03-15-2013 11:36 AM
I did a site-to-site VPN that worked for about a week and won't come back up. Can anyone spot the problem? Its an IOS router on one side, and an ASA on the other. There are 5 VPN's on the box, the others are working fine. I tried to isolate the commands for this tunnel but some others maybe mixed in.
000443: *Mar 14 15:28:47: ISAKMP:(0:3:SW:1):Old State = IKE_P1_COMPLETE New State = IKE_P1_COMPLETE
000444: *Mar 14 15:28:50: ISAKMP (0:0): received packet from 199.x.x. dport 500 sport 500 Global (N) NEW SA
000445: *Mar 14 15:28:50: ISAKMP: Created a peer struct for 199.x.x.x, peer port 500
000446: *Mar 14 15:28:50: ISAKMP: New peer created peer = 0x640CB9E0 peer_handle = 0x80000015
000447: *Mar 14 15:28:50: ISAKMP: Locking peer struct 0x640CB9E0, IKE refcount 1 for crypto_isakmp_process_block
000448: *Mar 14 15:28:50: ISAKMP: local port 500, remote port 500
000449: *Mar 14 15:28:50: insert sa successfully sa = 64040BD8
000450: *Mar 14 15:28:50: ISAKMP:(0:0:N/A:0):Input = IKE_MESG_FROM_PEER, IKE_MM_EXCH
000451: *Mar 14 15:28:50: ISAKMP:(0:0:N/A:0):Old State = IKE_READY New State =IKE_R_MM1
000452: *Mar 14 15:28:50: ISAKMP:(0:0:N/A:0): processing SA payload. message ID= 0
000453: *Mar 14 15:28:50: ISAKMP:(0:0:N/A:0): processing vendor id payload
000454: *Mar 14 15:28:50: ISAKMP:(0:0:N/A:0): vendor ID seems Unity/DPD but major 123 mismatch
000455: *Mar 14 15:28:50: ISAKMP:(0:0:N/A:0): vendor ID is NAT-T v2
000456: *Mar 14 15:28:50: ISAKMP:(0:0:N/A:0): processing vendor id payload
000457: *Mar 14 15:28:50: ISAKMP:(0:0:N/A:0): vendor ID seems Unity/DPD but major 157 mismatch
000458: *Mar 14 15:28:50: ISAKMP:(0:0:N/A:0): vendor ID is NAT-T v3
000459: *Mar 14 15:28:50: ISAKMP:(0:0:N/A:0): processing vendor id payload
000460: *Mar 14 15:28:50: ISAKMP:(0:0:N/A:0): vendor ID seems Unity/DPD but major 69 mismatch
000461: *Mar 14 15:28:50: ISAKMP:(0:0:N/A:0): processing vendor id payload
000462: *Mar 14 15:28:50: ISAKMP:(0:0:N/A:0): vendor ID seems Unity/DPD but major 194 mismatch
000463: *Mar 14 15:28:50: ISAKMP:(0:0:N/A:0):Looking for a matching key for 199.x.x.x in default
000464: *Mar 14 15:28:50: ISAKMP:(0:0:N/A:0): : success
000465: *Mar 14 15:28:50: ISAKMP:(0:0:N/A:0):found peer pre-shared key matching 199.x.x.x
000466: *Mar 14 15:28:50: ISAKMP:(0:0:N/A:0): local preshared key found
000467: *Mar 14 15:28:50: ISAKMP : Scanning profiles for xauth ...
000468: *Mar 14 15:28:50: ISAKMP:(0:0:N/A:0):Checking ISAKMP transform 1 against priority 1 policy
000469: *Mar 14 15:28:50: ISAKMP: default group 2
000470: *Mar 14 15:28:50: ISAKMP: encryption AES-CBC
000471: *Mar 14 15:28:50: ISAKMP: keylength of 256
000472: *Mar 14 15:28:50: ISAKMP: hash SHA
000473: *Mar 14 15:28:50: ISAKMP: auth pre-share
000474: *Mar 14 15:28:50: ISAKMP: life type in seconds
000475: *Mar 14 15:28:50: ISAKMP: life duration (VPI) of 0x0 0x1 0x51 0x80
000476: *Mar 14 15:28:50: ISAKMP:(0:0:N/A:0):Encryption algorithm offered does not match policy!
000477: *Mar 14 15:28:50: ISAKMP:(0:0:N/A:0):atts are not acceptable. Next payload is 3
000478: *Mar 14 15:28:50: ISAKMP:(0:0:N/A:0):Checking ISAKMP transform 2 against priority 1 policy
000479: *Mar 14 15:28:50: ISAKMP: default group 2
000480: *Mar 14 15:28:50: ISAKMP: encryption AES-CBC
000481: *Mar 14 15:28:50: ISAKMP: keylength of 192
000482: *Mar 14 15:28:50: ISAKMP: hash SHA
000483: *Mar 14 15:28:50: ISAKMP: auth pre-share
000484: *Mar 14 15:28:50: ISAKMP: life type in seconds
000485: *Mar 14 15:28:50: ISAKMP: life duration (VPI) of 0x0 0x1 0x51 0x80
000486: *Mar 14 15:28:50: ISAKMP:(0:0:N/A:0):Encryption algorithm offered does not match policy!
000487: *Mar 14 15:28:50: ISAKMP:(0:0:N/A:0):atts are not acceptable. Next payload is 3
000488: *Mar 14 15:28:50: ISAKMP:(0:0:N/A:0):Checking ISAKMP transform 3 against priority 1 policy
000489: *Mar 14 15:28:50: ISAKMP: default group 2
000490: *Mar 14 15:28:50: ISAKMP: encryption AES-CBC
000491: *Mar 14 15:28:50: ISAKMP: keylength of 128
000492: *Mar 14 15:28:50: ISAKMP: hash SHA
000493: *Mar 14 15:28:50: ISAKMP: auth pre-share
000494: *Mar 14 15:28:50: ISAKMP: life type in seconds
000495: *Mar 14 15:28:50: ISAKMP: life duration (VPI) of 0x0 0x1 0x51 0x80
000496: *Mar 14 15:28:50: ISAKMP:(0:0:N/A:0):Encryption algorithm offered does not match policy!
