03-25-2013 01:17 PM - edited 03-11-2019 06:19 PM
Hi There,
I am new with ASA devices
I have a ASA 5505, the former IT manager does not remember the password of it. I am just wondering do I lose the configuration on it if I reset the
password?
if yes, how can I download the configuration before resetting the password.
and how can I upload the downloaded configuration
Thank you in advance for your time
Solved! Go to Solution.
03-25-2013 01:31 PM
This Cisco document should detail the steps for Password Recovery.
http://www.cisco.com/en/US/docs/security/asa/asa72/configuration/guide/trouble.html#wp1058131
Basically what this does is
There are several guides online or even videos on Youtube which go through the process more clearly than the simply section of Cisco document I linked above.
You shouldnt loose your configuration unless you somehow manage to overwrite it
- Jouni
03-25-2013 01:31 PM
- Jouni
03-26-2013 06:40 PM
Hi Jouni,
Thank you so much for your reply. Actually I have tried the procedure on my other ASA 5505 as a test and it worked but I do not want to create a mess in my real network. until I have to.
any way thank you so much for your time
