03-24-2013 10:13 AM - edited 03-16-2019 04:25 PM
Hi guys,
All my ip phones registered with cucm and I am using H.323. The problem is when I dial a pstn number (10 digits ) the ip phone doesn't ring out at all but when I receive a call from a pstn number it rings fine. Also when I call an internal number 1XXX it rings out but not the pstn number.
Any idea?
03-24-2013 10:31 AM
Can you send your config..
Make sure you have the ff in bold in your config.
conf t
voice call send-alert
and the progress setup and alert under dialpeer
dial-peer voice 1001 pots
progress_ind setup enable 3
progress_ind alert enable 8
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
03-24-2013 11:32 AM
Yes I already put those commands in the voice router
voice translation-rule 2
rule 1 /2..../ /17772821359/
voice translation-rule 3
rule 1 /1678279\(....\)/ /2\1/
voice translation-rule 4
voice translation-rule 5
rule 1 /17772821359/ /2000/
voice translation-rule 100
rule 1 /1777282\(....\)/ /\1/
rule 2 /16782794482/ /17772821359/
voice translation-rule 105
rule 1 /1359/ /17772821359/
rule 2 /1359/ /16782794482/
voice translation-profile PSTN_in
translate called 100
voice translation-profile PSTN_out
translate calling 105
voice translation-profile TRANSLATE
translate calling 5
dial-peer voice 10000 voip
description Ways to 1XXX
translation-profile outgoing PSTN_in
destination-pattern 1...
session target ipv4:172.16.2.10
dial-peer voice 10001 voip
description call to PSTN network
translation-profile outgoing PSTN_out
destination-pattern 1[2-9]..[2-9]......
voice-class codec 1
session protocol sipv2
session target dns:callcentric.com
dtmf-relay sip-notify rtp-nte
ip qos dscp cs5 media
ip qos dscp cs4 signaling
03-24-2013 12:28 PM
So this is a SIP based PSTN.
Can you do a test call and send the ff debugs
debug ccsip messsages
debug voip ccapi inout
I also observe that there is no inbound dialpeer from cucm to the gateway..
Can you add this
dial-peer voice xxx voip
incoming called-number (put your called pattern here)
dtmf-relay h245 alpha-num
no vad
03-24-2013 01:36 PM
I didn't copy that part
03-24-2013 01:42 PM
OK. What is your call flow..Is this correct?
CUCM---h323--CUBE---SIp---PSTN
If thats correct you need to define an inbound dial-peer for calls coming in from cucm to the gateway (thse calls ar then sent tto the PSTN by the gateway)
I noticed that you have sip setup for your outbound dial-peer to your PSTN but there is no inbound dial-peer from CUCM
03-24-2013 02:37 PM
The ip phone rings out fine when I dial international number 011T. Only the pstn number 10 digits no ring out. Anything else works fine
03-24-2013 02:56 PM
OK,
If you need help then you need send the information requested..
Please send 'debug voip ccapi inout' and 'debug csip messages' for the affected calls.