000497: *Mar 14 15:28:50: ISAKMP:(0:0:N/A:0):atts are not acceptable. Next payload is 3
000498: *Mar 14 15:28:50: ISAKMP:(0:0:N/A:0):Checking ISAKMP transform 4 against priority 1 policy
000499: *Mar 14 15:28:50: ISAKMP: default group 2
000500: *Mar 14 15:28:50: ISAKMP: encryption 3DES-CBC
000501: *Mar 14 15:28:50: ISAKMP: hash SHA
000502: *Mar 14 15:28:50: ISAKMP: auth pre-share
000503: *Mar 14 15:28:50: ISAKMP: life type in seconds
000504: *Mar 14 15:28:50: ISAKMP: life duration (VPI) of 0x0 0x1 0x51 0x80
000505: *Mar 14 15:28:50: ISAKMP:(0:0:N/A:0):atts are acceptable. Next payload is 3
000506: *Mar 14 15:28:51: ISAKMP:(0:4:SW:1): processing vendor id payload
000507: *Mar 14 15:28:51: ISAKMP:(0:4:SW:1): vendor ID seems Unity/DPD but major 123 mismatch
000508: *Mar 14 15:28:51: ISAKMP:(0:4:SW:1): vendor ID is NAT-T v2
000509: *Mar 14 15:28:51: ISAKMP:(0:4:SW:1): processing vendor id payload
000510: *Mar 14 15:28:51: ISAKMP:(0:4:SW:1): vendor ID seems Unity/DPD but major 157 mismatch
000511: *Mar 14 15:28:51: ISAKMP:(0:4:SW:1): vendor ID is NAT-T v3
000512: *Mar 14 15:28:51: ISAKMP:(0:4:SW:1): processing vendor id payload
000513: *Mar 14 15:28:51: ISAKMP:(0:4:SW:1): vendor ID seems Unity/DPD but major 69 mismatch
000514: *Mar 14 15:28:51: ISAKMP:(0:4:SW:1): processing vendor id payload
000515: *Mar 14 15:28:51: ISAKMP:(0:4:SW:1): vendor ID seems Unity/DPD but major 194 mismatch
000516: *Mar 14 15:28:51: ISAKMP:(0:4:SW:1):Input = IKE_MESG_INTERNAL, IKE_PROCESS_MAIN_MODE
000517: *Mar 14 15:28:51: ISAKMP:(0:4:SW:1):Old State = IKE_R_MM1 New State = IKE_R_MM1
000518: *Mar 14 15:28:51: ISAKMP:(0:4:SW:1): constructed NAT-T vendor-03 ID
000519: *Mar 14 15:28:51: ISAKMP:(0:4:SW:1): sending packet to 199.x.x.x my_port 500 peer_port 500 (R) MM_SA_SETUP
000520: *Mar 14 15:28:51: ISAKMP:(0:4:SW:1):Input = IKE_MESG_INTERNAL, IKE_PROCESS_COMPLETE
000521: *Mar 14 15:28:51: ISAKMP:(0:4:SW:1):Old State = IKE_R_MM1 New State = IKE_R_MM2
000522: *Mar 14 15:28:51: ISAKMP (0:134217732): received packet from 199.x.x.x.x dport 500 sport 500 Global (R) MM_SA_SETUP
000523: *Mar 14 15:28:51: ISAKMP:(0:4:SW:1):Input = IKE_MESG_FROM_PEER, IKE_MM_EXCH
000524: *Mar 14 15:28:51: ISAKMP:(0:4:SW:1):Old State = IKE_R_MM2 New State = IKE_R_MM3
000525: *Mar 14 15:28:51: ISAKMP:(0:4:SW:1): processing KE payload. message ID = 0
000526: *Mar 14 15:28:51: ISAKMP:(0:4:SW:1): processing NONCE payload. message ID = 0
000527: *Mar 14 15:28:51: ISAKMP:(0:0:N/A:0):Looking for a matching key for 199.x.x.x in default
000528: *Mar 14 15:28:51: ISAKMP:(0:0:N/A:0): : success
000529: *Mar 14 15:28:51: ISAKMP:(0:4:SW:1):found peer pre-shared key matching 199.x.x.x.
000530: *Mar 14 15:28:51: ISAKMP:(0:4:SW:1):SKEYID state generated
000531: *Mar 14 15:28:51: ISAKMP:(0:4:SW:1): processing vendor id payload
000532: *Mar 14 15:28:51: ISAKMP:(0:4:SW:1): vendor ID is Unity
000533: *Mar 14 15:28:51: ISAKMP:(0:4:SW:1): processing vendor id payload
000534: *Mar 14 15:28:51: ISAKMP:(0:4:SW:1): vendor ID seems Unity/DPD but major 206 mismatch
000535: *Mar 14 15:28:51: ISAKMP:(0:4:SW:1): vendor ID is XAUTH
000536: *Mar 14 15:28:51: ISAKMP:(0:4:SW:1): processing vendor id payload
000537: *Mar 14 15:28:51: ISAKMP:(0:4:SW:1): speaking to another IOS box!
000538: *Mar 14 15:28:51: ISAKMP:(0:4:SW:1): processing vendor id payload
000539: *Mar 14 15:28:51: ISAKMP:(0:4:SW:1):vendor ID seems Unity/DPD but hash mismatch
000540: *Mar 14 15:28:51: ISAKMP:received payload type 20
000541: *Mar 14 15:28:51: ISAKMP (0:134217732): NAT found, the node inside NAT
000542: *Mar 14 15:28:51: ISAKMP:received payload type 20
000543: *Mar 14 15:28:51: ISAKMP:(0:4:SW:1):Input = IKE_MESG_INTERNAL, IKE_PROCESS_MAIN_MODE
000544: *Mar 14 15:28:51: ISAKMP:(0:4:SW:1):Old State = IKE_R_MM3 New State = IKE_R_MM3
000545: *Mar 14 15:28:51: ISAKMP:(0:4:SW:1): sending packet to 199.x.x.x. my_port 500 peer_port 500 (R) MM_KEY_EXCH
000546: *Mar 14 15:28:51: ISAKMP:(0:4:SW:1):Input = IKE_MESG_INTERNAL, IKE_PROCESS_COMPLETE
000547: *Mar 14 15:28:51: ISAKMP:(0:4:SW:1):Old State = IKE_R_MM3 New State = IKE_R_MM4
000548: *Mar 14 15:28:51: ISAKMP (0:134217732): received packet from 199.xx..x.x dport 4500 sport 4500 Global (R) MM_KEY_EXCH
000549: *Mar 14 15:28:51: ISAKMP:(0:4:SW:1):Input = IKE_MESG_FROM_PEER, IKE_MM_EXCH
000550: *Mar 14 15:28:51: ISAKMP:(0:4:SW:1):Old State = IKE_R_MM4 New State = IKE_R_MM5
000551: *Mar 14 15:28:51: ISAKMP:(0:4:SW:1): processing ID payload. message ID = 0
000552: *Mar 14 15:28:51: ISAKMP (0:134217732): ID payload
next-payload : 8
type : 1
address : 199.x.x.x
protocol : 17
port : 0
length : 12
000553: *Mar 14 15:28:51: ISAKMP:(0:4:SW:1):: peer matches *none* of the profiles
000554: *Mar 14 15:28:51: ISAKMP:(0:4:SW:1): processing HASH payload. message ID = 0
000555: *Mar 14 15:28:51: ISAKMP:received payload type 17
000556: *Mar 14 15:28:51: ISAKMP:(0:4:SW:1): processing vendor id payload
000557: *Mar 14 15:28:51: ISAKMP:(0:4:SW:1): vendor ID is DPD
000558: *Mar 14 15:28:51: ISAKMP:(0:4:SW:1):SA authentication status: authenticated
000559: *Mar 14 15:28:51: ISAKMP:(0:4:SW:1):SA has been authenticated with 199.x.x.x
000560: *Mar 14 15:28:51: ISAKMP:(0:4:SW:1):Detected port floating to port = 4500
000561: *Mar 14 15:28:51: ISAKMP: Trying to insert a peer 10.1.10.185/199.x.x..x/4500/, and inserted successfully 640CB9E0.
