Need SIP provider that will allow me to send SNR caller-id
jforbis
I have a UC560 that is running 8.6.1 and we have a PRI connected as the only phone line.  Our PRI provider will not let us send a caller id phone number that is not in their system so when we have a SNR call it shows up as our main number on the cell phone. I am looking to get a SIP connection to allow me to do this and send the original caller id to the cell phone on a SNR call. I have setup Skype for SIP and it does not send the correct caller id.
Does anyone use a SIP provider that the SNR caller id works?
Let me know and I will try it.
Darren DeCroock
Level 4
Level 4
I personally do not know of a specific SIP provider that I could recommend.  But there are some out there that validate the call based on the IP address it is coming from and not the Caller-ID/Account number.
Maybe someone else here may know of a provider they could suggest.
Thank you,
Darren
pennautomotive
Take a look at NexVortex. If you decide to use their service let them know Jordan Feldman of Penn Automotive sent you. Good Luck!
danplacek
Level 4
Level 4
We have used both NexVortex and Flowroute for this.
We prefer Flowroute.
Keep in mind SIP over the public internet has no voice quality guarantee -- at some point it will be bad.