03-24-2013 03:34 PM
2651xm#debug voip ccapi inout
voip ccapi inout debugging is on
2651xm#
Mar 10 17:24:40.973: //-1/007ED19C3700/DPM/dpAssociateIncomingPeerCore:
Calling Number=1359, Called Number=16785232243, Voice-Interface=0x0,
Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
Peer Info Type=DIALPEER_INFO_SPEECH
Mar 10 17:24:40.977: //-1/007ED19C3700/DPM/dpAssociateIncomingPeerCore:
Result=Success(0) after DP_MATCH_INCOMING_DNIS; Incoming Dial-peer=102
Mar 10 17:24:40.977: //-1/007ED19C3700/CCAPI/cc_api_display_ie_subfields:
cc_api_call_setup_ind_common:
cisco-username=1359
----- ccCallInfo IE subfields ---
2651xm#--
cisco-ani=1359
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=1
dest=16785232243
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=-1
cisco-rdnplan=-1
cisco-rdnpi=-1
cisco-rdnsi=-1
cisco-redirectreason=-1 fwd_final_type =0
final_redirectNumber =
hunt_group_timeout =0
Mar 10 17:24:40.981: //-1/007ED19C3700/CCAPI/cc_api_call_setup_ind_common:
Interface=0x8682AEF0, Call Info(
Calling Number=1359,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
Called Number=16785232243(TON=Unknown, NPI=Unknown),
Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
Incoming Dial-peer=102, Progress Indication=NULL(0), Calling IE Present=TRUE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=174
Mar 10 17:24:40.981: //-1/007ED19C3700/CCAPI/ccCheckClipClir:
In: Calling Number=1359(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
Mar 10 17:24:40.985: //-1/007ED19C3700/CCAPI/ccCheckClipClir:
Out: Calling Number=1359(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
Mar 10 17:24:40.985: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Mar 10 17:24:40.985: :cc_get_feature_vsa malloc success
Mar 10 17:24:40.985: cc_get_feature_vsa count is 1
Mar 10 17:24:40.985: :FEATURE_VSA attributes are: feature_name:0,fearture_time:2252809584,feature_id:166
Mar 10 17:24:40.985: //174/007ED19C3700/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
Call Info(Calling Number=1359(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
Called Number=16785232243(TON=Unknown, NPI=Unknown))
Mar 10 17:24:40.989: //174/007ED19C3700/CCAPI/cc_process_call_setup_ind:
Event=0x86490D78
Mar 10 17:24:40.989: //174/007ED19C3700/CCAPI/ccCallSetContext:
Context=0x86A9398C
Mar 10 17:24:40.993: //174/007ED19C3700/CCAPI/cc_process_call_setup_ind:
>>>>CCAPI handed cid 174 with tag 102 to app "_ManagedAppProcess_Default"
Mar 10 17:24:40.993: //174/007ED19C3700/CCAPI/ccCallProceeding:
Mar 10 17:24:40.997: //-1/007ED19C3700/DPM/dpMatchPeersCore:
Calling Number=, Called Number=16785232243, Peer Info Type=DIALPEER_INFO_SPEECH
Match Rule=DP_MATCH_DEST; Called Number=16785232243
Result=Success(0) after DP_MATCH_DEST
Mar 10 17:24:41.001: //-1/007ED19C3700/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
List of Matched Outgoing Dial-peer(s):
1: Dial-peer Tag=10001
2: Dial-peer Tag=10000
Mar 10 17:24:41.001: //174/007ED19C3700/CCAPI/ccCallSetupRequest:
Destination=, Calling IE Present=TRUE, Mode=0,
Outgoing Dial-peer=10001, Params=0x86A96184, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
Mar 10 17:24:41.001: //174/007ED19C3700/CCAPI/ccCheckClipClir:
In: Calling Number=17772821359(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
Mar 10 17:24:41.005: //174/007ED19C3700/CCAPI/ccCheckClipClir:
Out: Calling Number=17772821359(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
Mar 10 17:24:41.005: //174/007ED19C3700/CCAPI/ccCallSetupRequest:
Destination Pattern=1[2-9]..[2-9]......, Called Number=16785232243, Digit Strip=FALSE
Calling Number=17772821359(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
Redirect Number=, Display Info=
Account Number=1359, Final Destination Flag=TRUE,
Guid=007ED19C-D57E-F114-3700-3801AC10020C, Outgoing Dial-peer=10001
Mar 10 17:24:41.005: //174/007ED19C3700/CCAPI/cc_api_display_ie_subfields:
