NAT - table too small
LisaLarscandc
I have an RV082  10/100 8-Port VPN Router and have configured the NAT table to allow for remote users, however I've run into an issue. It seems like there is a limited number of entries that you can put in the table,10, and I need to configure about 5 more IPs.
Does anyone know a way to expand the NAT table, or alternatively recommend a different router. I would also be willing to add another router to the network, but I have little experience doing that.
Thank you.
Te-Kai Liu
Level 7
Level 7
If you are using the 1-to-1 NAT feature of RV082, the 1-to-1 NAT table supports 10 entries, each of which can be a range of IP addresses.
Bilal Nawaz
Which type of NAT are you using?
Please rate useful posts & remember to mark any solved questions as answered. Thank you.
Te-Kai Liu
Level 7
Level 7
Of course - thank you!!
It just wasn't quite clicking for me, but this makes so much sense.