000562: *Mar 14 15:28:51: ISAKMP:(0:4:SW:1):Setting UDP ENC peer struct 0x63EC9A58 sa= 0x64040BD8
000563: *Mar 14 15:28:51: ISAKMP:(0:4:SW:1):Input = IKE_MESG_INTERNAL, IKE_PROCESS_MAIN_MODE
000564: *Mar 14 15:28:51: ISAKMP:(0:4:SW:1):Old State = IKE_R_MM5 New State = IKE_R_MM5
000565: *Mar 14 15:28:51: ISAKMP:(0:4:SW:1):SA is doing pre-shared key authentication using id type ID_IPV4_ADDR
000566: *Mar 14 15:28:51: ISAKMP (0:134217732): ID payload
next-payload : 8
type : 1
address : 10.1.10.185
protocol : 17
port : 0
length : 12
000567: *Mar 14 15:28:51: ISAKMP:(0:4:SW:1):Total payload length: 12
000568: *Mar 14 15:28:51: ISAKMP:(0:4:SW:1): sending packet to 199.x.x.x my_port 4500 peer_port 4500 (R) MM_KEY_EXCH
000569: *Mar 14 15:28:51: ISAKMP:(0:4:SW:1):Input = IKE_MESG_INTERNAL, IKE_PROCESS_COMPLETE
000570: *Mar 14 15:28:51: ISAKMP:(0:4:SW:1):Old State = IKE_R_MM5 New State = IKE_P1_COMPLETE
000571: *Mar 14 15:28:51: ISAKMP:(0:4:SW:1):Input = IKE_MESG_INTERNAL, IKE_PHASE1_COMPLETE
000572: *Mar 14 15:28:51: ISAKMP:(0:4:SW:1):Old State = IKE_P1_COMPLETE New State = IKE_P1_COMPLETE
000573: *Mar 14 15:28:51: ISAKMP (0:134217732): received packet from 199.x.x..x dport 4500 sport 4500 Global (R) QM_IDLE
000574: *Mar 14 15:28:51: ISAKMP: set new node 397879553 to QM_IDLE
000575: *Mar 14 15:28:51: ISAKMP:(0:4:SW:1): processing HASH payload. message ID = 397879553
000576: *Mar 14 15:28:51: ISAKMP:(0:4:SW:1): processing DELETE payload. messageID = 397879553
000577: *Mar 14 15:28:51: ISAKMP:(0:4:SW:1):peer does not do paranoid keepalives.
000578: *Mar 14 15:28:51: ISAKMP:(0:4:SW:1):deleting SA reason "No reason" state (R) QM_IDLE (peer 199.x.x.x)
000579: *Mar 14 15:28:51: ISAKMP:(0:4:SW:1):deleting node 397879553 error FALSEreason "Informational (in) state 1"
000580: *Mar 14 15:28:51: ISAKMP:(0:4:SW:1):Input = IKE_MESG_INTERNAL, IKE_PHASE1_DEL
000581: *Mar 14 15:28:51: ISAKMP:(0:4:SW:1):Old State = IKE_P1_COMPLETE New State = IKE_DEST_SA
000582: *Mar 14 15:28:51: ISAKMP:(0:4:SW:1):deleting SA reason "No reason" state (R) QM_IDLE (peer 199.x.x.x)
000583: *Mar 14 15:28:51: ISAKMP: Unlocking IKE struct 0x640CB9E0 for isadb_mark_sa_deleted(), count 0
000584: *Mar 14 15:28:51: ISAKMP: Deleting peer node by peer_reap for 199.x.x.x.x: 640CB9E0
000585: *Mar 14 15:28:51: ISAKMP:(0:4:SW:1):deleting node 397879553 error FALSEreason "IKE deleted"
000586: *Mar 14 15:28:51: ISAKMP:(0:4:SW:1):Input = IKE_MESG_FROM_PEER, IKE_MM_EXCH
000587: *Mar 14 15:28:51: ISAKMP:(0:4:SW:1):Old State = IKE_DEST_SA New State = IKE_DEST_SA
03-15-2013 11:41 AM
Phase 1 seems to complete just fine.
Can you share the config from both ends? Maybe remote end has changed something perhaps?
03-15-2013 12:20 PM
ASA Side
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
interface Vlan1
nameif inside
security-level 100
ip address 192.168.100.1 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address 199.x.x.x 255.255.255.248
ftp mode passive
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
object network obj_any
subnet 0.0.0.0 0.0.0.0
object network Data
subnet 192.168.2.0 255.255.255.0
object network voice
subnet 192.168.4.0 255.255.255.0
object network NETWORK_OBJ_192.168.100.0_24
subnet 192.168.100.0 255.255.255.0
object network WebServer
host 192.168.100.100
description Web Server - HTTP
object network webserver
description webserver https
object network WebAddr
host 199.x.x.x
object-group network DM_INLINE_NETWORK_1
network-object object Data
network-object object voice
object-group network DM_INLINE_NETWORK_2
object-group network DM_INLINE_NETWORK_3
object-group service DM_INLINE_TCP_1 tcp
port-object eq www
port-object eq https
access-list outside_cryptomap extended permit ip 192.168.100.0 255.255.255.0 object-group DM_INLINE_NETWORK_1
access-list outside_cryptomap_1 extended permit ip object NETWORK_OBJ_192.168.100.0_24 object-group DM_INLINE_NETWORK_2
access-list DefaultRAGroup_splitTunnelAcl standard permit 192.168.100.0 255.255.255.0
access-list tcp_bypass remark async routing exception. also need one for return
access-list tcp_bypass extended permit tcp object Data any
access-list asyc_return extended permit tcp any host 192.168.100.100 object-group DM_INLINE_TCP_1
access-list asyc_return remark async routing exception for returning traffic
access-list asyc_return extended permit ip 192.168.2.0 255.255.255.0 any
pager lines 24
logging enable
logging asdm informational
logging host inside 192.168.2.33 6/1470
mtu inside 1500
mtu outside 1500
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
no arp permit-nonconnected
nat (inside,outside) source static NETWORK_OBJ_192.168.100.0_24 NETWORK_OBJ_192.168.100.0_24 destination static DM_INLINE_NETWORK_3 DM_INLINE_NETWORK_3 no-proxy-arp route-lookup
nat (inside,inside) source dynamic any interface
nat (inside,outside) dynamic interface
nat (inside,outside) static WebAddr service tcp www www
nat (inside,outside) static WebAddr service tcp https https
nat (inside,outside) after-auto source dynamic any interface
access-group asyc_return in interface outside
route outside 0.0.0.0 0.0.0.0 199.x.x.x.x
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
user-identity default-domain LOCAL
aaa authentication enable console LOCAL
aaa authentication http console LOCAL
aaa authorization command LOCAL
http server enable
http 0.0.0.0 0.0.0.0 inside
snmp-server host inside 192.168.2.0 community public
snmp-server location CoLo
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart warmstart
