03-05-2013 08:31 AM - edited 03-07-2019 12:04 PM
I have a ring with four IE3000-8TC switches Sw1, Sw2, Sw3, Sw4
They are configured in this way:
____________________________
Sw1
rep admin vlan 997
int gi1/1
sw mode trunk
rep segment 1 edge primary
int gi1/2
sw mode trunk
rep segment 1 edge
Sw2
rep admin vlan 997
int gi1/1
sw mode trunk
rep segment 1
int gi1/2
sw mode trunk
rep segment 1
Sw3
rep admin vlan 997
int gi1/1
sw mode trunk
rep segment 1
int gi1/2
sw mode trunk
rep segment 1
Sw4
rep admin vlan 997
int gi1/1
sw mode trunk
rep segment 1
int gi1/2
sw mode trunk
rep segment 1
The connections are showed in the image attacched, when all conections are working fine rep doesnt have problems and i show the rep topology like this
SW1#sh rep topology
REP Segment 1
BridgeName PortName Edge Role
SW1 Gi1/1 Pri Open
SW2 Gi1/1 Open
SW2 Gi1/2 Open
SW3 Gi1/1 Open
SW3 Gi1/2 Open
SW4 Gi1/1 Open
SW4 Gi1/2 Alt
SW1 Gi1/2 Sec Open
But if i disconnect a link in the sw3 the rep topology show the next output and the convergence doesnt works
SW1#sh rep topology
REP Segment 1
Warning: REP detects a segment failure, topology may be incomplete
SW1 Gi1/1 Sec Open
SW2 Gi1/1 Open
SW2 Gi1/2 Open
SW3 Gi1/1 Open
SW4 Gi1/2 Fail
Why I have lost the direct link between SW1 and SW4??
02-15-2016 11:56 PM
I have quite same this problem but it occurs on ME3400 ring. I went to SW that show fail, shutdown and no shutdown the failed interface. It’s work. But I don’t know why?
System image file is "flash:me340x-metroipaccessk9-mz.122-53.SE.bin"
ac3400combo(config)#int gi0/16
ac3400combo(config-if)#shu
005830: Feb 16 14:26:45.074 bkk: %REP-4-LINKSTATUS: GigabitEthernet0/16 (segment 1) is non-operational due to port become non-trunk
005831: Feb 16 14:26:46.818 bkk: %LINK-5-CHANGED: Interface GigabitEthernet0/16, changed state to administratively down
005832: Feb 16 14:26:47.825 bkk: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/16, changed state to down
ac3400combo(config-if)#no shu
005833: Feb 16 14:27:12.294 bkk: %LINK-3-UPDOWN: Interface GigabitEthernet0/16, changed state to up
005834: Feb 16 14:27:13.301 bkk: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/16, changed state to up
ac3400combo(config-if)#end
ac3400combo#
005835: Feb 16 14:27:16.480 bkk: %REP-4-LINKSTATUS: GigabitEthernet0/16 (segment 1) is operational
Thank you very much.
05-20-2016 12:00 PM
Had this problem in a lab I configured today also. Did you have any luck resolving this?
I've a stacked 3750X with 2x IE-3000 access switches in a REP ring.
SW1 Gi1/0/1 Pri Open
SW2 Gi1/1 Open
SW2 Gi1/2 Open
SW3 Gi1/1 Open
SW3 Gi1/2 Open
SW1 Gi2/0/1 Sec Alt
REP works fine if I remove the open link connected to the primary edge port. However if I remove the trunk link between the 2x IE-3000 access switches, REP does not converge.
