03 AM
I'm not the original poster but the aaa authentication enable default enable command solved the problem for me. Rated appropriately. Thank you very much.
03-05-2013 12:45 AM
no aaa new-model
line vty 0 4
login local
03-05-2013 12:50 AM
HI Andreas,
You need to specify it under line vty 0 4.
eg:
username cisco secret cisco enable secret cisco line vty 0 4 logging synchronous login local
03-05-2013 01:00 AM
Hi and thanks for the reply,
sorry but there is no option "login local" under 'line vty 0 4' since I use radius authentication(aaa new-model).
I only have "login authentication [WORD | default]".
I tried already to set 'login authentication default' under the 'line vty 0 4' but no success...
03-07-2013 12:26 PM
This must be a cosmetic bug. I get the same message when I SSH into a 3750X with 15.0(2)SE2 and AAA enabled. Disable AAA and the message disappears.
04-08-2013 02:29 PM
I think you're right, I get the same on a 3560X running 15.0(2)SE2
User Access Verification
Username: cisco
Password:
MySwitch>en
Password:
Myswitch#
so everything works apart from our automated scripts
03-07-2013 01:48 PM
If you are trying to use the RADIUS authentication there are additional steps, here is my setup and I'm running 15.1(1)SG1
aaa new-model
aaa authentication login vtylogin group radius local
aaa authentication login conlogin group radius local
aaa authentication enable default group radius enable
aaa authorization console
aaa authorization exec vtylogin group radius local
aaa authorization exec conlogin group radius local
radius server RADIUS
address ipv4 x.x.x.x auth-port 1645 acct-port 1646
timeout 3
retransmit 3
key xxxxxxxxxxxxxxxxxxxxxxxxx
ip radius source-interface vlan200
line vty 0 4
exec-timeout 0 5
login authentication vtylogin
transport input ssh
03-08-2013 12:30 AM
When I use the 'aaa authentication exec' command it kicks me out immediately after entering the password, so I can't use this option.
The other thing is I need to use the local enable(secret) password for the priv. exec mode.
I tried all other options but no luck.
03-08-2013 03:19 AM
I doesn't matter what I configure, It always brings this message. I doubt it has something to do with the vty lines, because the message comes after typing 'enable':
Switch42>en
Password:
Switch42#
03-08-2013 07:06 AM
It is possible that the issue is on the RADIUS server. What are you using for the RADIUS server?
03-08-2013 07:06 AM
Hi Andreas,
It seems that you did not set the password on the “ssh” configuration and that is why you
are receiving the specific message when trying to “ssh” to the switch.
The next configuration is the right configuration to applied:
Switch(config)#line vty 0 15
Switch(config-line)#transport input ssh
Switch(config-line)#password xxxx
Inayath
03-08-2013 09:46 AM
try this:
aaa new-model
aaa authentication login default local
username test password test
enable secret test
If this will not work, can you paste your config to see what is wrong?
Best Regards
Please rate helpful posts and close solved questions
03-08-2013 10:03 AM
03-11-2013 12:38 AM
thank you all, the aaa authentication enable default enable does the trick !
Thanks!
Kind regards!
07-26-2013 10:30 AM
As Chuck said above, it appears to be cosmetic. When running 15.0(2)SE on a 3560, I had NO problems, but when I upgraded to 15.0(2)SE4, the "Password required, but none set" message pops up. However, it does still require that I enter the correct password.
So I verified that 15.0(2)SE4 caused this by downgrading back to 15.0(2)SE and the error went away.
