Convert configuration of Juniper to Cisco Firewall
Jan 16th, 2013
Can somebody help me to convert the following config of Juniper router to cisco ASA
set interfaces ge-0/0/0 description xxxxxxxxxxx
set interfaces ge-0/0/0 vlan-tagging
set interfaces ge-0/0/0 mtu 4000
set interfaces ge-0/0/0 no-gratuitous-arp-request
set interfaces ge-0/0/0 unit 1 arp-resp unrestricted
set interfaces ge-0/0/0 unit 1 proxy-arp
set interfaces ge-0/0/0 unit 1 vlan-id 1
set interfaces ge-0/0/0 unit 1 family inet address X.X.X.X/25
set interfaces ge-0/0/0 unit 255 vlan-id 255
set interfaces ge-0/0/0 unit 255 family inet address X.X.X.X/30
set interfaces ge-0/0/1 description TUNNEL
set interfaces ge-0/0/1 vlan-tagging
set interfaces ge-0/0/1 mtu 4000
set interfaces ge-0/0/1 no-gratuitous-arp-request
set interfaces ge-0/0/1 unit 1 arp-resp restricted
set interfaces ge-0/0/1 unit 1 proxy-arp unrestricted
set interfaces ge-0/0/1 unit 1 vlan-id 1
set interfaces ge-0/0/1 unit 1 family inet address X.X.X.X/25
set interfaces ge-0/0/2 description to-xxxxxxxxxx
set interfaces ge-0/0/2 vlan-tagging
set interfaces ge-0/0/2 mtu 4000
set interfaces ge-0/0/2 unit 556 vlan-id 556
set interfaces ge-0/0/2 unit 556 family inet address X.X.X.X/30
set interfaces ge-0/0/2 unit 558 vlan-id 558
set interfaces ge-0/0/2 unit 558 family inet address X.X.X.X/30
set interfaces vlan unit 1 proxy-arp unrestricted
set routing-options static route X.X.X.X/32 next-hop X.X.X.X
set routing-options static route X.X.X.X/30 next-hop X.X.X.X
set routing-options static route 0.0.0.0/0 next-hop X.X.X.X
set protocols rip receive both
set protocols rip group xxxxxx neighbor ge-0/0/0.1
set policy-options policy-statement RIP-export term a from protocol direct
set policy-options policy-statement RIP-export term a from protocol rip
set policy-options policy-statement RIP-export term a then accept
Michal Garcarz Fri, 01/18/2013 - 03:22
  • Cisco Employee,
Disclaimer: there are many flavours of IOS, can not warrant that it will work for every possible software version.
For the fist interface:
no ip gratuitous-arps
int g0/0
switchport trunk encapsulation dot
switchport mode trunk
switchport trunk allowed vlan 1,255
int vlan 1
ip proxy-arp
ip address X.X.X.X/25
int vlan 255
ip proxy-arp
ip address X.X.X.X/30
#repeat the same for next interfaces/vlans
For first routing entry (
set routing-options static route X.X.X.X/32 next-hop Y.Y.Y.Y)
ip route X.X.X.0 255.255.255.0 Y.Y.Y.Y
For RIP:
router rip
passive-interface default
no passive-interface gig0/0
For routing leakage: i do not see the rest of the config, but you can control what routes to accept using
router rip
distribute-list 100 in     #ACL number 100 decides which routes to accept.
Michal
ahmedzniti Thu, 03/14/2013 - 15:13
hello
what's the mean of the following command and what's the equivalent on cisco
unit 1 proxy-arp
the problem if we activate the proxy arp on asa cisco 5525 X didnt work and i note that the proxy arp is enabled by default
below all juniper configuration
set interfaces ge-0/0/0 description Test
set interfaces ge-0/0/0 unit 1 family inet address 10.10.132.1/25
set interfaces ge-0/0/0 unit 255 family inet address 192.168.2.2/30
set interfaces ge-0/0/1 description Test2
set interfaces ge-0/0/1 unit 1 family inet address 10.10.132.129/25
set interfaces ge-0/0/2 description to-BB
set interfaces ge-0/0/2 unit 556 family inet address 10.1.6.90/30
set interfaces ge-0/0/2 unit 558 family inet address 10.1.6.134/30
set routing-options static route 208.226.76.25/32 next-hop 10.10.132.101
set routing-options static route 24.201.44.122/32 next-hop 10.10.132.101
set routing-options static route 216.150.170.90/32 next-hop 10.10.132.101
set routing-options static route 42.220.13.162/32 next-hop 10.10.132.101
set routing-options static route 81.247.181.14/32 next-hop 10.10.132.101
set routing-options static route 10.1.6.128/30 next-hop 10.1.6.89
set routing-options static route 0.0.0.0/0 next-hop 10.1.6.133
set protocols rip group Group1 neighbor ge-0/0/0.1