crypto ipsec ikev1 transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-128-SHA-TRANS esp-aes esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-128-SHA-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-AES-128-MD5-TRANS esp-aes esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-128-MD5-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-AES-192-SHA-TRANS esp-aes-192 esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-192-SHA-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-AES-192-MD5-TRANS esp-aes-192 esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-192-MD5-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-AES-256-SHA-TRANS esp-aes-256 esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-256-SHA-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-AES-256-MD5-TRANS esp-aes-256 esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-256-MD5-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-3DES-SHA-TRANS esp-3des esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-3DES-SHA-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-3DES-MD5-TRANS esp-3des esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-3DES-MD5-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-DES-SHA-TRANS esp-des esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-DES-SHA-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-DES-MD5-TRANS esp-des esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-DES-MD5-TRANS mode transport
crypto ipsec ikev1 transform-set NRM esp-3des esp-md5-hmac
crypto ipsec ikev1 transform-set NRM2 esp-3des esp-md5-hmac
crypto ipsec ikev1 transform-set NRM2 mode transport
crypto ipsec ikev2 ipsec-proposal DES
protocol esp encryption des
protocol esp integrity sha-1 md5
crypto ipsec ikev2 ipsec-proposal 3DES
protocol esp encryption 3des
crypto ipsec ikev2 ipsec-proposal AES
protocol esp encryption aes
crypto ipsec ikev2 ipsec-proposal AES192
protocol esp encryption aes-192
crypto ipsec ikev2 ipsec-proposal AES256
protocol esp encryption aes-256
crypto ipsec security-association pmtu-aging infinite
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set ikev1 transform-set ESP-AES-192-SHA ESP-AES-256-SHA ESP-3DES-SHA ESP-DES-SHA ESP-AES-128-SHA-TRANS ESP-AES-192-SHA-TRANS ESP-AES-256-SHA-TRANS ESP-3DES-SHA-TRANS ESP-DES-SHA-TRANS NRM NRM2
crypto map outside_map 1 match address outside_cryptomap_1
crypto map outside_map 1 set peer (PEER ADDR)
crypto map outside_map 1 set ikev1 transform-set ESP-AES-128-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto map outside_map 1 set ikev2 ipsec-proposal AES256 AES192 AES 3DES DES
crypto map outside_map 1 set ikev2 pre-shared-key null
crypto map outside_map 65535 ipsec-isakmp dynamic SYSTEM_DEFAULT_CRYPTO_MAP
crypto map outside_map interface outside
crypto ca trustpoint _SmartCallHome_ServerCA
crl configure
crypto ca trustpool policy
crypto ca certificate chain _SmartCallHome_ServerCA
certificate ca 6ecc7aa5a7032009b8cebcf4e952d491
308205ec 308204d4 a0030201 0202106e cc7aa5a7 032009b8 cebcf4e9 52d49130
0d06092a 864886f7 0d010105 05003081 ca310b30 09060355 04061302 55533117
30150603 55040a13 0e566572 69536967 6e2c2049 6e632e31 1f301d06 0355040b
13165665 72695369 676e2054 72757374 204e6574 776f726b 313a3038 06035504
0b133128 63292032 30303620 56657269 5369676e 2c20496e 632e202d 20466f72
20617574 686f7269 7a656420 75736520 6f6e6c79 31453043 06035504 03133c56
65726953 69676e20 436c6173 73203320 5075626c 69632050 72696d61 72792043
65727469 66696361 74696f6e 20417574 686f7269 7479202d 20473530 1e170d31
30303230 38303030 3030305a 170d3230 30323037 32333539 35395a30 81b5310b
30090603 55040613 02555331 17301506 0355040a 130e5665 72695369 676e2c20
496e632e 311f301d 06035504 0b131656 65726953 69676e20 54727573 74204e65
74776f72 6b313b30 39060355 040b1332 5465726d 73206f66 20757365 20617420
68747470 733a2f2f 7777772e 76657269 7369676e 2e636f6d 2f727061 20286329
3130312f 302d0603 55040313 26566572 69536967 6e20436c 61737320 33205365
63757265 20536572 76657220 4341202d 20473330 82012230 0d06092a 864886f7
0d010101 05000382 010f0030 82010a02 82010100 b187841f c20c45f5 bcab2597
a7ada23e 9cbaf6c1 39b88bca c2ac56c6 e5bb658e 444f4dce 6fed094a d4af4e10
9c688b2e 957b899b 13cae234 34c1f35b f3497b62 83488174 d188786c 0253f9bc
7f432657 5833833b 330a17b0 d04e9124 ad867d64 12dc744a 34a11d0a ea961d0b
15fca34b 3bce6388 d0f82d0c 948610ca b69a3dca eb379c00 48358629 5078e845
63cd1941 4ff595ec 7b98d4c4 71b350be 28b38fa0 b9539cf5 ca2c23a9 fd1406e8
18b49ae8 3c6e81fd e4cd3536 b351d369 ec12ba56 6e6f9b57 c58b14e7 0ec79ced
4a546ac9 4dc5bf11 b1ae1c67 81cb4455 33997f24 9b3f5345 7f861af3 3cfa6d7f
81f5b84a d3f58537 1cb5a6d0 09e4187b 384efa0f 02030100 01a38201 df308201
db303406 082b0601 05050701 01042830 26302406 082b0601 05050730 01861868
7474703a 2f2f6f63 73702e76 65726973 69676e2e 636f6d30 12060355 1d130101
ff040830 060101ff 02010030 70060355 1d200469 30673065 060b6086 480186f8
45010717 03305630 2806082b 06010505 07020116 1c687474 70733a2f 2f777777
2e766572 69736967 6e2e636f 6d2f6370 73302a06 082b0601 05050702 02301e1a
1c687474 70733a2f 2f777777 2e766572 69736967 6e2e636f 6d2f7270 61303406
03551d1f 042d302b 3029a027 a0258623 68747470 3a2f2f63 726c2e76 65726973
69676e2e 636f6d2f 70636133 2d67352e 63726c30 0e060355 1d0f0101 ff040403
02010630 6d06082b 06010505 07010c04 61305fa1 5da05b30 59305730 55160969
6d616765 2f676966 3021301f 30070605 2b0e0302 1a04148f e5d31a86 ac8d8e6b
c3cf806a d448182c 7b192e30 25162368 7474703a 2f2f6c6f 676f2e76 65726973
69676e2e 636f6d2f 76736c6f 676f2e67 69663028 0603551d 11042130 1fa41d30
1b311930 17060355 04031310 56657269 5369676e 4d504b49 2d322d36 301d0603
551d0e04 1604140d 445c1653 44c1827e 1d20ab25 f40163d8 be79a530 1f060355
1d230418 30168014 7fd365a7 c2ddecbb f03009f3 4339fa02 af333133 300d0609
2a864886 f70d0101 05050003 82010100 0c8324ef ddc30cd9 589cfe36 b6eb8a80
4bd1a3f7 9df3cc53 ef829ea3 a1e697c1 589d756c e01d1b4c fad1c12d 05c0ea6e
b2227055 d9203340 3307c265 83fa8f43 379bea0e 9a6c70ee f69c803b d937f47a
6decd018 7d494aca 99c71928 a2bed877 24f78526 866d8705 404167d1 273aeddc
481d22cd 0b0b8bbc f4b17bfd b499a8e9 762ae11a 2d876e74 d388dd1e 22c6df16