ccCallSetupRequest:
cisco-username=1359
----- ccCallInfo IE subfields -----
cisco-ani=17772821359
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=1
dest=16785232243
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=-1
cisco-rdnplan=-1
cisco-rdnpi=-1
cisco-rdnsi=-1
Mar 10 17:24:41.013: //174/007ED19C3700/CCAPI/ccIFCallSetupRequestPrivate:
Interface=0x867AA2D4, Interface Type=3, Destination=, Mode=0x0,
Call Params(Calling Number=17772821359,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
Called Number=16785232243(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=10001, Call Count On=FALSE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
Mar 10 17:24:41.013: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Mar 10 17:24:41.017: :cc_get_feature_vsa malloc success
Mar 10 17:24:41.017: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Mar 10 17:24:41.017: cc_get_feature_vsa count is 2
Mar 10 17:24:41.017: :FEATURE_VSA attributes are: feature_name:0,fearture_time:2252807856,feature_id:167
Mar 10 17:24:41.017: //175/007ED19C3700/CCAPI/ccIFCallSetupRequestPrivate:
SPI Call Setup Request Is Success; Interface Type=3, FlowMode=1
Mar 10 17:24:41.021: //175/007ED19C3700/CCAPI/ccCallSetContext:
Context=0x86A96134
Mar 10 17:24:41.021: //174/007ED19C3700/CCAPI/ccSaveDialpeerTag:
Mar 10 17:24:41.025: //175/007ED19C3700/CCAPI/cc_api_call_proceeding:
Interface=0x867AA2D4, Progress Indication=NULL(0)
2651xm#
2651xm#
Mar 10 17:24:54.512: //174/007ED19C3700/CCAPI/cc_api_call_disconnected:
Cause Value=16, Interface=0x8682AEF0, Call Id=174
Call Entry(Responsed=FALSE, Cause Value=16, Retry Count=0)
Mar 10 17:24:54.516: //175/007ED19C3700/CCAPI/ccCallDisconnect:
Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
Cause Value=16, Call Entry(Responsed=FALSE, Cause Value=16)
Mar 10 17:24:54.520: //174/007ED19C3700/CCAPI/ccCallDisconnect:
Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Mar 10 17:24:54.520: //174/007ED19C3700/CCAPI/cc_api_get_transfer_info:
Transfer Number Is Null
Mar 10 17:24:54.532: //174/007ED19C3700/CCAPI/cc_api_call_disconnec
2651xm#t_done:
Disposition=0, Interface=0x8682AEF0, Tag=0x0, Call Id=174,
Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
Mar 10 17:24:54.532: //174/007ED19C3700/CCAPI/cc_api_call_disconnect_done:
Call Disconnect Event Sent
Mar 10 17:24:54.536: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Mar 10 17:24:54.536: :cc_free_feature_vsa freeing 86472568
Mar 10 17:24:54.536: vsacount in free is 1
Mar 10 17:24:54.592: //175/007ED19C3700/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x867AA2D4, Tag=0x0, Call Id=175,
Mar 10 17:24:54.592: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Mar 10 17:24:54.592: :cc_free_feature_vsa freeing 86471EA8
Mar 10 17:24:54.592: vsacount in free is 0
2651xm#debug ccsip messages
SIP Call messages tracing is enabled
2651xm#
Mar 10 17:26:30.375: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:16785232243@callcentric.com:5080 SIP/2.0
Via: SIP/2.0/UDP 192.168.0.7:5060;branch=z9hG4bK8415E5
Remote-Party-ID: <>>17772821359@callcentric.com>;party=calling;screen=yes;privacy=off
From: <>>17772821359@callcentric.com>;tag=D66E3-1E4C
To: <>>16785232243@callcentric.com>
Date: Sun, 10 Mar 2013 17:26:30 GMT
Call-ID: 7B15CAB9-88DE11E2-80EDBF05-C0F9C20@callcentric.com
Supported: 100rel,timer,resource-priority,replaces
Min-SE: 1800
Cisco-Guid: 2712286-1132458260-939538689-2886730252
User-Agent: Cisco-SIPGateway/IOS-12.x
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1362936390
Contact: <17772821359>17772821359>
Call-Info: <192.168.0.7:5060>;method="NOTIFY;Event=telephone-event;Duration=2000"192.168.0.7:5060>
Expires: 180
Allow-Events: telephone-event
Content-Length: 0
2651xm#
Mar 10 17:26:30.452: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 407 Proxy Authentication Required
