Mounting Bracket for AIR-ANT2566P4W-R=
paul.2.smith
Looking at deploying the the above antenna externally, however it seems there is no specific mounting bracket available from Cisco to enable any adjustment  that needs to be made.
Has anybody any suggestions as to what to use, are there any 3rd party brackets that anyone can recommend?
Paolo Flores
Hey mate we ordered a bunch of brackets custom made for the 2566 antennas from DW-WiFi in the UK and had them shipped here to Australia. Obviously will be cheaper for you without the shipping. I believe he sells these now as a standard product.
http://www.wifiprofessionalservices.com/Antenna-Mounting-Brackets-For-Cisco-Antennas.php
lukemorgan1
Terrawave makes an adapter plate for this antenna that will allow it to be used with their universal articulating mount.  The adapter is part number TW-CISCO-A2566 and the universal articulating mount is TW-ART-MOUNTT at www.terra-wave.com.
Thanks for that, however I'm based in the UK so I imagine the cost of shipping these these would be prohibative
Paolo Flores