b62b8214 0a945cf2 50ecafce ff62370d ad65d306 4153ed02 14c8b558 28a1ace0
5becb37f 954afb03 c8ad26db e6667812 4ad99f42 fbe198e6 42839b8f 8f6724e8
6119b5dd cdb50b26 058ec36e c4c875b8 46cfe218 065ea9ae a8819a47 16de0c28
6c2527b9 deb78458 c61f381e a4c4cb66
quit
crypto ikev2 policy 1
encryption aes-256
integrity sha
group 5 2
prf sha
lifetime seconds 86400
crypto ikev2 policy 10
encryption aes-192
integrity sha
group 5 2
prf sha
crypto ikev2 policy 20
encryption aes
integrity sha
group 5 2
prf sha
crypto ikev2 policy 30
encryption 3des
integrity sha
group 5 2
prf sha
crypto ikev2 policy 40
encryption des
integrity sha
group 5 2
prf sha
crypto ikev2 enable inside
crypto ikev2 enable outside
crypto ikev1 enable inside
crypto ikev1 enable outside
crypto ikev1 policy 10
authentication crack
encryption aes-256
hash sha
group 2
lifetime 86400
crypto ikev1 policy 20
authentication rsa-sig
encryption aes-256
hash sha
group 2
lifetime 86400
crypto ikev1 policy 30
authentication pre-share
encryption aes-256
hash sha
group 2
lifetime 86400
crypto ikev1 policy 40
encryption aes-192
hash sha
group 2
lifetime 86400
crypto ikev1 policy 50
encryption aes-192
hash sha
group 2
lifetime 86400
crypto ikev1 policy 60
encryption aes-192
hash sha
group 2
lifetime 86400
crypto ikev1 policy 70
encryption aes
hash sha
group 2
lifetime 86400
crypto ikev1 policy 80
encryption aes
hash sha
group 2
lifetime 86400
crypto ikev1 policy 90
encryption aes
hash sha
group 2
lifetime 86400
crypto ikev1 policy 100
encryption 3des
hash sha
group 2
lifetime 86400
crypto ikev1 policy 110
encryption 3des
hash sha
group 2
lifetime 86400
crypto ikev1 policy 120
encryption 3des
hash sha
group 2
lifetime 86400
crypto ikev1 policy 130
encryption des
hash sha
group 2
lifetime 86400
crypto ikev1 policy 140
encryption des
hash sha
group 2
lifetime 86400
crypto ikev1 policy 150
encryption des
hash sha
group 2
lifetime 86400
telnet timeout 5
ssh timeout 5
console timeout 0
management-access inside
dhcpd dns xxx
dhcpd domain xxx
dhcpd auto_config outside vpnclient-wins-override
dhcpd address 192.168.100.5-192.168.100.36 inside
dhcpd auto_config outside interface inside
dhcpd enable inside
threat-detection basic-threat
threat-detection scanning-threat shun
threat-detection statistics host number-of-rate 2
threat-detection statistics port
threat-detection statistics protocol
threat-detection statistics access-list
threat-detection statistics tcp-intercept rate-interval 30 burst-rate 400 average-rate 200
group-policy DefaultRAGroup internal
group-policy DefaultRAGroup attributes
dns-server valuexxx
vpn-tunnel-protocol l2tp-ipsec
split-tunnel-policy tunnelspecified
split-tunnel-network-list value DefaultRAGroup_splitTunnelAcl
default-domain value messicks.local
group-policy GroupPolicy2 internal
group-policy GroupPolicy1 internal
group-policy GroupPolicy_xxx internal
group-policy GroupPolicy_xxx attributes
vpn-tunnel-protocol ikev1 ikev2
username talon55 password c7KAH6h/ZbKJwDFs encrypted privilege 15
username coloitaly password HDK4AgaFqEl9MeWAhIfXAg== nt-encrypted
username coloitaly attributes
service-type remote-access
tunnel-group DefaultRAGroup general-attributes
address-pool vpnpool
tunnel-group DefaultRAGroup ipsec-attributes
ikev1 pre-shared-key colo$45050
tunnel-group DefaultRAGroup ppp-attributes
authentication ms-chap-v2
tunnel-group xxx type ipsec-l2l
tunnel-group xxx general-attributes
default-group-policy GroupPolicy_xxx
tunnel-group xxx ipsec-attributes
ikev1 pre-shared-key XXX
ikev2 remote-authentication pre-shared-key XXX
ikev2 local-authentication pre-shared-key XXX
class-map inspection_default
match default-inspection-traffic
class-map tcp_bypass
match access-list tcp_bypass
policy-map type inspect dns preset_dns_map
parameters
message-length maximum client auto
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
inspect ip-options
policy-map tcp_bypass_policy
class tcp_bypass
set connection timeout idle 0:10:00
set connection advanced-options tcp-state-bypass
service-policy global_policy global
service-policy tcp_bypass_policy interface outside
prompt hostname context
call-home reporting anonymous
hpm topN enable
03-15-2013 12:42 PM
Router Side. Its a mess, there is 7-8 years of old config on here. alot is not used.
remeber, this worked great for 5-6 days before things just stopped.
Building configuration...
Current configuration : 27258 bytes
version 12.4
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime
service timestamps log datetime
service password-encryption
service sequence-numbers
hostname E-town
boot-start-marker
boot-end-marker
security authentication failure rate 3 log
security passwords min-length 6
no logging buffered
logging console critical
enable secret 5 $1$jruL$Hthzgqf5irNb3uqgzCXB30
aaa new-model
aaa authentication login default local
aaa authorization exec default local
aaa session-id common
resource policy
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip subnet-zero
no ip source-route
ip cef
ip inspect max-incomplete high 900
ip inspect max-incomplete low 800
ip inspect one-minute high 900
ip inspect one-minute low 800
ip inspect name SDM_LOW icmp
ip inspect name SDM_LOW rcmd
ip inspect name SDM_LOW ntp
ip inspect name SDM_LOW ftp
ip inspect name SDM_LOW tftp
ip inspect name SDM_LOW ftps
ip inspect name SDM_LOW tcp alert on audit-trail off
ip inspect name SDM_LOW udp alert on audit-trail off
ip ips sdf location flash://128MB.sdf
ip ips notify SDEE
no ip bootp server
ip name-server 205.160.192.2
ip name-server 192.168.2.5
crypto pki trustpoint TP-self-signed-1438219780
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1438219780
revocation-check none
rsakeypair TP-self-signed-1438219780
crypto pki trustpoint tti
revocation-check crl
rsakeypair tti
crypto pki certificate chain tti
username administrator privilege 15 secret 5 $1$Isbo$u5PsZYMwh0rYzlZ1TRO.8.