v: SIP/2.0/UDP 192.168.0.7:5060;branch=z9hG4bK8415E5;rport=57448;received=64.203.215.226
f: <>>17772821359@callcentric.com>;tag=D66E3-1E4C
t: <>>16785232243@callcentric.com>
i: 7B15CAB9-88DE11E2-80EDBF05-C0F9C20@callcentric.com
CSeq: 101 INVITE
Proxy-Authenticate: Digest realm="callcentric.com", domain="sip:callcentric.com", nonce="e38404538e671908fe60e1598cf18cc6", opaque="", stale=TRUE, algorithm=MD5
l: 0
Mar 10 17:26:30.468: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:16785232243@callcentric.com:5080 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Sent:
Via: SIP/2.0/UDP 192.168.0.7:5060;branch=z9hG4bK8526AE
Min-SE: 1800
CSeq: 102 INVITE
Max-Forwards: 70
Expires: 180
Proxy-Authorization: Digest username="17772821359",realm="callcentric.com",uri="sip:16785232243@callcentric.com:5080",response="f3449e7654bd0b4e279540fdfdbc4850",nonce="e38404538e671908fe60e1598cf18cc6",opaque="",algorithm=MD5
Content-Length: 0
Mar 10 17:26:30.524: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
v: SIP/2.0/UDP 192.168.0.7:5060;branch=z9hG4bK8526AE;rport=57448;received=64.203.215.226
CSeq: 102 INVITE
l: 0
Mar 10 17:26:30.752: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
CSeq: 102 INVITE
l: 0
2651xm#
2651xm#
Mar 10 17:26:35.913: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 183 Session Progress
t: <>>16785232243@callcentric.com>;tag=3573153219-717879
CSeq: 102 INVITE
m: <7BF4BF8CB1B62FC5AB23269E8F440964>7BF4BF8CB1B62FC5AB23269E8F440964>
l: 0
2651xm#
Mar 10 17:26:36.418: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 102 INVITE
l: 0
2651xm#
Mar 10 17:26:37.419: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 102 INVITE
l: 0
2651xm#
Mar 10 17:26:39.415: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 102 INVITE
l: 0
2651xm#
Mar 10 17:26:43.417: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 102 INVITE
l: 0
Mar 10 17:26:44.194: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
CANCEL sip:16785232243@callcentric.com:5080 SIP/2.0
CSeq: 102 CANCEL
Max-Forwards: 70
Timestamp: 1362936404
Reason: Q.850;cause=16
Content-Length: 0
Mar 10 17:26:44.247:
2651xm#//-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 102 CANCEL
l: 0
Mar 10 17:26:44.259: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 487 Request Terminated
CSeq: 102 INVITE
l: 0
Mar 10 17:26:44.267: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
To: <>>16785232243@callcentric.com>;tag=3573153219-717879
Max-Forwards: 70
CSeq: 102 ACK
Content-Length: 0
session target ipv4:172.16.2.10 CUCM ip address
voice-class codec 1
I am doing digits manipulation on 1XXX-------------->1XXXXXXXXXX
03-25-2013 05:16 AM
Can you please send your full config. I can see the call is matching inbound dialpeer 102. But I dont know what you have on that dialpeer...
03-05-2015 04:04 AM
I have cucm10.5 with 2x2921 routers.
When I place an internal call I don't here the ring and i don't now how many times the call is ringing.
Any ideas why my cucm doesn't send the ring to the other terminal???
03-24-2013 10:31 AM
What u are trying to say is that u have a cisco router configured as H.323 GW on which is being used for PSTN and registered to Call Manager.
The problem u are facing is that when u are dialing from IP phone to PSTN number , u do not hear RingBack Tone on your IP phone but the call when picked by PSTN user, u are able to talk.
When PSTN user calls on your IP phone, it works perfectly fine.
Please explain the last line of internal number.
regds,
aman
03-24-2013 11:35 AM
Yes. I have a couple of ip phones registered to cucm( v8.6). When I call the other ip phone internal number 1XXX it rings out. But When I dial a PSTN number number like my cell phone no ring out but I still receive the call from the ip phone.
Also I see the incoming call to my ip phone but I can't hear anything when I answer it and the other end they hear a fast busy signal.
