Warning message
Cannot Upgrade CUE
Mar 28th, 2013
I have a UC520 that does not upgrade CUE.  I am trying to upgrade to 8.2.0.  When usine CCA, I was able to upgrade CME IOS but it failed on the CUE.  I tried upgrading CUE on it's own and it failed as well.  I now tried upgrading using boot helper command, it starts to copy the file from the TFTP server and then then it aborts?  I am thinking a space issue?  I don't know.
danplacek Thu, 03/28/2013 - 09:01
  • Silver, 250 points or more
Can you post the terminal output from your boot helper attempt?
-Dan
Please rate useful posts.
James Davies Thu, 03/28/2013 - 09:17
I had this issue recently as well and moving the call processor back to it's default voice and data VLAN's resolved the issue and I was able to complete a software pack upgrade in full.  I suppose it could had been a coincidence though.
mark@excellent-... Thu, 03/28/2013 - 09:54
ServicesEngine boot-loader>
ServicesEngine boot-loader> config
  IP Address [10.1.10.1] >
  Subnet Mask [255.255.255.252] >
  TFTP Server [192.168.1.84] > 192.168.1.79
  Gateway [10.1.10.2] >
  Default Helper-file [cue-installer.uc500.8.0.6] >
  Ethernet Interface [internal] [internal] >
  Default Boot [none|helper|disk] [disk] >
  Default Bootloader [primary|secondary] [primary] >
Erasing Flash...
. done
Erased 1 sectors
Writing to Flash...
64 KBdone
paolo bevilacqua Thu, 03/28/2013 - 10:32
  • Hall of Fame,
    Founding Member
The log above does not show an actual boot attempt.
mark@excellent-... Thu, 03/28/2013 - 10:36
Looks like there is an issue with my switch and the UC.  Once I connected directly to the UC, the upgrade went through.  I may need to upgrade my switch and check my uplink ports.   Thanks for the help
