WAAS Bounced Sequence Numbers at Client?
epeeler
Is it normal for me to be seeing the bounced sequence numbers of a WAAS optimized tcp stream at the client ends of the conversation?     I thought that this was something between the WAAS units themselves..
Marco Cassini
Indeed this is not expected to be seen on client side and would cause issues. This normally means there is some "leaked" packet from the WAN that is bypassing the WAE and reaching the client directly, so you should try to trace the exact path of those packets.
I hope this helps,
Marco
