MARS updates failing due to certificate error (FYI)
Mar 6th, 2013
All our MARS devices started failing IPS signature dynamic updates today due to a certificate error.  I assume this has been updated using a root which isn't in the MARS.  I've opened a TAC case to confirm the change was intentional.  Assuming it is, all MARS devices in the field will need manual attention before they continue updating.  I will provide an update later today.
Error:
Download Failed: CS-MARS could not download IPS Signature file at Mar 06, 2013 01:15:51 PM GMT+00:00
When I click "Update now" I'm asked to accept the following certificate:
Do you want to accept following certificate for device at IpAddress <the IP varies by device>
Subject: CN=Baltimore CyberTrust Root, OU=CyberTrust, O=Baltimore, C=IE
Issuer: CN=Baltimore CyberTrust Root, OU=CyberTrust, O=Baltimore, C=IE
Valid From: Fri May 12 18:46:00 GMT+00:00 2000
Valid To: Mon May 12 23:59:00 GMT+00:00 2025
Public Key Algorithm: RSA
Signing Algorithm: SHA1withRSA
Related Content
