Showing results forĀ
Search instead forĀ
Did you mean:Ā
CER v9 upgrade questions - licensing - media
kbyrd
Level 2
Level 2
I have  customer woth dual 7816I5s running CER 8.5.1. He needs an upgrade to pick up support for a couple of new switches whose MIBs are not in 8.5.1. This switch is in 8.7 and 9.0.2.
1) In the downloads section of CCO, there is no ISO for 8.7 - only OVAs. However, there is an ISO for 9.0.2. Has 8.7 been pulled?
2) Will I need to upgrade licenses from v8 to v9? I did not see that addressed in the release notes.
Thanks.
yahsiel2004
Level 7
Level 7
You would get the software from Cisco through the PUT Tool if you have UCSS CUWL. If not, you will need to purchase the software.
You would need to upgrade your license from version 8 to 9.
Yosh
HTH Regards, Yosh