class-map match-any colo
description colo bandwidth limit
match access-group 150
class-map match-all webqos
match access-group 110
class-map match-any voice-signaling
match ip dscp cs3
match ip dscp af31
match ip dscp af41
class-map match-all tcp_traffic
match ip dscp ef
match ip precedence 5
policy-map WebQOS
class tcp_traffic
police 150000 280000
policy-map voice-qos
class voice
priority percent 20
class voice-signaling
bandwidth percent 5
class class-default
fair-queue
crypto isakmp policy 1
encr 3des
group 2
crypto isakmp key xxx address 174.x.x.x
crypto isakmp key xxx address 199.x.x.x.x
crypto isakmp key xxx address 24..x.x.x
crypto isakmp key xxx address 0.0.0.0 0.0.0.0 no-xauth
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec transform-set ESP-3DES-SHA1 esp-3des esp-sha-hmac
crypto ipsec transform-set ESP-3DES-SHA2 esp-3des esp-sha-hmac
crypto ipsec transform-set ESP-3DES-SHA3 esp-3des esp-sha-hmac
crypto ipsec transform-set ESP-3DES-SHA4 esp-3des esp-sha-hmac
crypto ipsec transform-set ESP-3DES-SHA5 esp-3des esp-sha-hmac
crypto ipsec transform-set ESP-3DES-SHA6 esp-3des esp-sha-hmac
crypto ipsec transform-set NRM esp-3des esp-sha-hmac
crypto ipsec transform-set ESP-3DES-SHA7 esp-3des esp-sha-hmac
crypto ipsec transform-set ESP-3DES-SHA8 esp-3des esp-sha-hmac
crypto ipsec df-bit clear
crypto ipsec profile nrm
set transform-set ESP-3DES-SHA6 ESP-3DES-SHA5 ESP-3DES-SHA
crypto dynamic-map SDM_DYNMAP_1 10
set transform-set ESP-3DES-SHA1
match address 112
reverse-route
crypto dynamic-map SDM_DYNMAP_1 11
match address 114
reverse-route
crypto dynamic-map SDM_DYNMAP_1 12
match address 116
reverse-route
crypto dynamic-map SDM_DYNMAP_1 14
set transform-set ESP-3DES-SHA7
match address 118
reverse-route
crypto map SDM_CMAP_1 1 ipsec-isakmp
description Tunnel to199.x.x.x.x
set peer 199.x.x.x.x
set transform-set ESP-3DES-SHA8
match address VPNACL
crypto map SDM_CMAP_1 65535 ipsec-isakmp dynamic SDM_DYNMAP_1
interface Null0
no ip unreachables
interface FastEthernet0/0
description "Data Subnet"
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip flow egress
ip route-cache flow
duplex auto
speed auto
no mop enabled
interface FastEthernet0/0.1
n/a
interface FastEthernet0/0.2
n/a
interface FastEthernet0/0.3
n/a
interface FastEthernet0/1
description Internet$FW_OUTSIDE$$ETH-LAN$
ip address 10.1.10.185 255.255.255.0
ip verify unicast reverse-path
no ip redirects
no ip unreachables
no ip proxy-arp
ip nbar protocol-discovery
ip inspect SDM_LOW in
ip inspect SDM_LOW out
ip flow ingress
ip flow egress
ip nat outside
ip virtual-reassembly
ip route-cache flow
duplex auto
speed auto
no mop enabled
interface Serial0/0/0
not used
ip classless
ip route 0.0.0.0 0.0.0.0 10.1.10.1
ip route 63.156.56.48 255.255.255.252 {MPLS router}
ip route 63.156.56.52 255.255.255.252 {MPLS router}
ip route 63.156.56.56 255.255.255.252 {MPLS router}
ip route 63.156.56.60 255.255.255.252 {MPLS router}
ip route 64.73.117.34 255.255.255.255 1.1.1.1
ip route 172.20.94.212 255.255.255.252 172.20.94.29
ip route 192.168.1.0 255.255.255.0 {MPLS router}
ip route 192.168.3.0 255.255.255.0 {MPLS router}
ip route 192.168.4.0 255.255.255.0 {MPLS router}
ip route 192.168.5.0 255.255.255.0 192.168.2.7
ip route 192.168.6.0 255.255.255.0 {MPLS router}
ip route 192.168.7.0 255.255.255.0 {MPLS router}
ip route 192.168.8.0 255.255.255.0 {MPLS router}
ip route 192.168.9.0 255.255.255.0 {MPLS router}
ip route 192.168.10.0 255.255.255.0 {MPLS router}
ip route 192.168.11.0 255.255.255.0 {MPLS router}
ip flow-top-talkers
top 50
sort-by bytes
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 600 life 86400 requests 10000
ip nat inside source route-map SDM_RMAP_2 interface FastEthernet0/1 overload
ip access-list extended VPNACL
remark SDM_ACL Category=20
permit ip 192.168.4.0 0.0.0.255 192.168.100.0 0.0.0.255
permit ip 192.168.2.0 0.0.0.255 192.168.100.0 0.0.0.255
logging 192.168.2.33
access-list 1 remark SDM_ACL Category=2
access-list 1 permit 192.168.4.0 0.0.0.255
access-list 1 permit 192.168.200.0 0.0.0.3
access-list 2 remark SDM_ACL Category=2
access-list 2 permit 192.168.2.0 0.0.0.255
access-list 2 permit 192.168.4.0 0.0.0.255
access-list 2 permit 192.168.200.0 0.0.0.3
access-list 2 remark a-town
access-list 2 permit 192.168.1.0 0.0.0.255
access-list 2 permit 192.168.3.0 0.0.0.255
access-list 100 remark auto generated by SDM firewall configuration
access-list 100 remark SDM_ACL Category=1
access-list 100 permit ip any any
access-list 101 remark auto generated by SDM firewall configuration
access-list 101 remark SDM_ACL Category=1
access-list 101 deny ip 192.168.200.0 0.0.0.3 any
access-list 101 deny ip 192.168.2.0 0.0.0.255 any
access-list 101 deny ip xxx 0.0.0.7 any
access-list 101 deny ip host 255.255.255.255 any
access-list 101 deny ip 127.0.0.0 0.255.255.255 any
access-list 101 permit ip any any
access-list 102 remark auto generated by SDM firewall configuration
access-list 102 remark SDM_ACL Category=1
access-list 102 deny ip 192.168.4.0 0.0.0.255 any
access-list 102 deny ip 192.168.2.0 0.0.0.255 any
access-list 102 deny ip xxx 0.0.0.7 any
access-list 102 deny ip host 255.255.255.255 any
access-list 102 deny ip 127.0.0.0 0.255.255.255 any
access-list 102 permit ip any any
access-list 103 remark auto generated by SDM firewall configuration
access-list 103 remark SDM_ACL Category=1
access-list 103 permit udp any host xx eq isakmp
access-list 103 permit tcp any host x.x.x.x eq 50
access-list 103 permit udp any host x.x.x.x eq non500-isakmp
access-list 103 permit tcp any host x.x.x.x eq 443
access-list 103 permit tcp any host x.x.x.x eq www
access-list 103 permit tcp any host x.x.x..73 eq 443
access-list 103 permit tcp any host x.x.x..73 eq www
access-list 103 permit tcp any host x.x.x..73 eq smtp
access-list 103 deny ip 192.168.200.0 0.0.0.3 any
access-list 103 deny ip 192.168.4.0 0.0.0.255 any
access-list 103 deny ip 192.168.2.0 0.0.0.255 any
