03-18-2013 12:06 AM - edited 07-03-2021 11:44 PM
I would need assitance on explaining the heat map in Cisco Prime. Some AP's signal are shown as red (-35-45 dbm) , but some AP's are shown as yellow (-55-65 dbm).
Utilization, power, comparing the AP which has excellent red signal and yellow/green signal are same.
Kindly advise.
Rama
Solved! Go to Solution.
03-18-2013 01:21 AM
Here is a link that sort of explains it. Remember that this isn't going to give you the same readings as if you were using a survey tool to capture the RSSI value.
http://www.cisco.com/en/US/docs/wireless/ncs/1.0/configuration/guide/maps.html#wp1080107
03-18-2013 12:53 AM
Prime is estimating the RSSI in the floor plan and that is why you see some areas in yellow and not red. Typically you will see red when you have an AP in that room or right around the AP. PI is calculating the floor plan by what it hears from the other APs and where you are placing the APs on the map. APs in the wrong location will throw the color off also so that is important to make sure the AP locations are correct.
03-18-2013 01:14 AM
Hi Scott,
Are there any Cisco Doc states the info you have given? What kind calculation/algorithm does PI determine the dbm color per AP and what actually does it hear from other AP to determine the color.
Thanks in advance.
03-18-2013 01:21 AM
03-22-2013 02:16 AM
Hello!
It was noticed that we have two parametrs of calculating the heat maps: AP location and information from other APs.
What about obstales drawn in Map Editor?
Does NCS take them into considiration when calculating the heat maps?
Does NCS compare obstales with information from other APs when calculating the heat maps?
I also noticed some peculiarity: when I add obstales and click "Save and recompute RF prediction", after RF is predicted there are heat maps without lots of red zones. After choosing "Reload from network" the Heat maps change a lot of red zones appear.
So, the Heat maps from RF prediction differ a lot and from the "Reload from network" heatmap.
In this case, what is taken into considiration when calculating the location?
03-25-2013 02:56 AM
Is there any way to disable "Refresh Map from Network" feature (Prime 1.3)?
In Maps -> Properties there is an opportunity to disable "Refresh Map from Network" feature.
When returning to Maps -> Properties after some time, the "Refresh Map from Network" is enabled again.
Is it normal situation?
Does it refer to auto refresh feature in Floor area itself?
03-25-2013 04:44 AM
Yes it is for that floor and you do want the latest info. That is default and is a good thing.
03-25-2013 06:01 AM
It seems, that after auto update from netwrok Heat Maps do not take walls and obstacles into considiration. Red zones are displayed even behind the thick walls and doors, drawn in the Map editor.
In Site Maps -> Properties the option Wall Usage Calibration "Use walls" is chosen.
As far as I understand, this tells NCS to take drawn walls into considiration. while calculating HeatMaps
03-25-2013 06:04 AM
The only walls I would draw in is the outer walls so PI knows what's possibly inside or outside. Interior walls have a limitation on how many you can put on a floor if I recall.
Scott
Help out other by using the rating system and marking answered questions as "Answered"
03-25-2013 06:14 AM
I thought, that the more walls is drawn, the more carefull will be the Heat Map and Location accuracy.
Then why do we need obstacles at all?
03-25-2013 06:18 AM
It's there if you want to use it, but I don't at all. The AP's will triangulate the devices based off of rssi values so it depends on how well the floor was surveyed and if it was surveyed for data, voice, location or even high density. There is really no need if you ask me to put in the interior walls. The exterior is a different story. Anyway's, how would you know how every wall is constructed.... that would take forever and it doesn't include the other materials that also causes attenuation.
Scott
04-04-2013 06:36 AM
please find Cisco link for prime datasheet:
http://www.cisco.com/en/US/docs/wireless/prime_infrastructure/1.3/configuration/guide/pi_13_cg.pdf.
Thanks.
