03-05-2013 04:15 PM - edited 03-07-2019 12:04 PM
Hi all,
We have recently purchased 2 x 4900M switches with the following configuration:
2 x X2-10GB-SR installed in port te1/1, 1/2 (optical)
1 x 20 x 1GB RJ45 installed in the top left of chasis ge2/1 - 2/20
1 x WS-X4908-10G-RJ45 8 port 1/2 card in the top right of chassis te3/1 - 3/8
We have te1/1 connecting the 2 switches, and various vlan's and connections on the 1GB RJ45's with no problems.
However, we have a number of 10Gbps BaseT connections te3/1 - te3/5 which are causing us issues. On a reload of the switch or removal / re-install of the cable it can take anywhere up to an hour for the port to become active again. So when we reload the switch, we may get a connection come up after say 3 mins, but the port next to it may not come up for 15-60 min. The cabling is all the same (CAT6 and has been tested/verified) and all connections go to Broadcom 10Gb cards in Dell 820 servers running vmware. We have the following set on the ports:
switchport mode access
spanning-tree portfast
No speed or duplex can be set on these ports - these options are not available in the config.
Is this normal? Is there something I am missing in config for these ports? By the way, once a link is finally established, it will hold the link solid with no problems, but this is a problem for us, we can't have a reboot take an undetermined amount of time for the link to come back.
Any help appreciated.
Cheers,
Shane
03-05-2013 04:34 PM
No that is not normal at all. What if you use ports (te3/1 - te3/5) instead of te1/1 to connect the switches together?
Do you still have the same problem?
I know it is hard to find a laptop or desktop with 10Gig interface, but is there is device other then the servers you can connect to these ports?
03-05-2013 04:56 PM
Thanks for reply,
I connected te3/1 to te3/1 on each switch and the link took 5 min 3 seconds to establish.
I also have some dell 10Gb rj-45 switches and if I connect the server to a dell switch the link is basically instant (as one would expect).
It's really got us scratching our heads...
Cheers,
Shane
03-05-2013 05:30 PM
What version of IOS are you running?
Cisco IOS Software Release 12.2(54)SG continues to deliver data center smart top-of-rack services:
• Hardware support for the new Cisco Catalyst 4948E
• Hardware support for the new Cisco Catalyst 4900M 8-Port 10GBASE-T RJ-45 Half Card (WS-X4908-10G-RJ45)
more info:
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps6021/product_bulletin_c25_608183.html
03-05-2013 06:05 PM
Seems our output below has ROM: 12.2(44r)SG10, should we be running 12.2(54)SG?
We only purchased these switches a couple of weeks ago, I didn't look to see if they were up to the latest IOS.
Output from show version:
Cisco IOS Software, Catalyst 4500 L3 Switch Software (cat4500e-ENTSERVICESK9-M),
Version 15.0(2)SG3, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Mon 09-Jan-12 01:56 by prod_rel_team
Image text-base: 0x10000000, data-base: 0x12E99770
ROM: 12.2(44r)SG10
Sushi Revision 11, Tatooine Revision 141, Forerunner Revision 1.79
swe11 uptime is 22 hours, 22 minutes
System image file is "bootflash:cat4500e-entservicesk9-mz.150-2.SG3.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
cisco WS-C4900M (MPC8548) processor (revision 2) with 1048576K bytes of memory.
Processor board ID JAE16110AY1
MPC8548 CPU at 1.33GHz, Cisco Catalyst 4900M
Last reset from PowerUp
1 Virtual Ethernet interface
28 Gigabit Ethernet interfaces
16 Ten Gigabit Ethernet interfaces
511K bytes of non-volatile configuration memory.
Configuration register is 0x2101
Cheers,
Shane
03-05-2013 07:32 PM
No, that is firm ware for Rommon and usually doesn't need to be ugraded often. Your IOS version is 150-2.SG3, which is pretty new. Also one more thing and this shouldn't make any difference on the issue you have, but your config register is 0x2101. Can you change it to 0x2102, reboot and test again?