access-list 103 permit udp any eq bootps any eq bootps
access-list 103 permit icmp any host x.x.x.x echo-reply
access-list 103 permit icmp any host x.x.x.x time-exceeded
access-list 103 permit icmp any host x.x.x.x unreachable
access-list 103 deny ip 10.0.0.0 0.255.255.255 any
access-list 103 deny ip 172.16.0.0 0.15.255.255 any
access-list 103 deny ip 192.168.0.0 0.0.255.255 any
access-list 103 deny ip 127.0.0.0 0.255.255.255 any
access-list 103 deny ip host 255.255.255.255 any
access-list 103 deny ip host 0.0.0.0 any
access-list 103 deny ip any any log
access-list 104 remark auto generated by SDM firewall configuration
access-list 104 remark SDM_ACL Category=1
access-list 104 permit udp any host 192.168.2.200 eq non500-isakmp
access-list 104 permit udp any host 192.168.2.200 eq isakmp
access-list 104 permit esp any host 192.168.2.200
access-list 104 permit ahp any host 192.168.2.200
access-list 104 permit gre any host 192.168.2.200
access-list 104 deny ip 192.168.200.0 0.0.0.3 any
access-list 104 deny ip 192.168.4.0 0.0.0.255 any
access-list 104 deny ip x.x.x..72 0.0.0.7 any
access-list 104 deny ip host 255.255.255.255 any
access-list 104 deny ip 127.0.0.0 0.255.255.255 any
access-list 104 permit ip any any
access-list 105 remark auto generated by SDM firewall configuration
access-list 105 remark SDM_ACL Category=1
access-list 105 permit gre any host 192.168.2.200
access-list 105 permit ahp any host 192.168.2.200
access-list 105 permit esp any host 192.168.2.200
access-list 105 permit udp any host 192.168.2.200 eq isakmp
access-list 105 permit udp any host 192.168.2.200 eq non500-isakmp
access-list 105 deny ip 192.168.200.0 0.0.0.3 any
access-list 105 deny ip 192.168.2.0 0.0.0.255 any
access-list 105 deny ip x.x.x..72 0.0.0.7 any
access-list 105 deny ip host 255.255.255.255 any
access-list 105 deny ip 127.0.0.0 0.255.255.255 any
access-list 105 permit ip any any
access-list 106 remark auto generated by SDM firewall configuration
access-list 106 remark SDM_ACL Category=1
access-list 106 permit tcp any host x.x.x..76 eq ftp-data
access-list 106 remark Keivn Warrenty
access-list 106 permit ip host 129.35.117.246 any
access-list 106 remark search appliance
access-list 106 permit tcp any host x.x.x..76 eq www
access-list 106 remark AS400 FTP
access-list 106 permit tcp any host x.x.x.x eq 1723
access-list 106 remark VPN Port
access-list 106 permit gre any host x.x.x.x log
access-list 106 permit udp any host x.x.x.x eq isakmp
access-list 106 permit tcp any host x.x.x.x eq 50
access-list 106 permit udp any host x.x.x.x eq non500-isakmp
access-list 106 permit tcp any host x.x.x.x eq 443
access-list 106 permit tcp any host x.x.x.x eq www
access-list 106 permit tcp any host x.x.x..73 eq 443
access-list 106 permit tcp any host x.x.x..73 eq www
access-list 106 permit tcp any host x.x.x..73 eq smtp
access-list 106 permit udp host 205.160.192.2 eq domain host x.x.x.x
access-list 106 deny ip 192.168.200.0 0.0.0.3 any
access-list 106 deny ip 192.168.4.0 0.0.0.255 any
access-list 106 deny ip 192.168.2.0 0.0.0.255 any
access-list 106 permit udp any eq bootps any eq bootps
access-list 106 permit icmp any host x.x.x.x echo-reply
access-list 106 permit icmp any host x.x.x.x time-exceeded
access-list 106 permit icmp any host x.x.x.x unreachable
access-list 106 deny ip 10.0.0.0 0.255.255.255 any
access-list 106 deny ip 172.16.0.0 0.15.255.255 any
access-list 106 deny ip 192.168.0.0 0.0.255.255 any
access-list 106 deny ip 127.0.0.0 0.255.255.255 any
access-list 106 deny ip host 255.255.255.255 any
access-list 106 deny ip host 0.0.0.0 any
access-list 106 deny ip any any log
access-list 107 remark auto generated by SDM firewall configuration
access-list 107 remark SDM_ACL Category=1
access-list 107 deny ip 192.168.200.0 0.0.0.3 any
access-list 107 deny ip 192.168.4.0 0.0.0.255 any
access-list 107 deny ip xxx 0.0.0.7 any
access-list 107 deny ip host 255.255.255.255 any
access-list 107 deny ip 127.0.0.0 0.255.255.255 any
access-list 107 permit ip any any
access-list 108 permit ip any any
access-list 109 remark SDM_ACL Category=2
access-list 109 remark IPSec Rule
access-list 109 deny ip 192.168.2.0 0.0.0.255 192.168.100.0 0.0.0.255
access-list 109 deny ip 192.168.2.0 0.0.0.255 192.168.2.0 0.0.0.255
access-list 109 deny ip 10.1.10.0 0.0.0.255 host 174.59.111.20
access-list 109 deny ip any any
access-list 109 deny ip 192.168.2.0 0.0.0.255 host 192.168.2.120
access-list 109 deny ip 192.168.2.0 0.0.0.255 192.168.10.0 0.0.0.255
access-list 109 deny ip 192.168.10.0 0.0.0.255 10.1.10.0 0.0.0.255
access-list 109 permit ip 192.168.3.0 0.0.0.255 any
access-list 109 remark a-town
access-list 109 permit ip 192.168.1.0 0.0.0.255 any
access-list 109 permit ip 192.168.200.0 0.0.0.3 any
access-list 109 permit ip 192.168.4.0 0.0.0.255 any
access-list 109 permit ip 192.168.2.0 0.0.0.255 any
access-list 110 remark WebQOSacl
access-list 110 remark SDM_ACL Category=1
access-list 110 permit icmp any any
access-list 110 permit udp any any
access-list 110 permit tcp any any
access-list 110 permit ip any any
access-list 111 remark CCP_ACL Category=2
access-list 111 remark SDM_ACL Category=18
access-list 111 deny ip 192.168.2.0 0.0.0.255 192.168.230.0 0.0.0.255
access-list 111 deny ip 192.168.4.0 0.0.0.255 192.168.6.0 0.0.0.255
access-list 111 deny ip 192.168.3.0 0.0.0.255 192.168.6.0 0.0.0.255
access-list 111 deny ip 192.168.1.0 0.0.0.255 192.168.6.0 0.0.0.255
access-list 111 deny ip 192.168.2.0 0.0.0.255 192.168.6.0 0.0.0.255
access-list 111 deny ip 192.168.2.0 0.0.0.255 192.168.101.0 0.0.0.255
access-list 111 remark IPSec Rule
access-list 111 deny ip 192.168.4.0 0.0.0.255 192.168.101.0 0.0.0.255
access-list 111 remark voice
access-list 111 deny ip 192.168.4.0 0.0.0.255 192.168.103.0 0.0.0.255
access-list 111 deny ip 192.168.2.0 0.0.0.255 192.168.103.0 0.0.0.255
access-list 111 deny ip 192.168.4.0 0.0.0.255 192.168.102.0 0.0.0.255
access-list 111 deny ip 192.168.2.0 0.0.0.255 192.168.102.0 0.0.0.255
