Smart Call Connector SCC UC500
alangoh27
I have a question on SCC for my customer.
He wants basic presence on their internal NFR UC540 system but have no requirement for receptionist usage.
I’ve been having a hunt around and would like to confirm what would be needed?
They have 17 phones so would they need to get
1x L-SW-SCC-SERVER
2x L-SW-SCC-8ADVANCED
I’m guessing they wouldn’t need SCC for all handsets so could probably get away with 1 additional licence pack.
Also is the Server SKU needed to run SCC? I have heard that it may not be needed?
Thanks in advance for your help
David Trad
Hi Alan,
You can run standalone mode but not recommended.
I would stick with your original assumption and get a server and 2X 8 Pac licenses to cover it, in order for SCC to really work properly it is highly recommended to get a server, and then spend the countless hours setting it up as well
But please keep in mind that I do not see Cisco continuing any maintenance on SCC or any other major releases, I could be wrong, but I know it wont most likely be setup to work with Windows 8 either, which tells me (And I could be wrong again) that they will probably call it EoL and EoS.
Cheers,
David Trad.
**If you don't want to rate a post that is fine, I'll just find out where you live and hunt you down**
^^ That's a joke just in case you didn't get it :)
Cheers, David Trad. **When you rate a persons post, you are indicating a thank you or that it helped, but at the same time you are also helping to maintain the community spirit - You don't have to rate posts and you wont be looked down upon :) *
David Trad
Hi Alan,
Cheers,
David Trad.