03-05-2013 07:56 PM
That particular switch had no compact flash card installed - so 0x2102 sent it into a reboot loop as is couldn't find an image in slot0. I have since added a card with the image and it's rebooting now.
I also contacted cisco and they are making 15.1.2SG available as these switches were purchased within the last 90 days.
I will test this as soon as I receive the new image.
Thanks for your help... getting there...
Cheers,
Shane
03-06-2013 05:39 PM
I have now deployed cat4500e-entservicesk9-mz.151-2.SG.bin on both switches, and found a vmware driver update for the broadcom cards they are connected to (BCM-NetXtremeII-7.0-1036215.zip released 2 days ago). Also 1 of the ports is connected directly to a Windows 2k8 server.
It didn't help. A reload of both switches saw the following:
sw2 port 3/4 up at 40 seconds
sw2 port 3/3 up at 1:42 seconds
sw1 port 3/3 up at 6:50 seconds
Then no other ports up to 15 mins, so I went and got a coffee, came back and the last port came on-line at 40 minutes 11 seconds (the others somewhere between 15-40 mins).
I was timing from when the module status light turned green during reload.
Still stumped.
Cheers,
Shane
03-06-2013 06:09 PM
A further search on these discussions found that downgrading to 122-54.SG1 may fix the problem. I'll test that and see.
Cheers,
Shane
03-07-2013 05:15 PM
Downgrading to 122-54.SG1 has fixed the problem. Each of the ports now starts approximately 5 seconds after the modules status light turns green. If you unplug a link and plug it back in - the port again comes up after approx 5 seconds.
A Cisco support case has been opened, how can they release an IOS and ship it on a device that clearly does not work properly...
Cheers,
Shane
04-23-2013 09:14 AM
I've got a very similar problem except mine won't come up at all.
Upgraded to 15.1(2) from 122-54
and now a few of the 10GBaseT connections are acting strange.
The ports that were up when I upgraded have stayed up however I can't get a new connection to work. This was from a ESX vmWare server. This connection used to work perfectly fine. We only plug it in when needed.
I even tried using the hw-module command to change the port to 1G but it still will not come up.
So I tried moving an working 10G connection from port Te2/4 to port Te2/3 and now this connection wont come up no matter where I try and connect it.
I've verified it isn't the server becasue they come up fine on another switch at 1G.
I've got a TAC case in. I'll let you know what happens. This sucks becasue the last time I tried moving to 15.0 I had to back down to 12.2 becasue of these stupid RF45 ports.
04-24-2013 12:26 PM
So the solution from TAC is to downgrade back to 12.2.54,
This is the second time I've tried to upgrade these switches only to spend wasted hours troubleshooting the problem and then having to downgrade anyway.
04-25-2013 03:31 PM
Thanks for your update. I am still providing debugging info to my support case (have provided heaps so far). No solution as yet though...
Like you - we are currently running 12.2.54 while we wait for a working update.
Cheers,
Shane
04-30-2013 08:03 AM
I wanted to give anyone finding this post an update.
We downgraded to 12.2.54 last week and the 10GBaseT ports work perfectly now.
I wanted to let you all know about another problem with the 4900M that cropped up when I went to 15.1 that also has gone away. It has to do with the switched reporting a %SNMP-3-CPUHOG error. I would get this error when a network management device I have did a SNMP discovery of the device. I have all the nasty details documented so I can discuss in more detail if needed.
The short version is the 4900M CPU would spike to over 90% for about 5 minutes blocking any other SNMP requests.
The final resolution from TAC was
"the SNMP Engine seems to be getting in a loop while polling the following OID:lldpXMedLocMediaPolicyEntry"
The TAC solution (basically telling the 4900M to ignore requests for that OID) did resolve the problem however when I downgraded back to 12.2.54 the issue went away.
So the best advice if you have a 4900M is to just stay away from 15.x for now.
Thanks.
-Clay
04-30-2013 09:39 AM
My take has always been unless a code upgrade is needed to support new hardware or to fix a specific problem or security issue , leave it alone. If it's not broke don't fix it .