access-list 111 deny ip 192.168.2.0 0.0.0.255 192.168.100.0 0.0.0.255
access-list 111 deny ip 192.168.4.0 0.0.0.255 192.168.100.0 0.0.0.255
access-list 111 deny ip 192.168.2.0 0.0.0.255 192.168.2.0 0.0.0.255
access-list 111 deny ip 192.168.4.0 0.0.0.255 192.168.104.0 0.0.0.255
access-list 111 deny ip 192.168.2.0 0.0.0.255 192.168.104.0 0.0.0.255
access-list 111 deny ip 10.1.10.0 0.0.0.255 host xxx
access-list 111 permit ip 192.168.3.0 0.0.0.255 any
access-list 111 remark a-town
access-list 111 permit ip 192.168.1.0 0.0.0.255 any
access-list 111 permit ip 192.168.4.0 0.0.0.255 any
access-list 111 permit ip 192.168.2.0 0.0.0.255 any
access-list 111 permit ip 192.168.22.0 0.0.0.255 any
access-list 111 permit ip 192.168.222.0 0.0.0.255 any
access-list 112 remark SDM_ACL Category=4
access-list 112 remark IPSec Rule
access-list 112 permit ip 192.168.2.0 0.0.0.255 192.168.102.0 0.0.0.255
access-list 112 permit ip 192.168.4.0 0.0.0.255 192.168.102.0 0.0.0.255
access-list 114 remark CCP_ACL Category=4
access-list 114 remark IPSec Rule
access-list 114 permit ip 192.168.2.0 0.0.0.255 192.168.103.0 0.0.0.255
access-list 114 permit ip 192.168.4.0 0.0.0.255 192.168.103.0 0.0.0.255
access-list 116 remark NRM 101
access-list 116 remark CCP_ACL Category=4
access-list 116 permit ip 192.168.2.0 0.0.0.255 192.168.101.0 0.0.0.255
access-list 116 permit ip 192.168.4.0 0.0.0.255 192.168.101.0 0.0.0.255
access-list 118 remark 192.168.104.0
access-list 118 remark SDM_ACL Category=4
access-list 118 permit ip 192.168.2.0 0.0.0.255 192.168.104.0 0.0.0.255
access-list 118 permit ip 192.168.4.0 0.0.0.255 192.168.104.0 0.0.0.255
access-list 120 deny ip any 192.168.0.0 0.0.255.255
access-list 120 permit ip any any
access-list 150 permit ip any any
access-list 150 permit ip any host 192.168.100.100
snmp-server community public RO
snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart
snmp-server enable traps vrrp
snmp-server enable traps ds1
snmp-server enable traps tty
snmp-server enable traps eigrp
snmp-server enable traps envmon
snmp-server enable traps flash insertion removal
snmp-server enable traps icsudsu
snmp-server enable traps isdn call-information
snmp-server enable traps isdn layer2
snmp-server enable traps isdn chan-not-avail
snmp-server enable traps isdn ietf
snmp-server enable traps ds0-busyout
snmp-server enable traps ds1-loopback
snmp-server enable traps cnpd
snmp-server enable traps config-copy
snmp-server enable traps entity
snmp-server enable traps event-manager
snmp-server enable traps frame-relay
snmp-server enable traps frame-relay subif
snmp-server enable traps hsrp
snmp-server enable traps ipmobile
snmp-server enable traps ipmulticast
snmp-server enable traps msdp
snmp-server enable traps mvpn
snmp-server enable traps ospf state-change
snmp-server enable traps ospf errors
snmp-server enable traps ospf retransmit
snmp-server enable traps ospf lsa
snmp-server enable traps ospf cisco-specific state-change nssa-trans-change
snmp-server enable traps ospf cisco-specific state-change shamlink interface-old
snmp-server enable traps ospf cisco-specific state-change shamlink neighbor
snmp-server enable traps ospf cisco-specific errors
snmp-server enable traps ospf cisco-specific retransmit
snmp-server enable traps ospf cisco-specific lsa
snmp-server enable traps pim neighbor-change rp-mapping-change invalid-pim-messa
ge
snmp-server enable traps pppoe
snmp-server enable traps cpu threshold
snmp-server enable traps rsvp
snmp-server enable traps syslog
snmp-server enable traps l2tun session
snmp-server enable traps vtp
snmp-server enable traps aaa_server
snmp-server enable traps atm subif
snmp-server enable traps isakmp policy add
snmp-server enable traps isakmp policy delete
snmp-server enable traps isakmp tunnel start
snmp-server enable traps isakmp tunnel stop
snmp-server enable traps ipsec cryptomap add
snmp-server enable traps ipsec cryptomap delete
snmp-server enable traps ipsec cryptomap attach
snmp-server enable traps ipsec cryptomap detach
snmp-server enable traps ipsec tunnel start
snmp-server enable traps ipsec tunnel stop
snmp-server enable traps ipsec too-many-sas
snmp-server enable traps rtr
snmp-server host 192.168.2.250 public
no cdp run
route-map SDM_RMAP_1 permit 1
match ip address 109
route-map SDM_RMAP_2 permit 1
match ip address 111
control-plane
line con 0
transport output telnet
line aux 0
line vty 0 4
exec-timeout 60 0
password 7 12140004015A5F5573
transport input telnet
scheduler allocate 4000 1000
end
03-15-2013 05:26 PM
On the ASA side you have lots of IPSec algorithm, and I would advise to just have 1 matching one to the router.
no crypto map outside_map 1 set ikev1 transform-set ESP-AES-128-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto map outside_map 1 set ikev1 transform-set ESP-3DES-SHA
Also, is it possible that the internet router might be blocking ESP? as base on the debugs, i don't see negotiation starts for phase 2 at all.
03-15-2013 06:29 PM
anything is possible. the ASA is in a colocation facility with raw internet, so a change is unlikly. If there are no other red flags, I guess thats where I'll start looking. A config change by the provider would explain why this suddenly stopped working. The router is working with 3-4 other ASA's just fine, so that provider should be okay.
You'd agree that debug crypto ipsec and debug crypto isakmp should give everything you need to see the tunnels comming up? Is there anyway to isolate the debugs for this tunnel from the others running on the same router?
03-16-2013 03:11 PM
yes, those debugs should give you anything you need if they are actually issue with the IPSec itself.
You can isolate the debugs just from one tunnel:
To turn the debug filter on:
debug condition ip
Then:
debug cry isa
debug cry ipsec
Once you have collected all the debug outputs, turn off all the debugs, and remember to remove the debug filter:
no debug condition ip
