Warning message
Voicemail to email notification not working...anymore
Mar 13th, 2013
I moved a UC520 for a client and all of a sudden their VM to email notification is no longer working. All other aspects of their CUE are working fine (i.e. auto attendant, mwi, etc). I have run a debug test on the system when leaving a message and am unsure as to what is causing the problem. Any assistance would be appreciated. I have attached the trace I get when I leave the message.
3528 03/13 23:29:30.263 VMSS mnot 0 MessageNotification: Enter insertIntoMsgNotifQueue(): msg recipient: efearnotif target: efear
3528 03/13 23:29:30.355 VMSS mnot 0 MessageNotification: Exit insertIntoMsgNotifQueue(): notifyEmailThread=false, notifyPhoneThread=false
Yasien Adams Wed, 03/13/2013 - 21:48
please elaborate.
you moved the UC to a different location?
did the server you were pointing to as the smtp server get moved as well?
or is that server still visible to the UC?
Alexander Maroukian Thu, 03/14/2013 - 01:28
  • Cisco Employee,
Hello Jay,
Please check if you have the email notification enabled for that user.
I see the following in the trace (bold):
You may easily check if the SMTP work by going to CUE web GUI -> System-> SMTP Settings -> Test SMTP setting. There you put an email and send test email to it.
HTH,
Alex
*Please rate helpful posts
Related Content
