Inter-AS Option B ASR9K/IOS-XR - Config Help with MDT RPF Vector
jwstric22
Basically in my setup, I have AS65501 and AS65502.  AS65501 / AS65502  know all but a couple PEs from each respective AS (Provider exported  some routes for Inter-AS Option C L2VPNs).  Thus, I would some support of the RPF vector to alleviate some of the problems.
Apologize in advance, I have not had a chance to capture a debug of the PIM Join messages from PE to see the embedded RPF vector (if set correctly).  From the debug I saw, looks like its not even attempting to send the message.  https://supportforums.cisco.com/message/3392007#3392007 gave a good guide but it was IOS encentric.  I've hit some issues attempting to follow IOS guides with IOS-XR configurations.
Attached is a PE in AS 65501 that has attached customer edges.  Basically, it can't resolve the RPF neighbor to send the join.  Any guidance to my configuration problem would be appreciated.
jwstric22
Not supported on IOS-XR:
Cisco Reply:  "We do not support origination or termination of rpf-vector in IOS-XR today, for global table (BGP-nexthop) and Inter-AS Option B case".
Thus you would need to expose the PEs addresses of ASx in ASy and vice versus for the operations to successfully work.  Inter-AS Option C may be a better choice if possible, you own ASes.  Option B will work with the caviant of course you would need to export those specific routes of the originating BGP peers of the SAFI.
