Switchport mode access command
Patrick McHenry
Level 3
Level 3
I was curious about the switchport mode access command and its interoperability with the switchport voice vlan command.
If I configured a switchport with the switchport mode access commmand, will that make it impossible for the switchport to create a special case trunk with the IP phone? Even if I configure switchport voice vlan command?
And if so, should the port be configured as switchport mode dynamic auto? Or desirable?
Thank you, Pat
fb_webuser
Level 6
Level 6
Pat, you absolutely can configure a port as an access port, add the voice vlan config and have connect both a phone and another device. The trunk will form. With the "voice vlan" Cisco obfuscates the fact that a trunk is being formed. I don't necessarily agree with this strategy and it wasn't always that way. I remember configuring phones on a 3500XL and the ports were configured as trunks.
You got me thinking, so I issued some commands on a WS-C3560V2-48PS-S running IOS 12.2(58)SE2 that has 12 phones connected to it.
Here is the config for a port that has a phone connected:
Switch#sho run int f0/2
Building configuration...
Current configuration : 475 bytes
interface FastEthernet0/2
switchport access vlan 11
switchport trunk native vlan 11
switchport trunk allowed vlan 2,10-19
switchport nonegotiate
switchport voice vlan 12
srr-queue bandwidth share 1 30 35 5
priority-queue out
mls qos trust device cisco-phone
mls qos trust cos
auto qos voip cisco-phone
no mdix auto
spanning-tree portfast
service-policy input AUTOQOS-SRND4-CISCOPHONE-POLICY
end
If I show the trunk status for an individual port IOS acknowledges that the port with the phone attached is actually a trunk:
Switch#sho int f0/2 trunk
Port Mode Encapsulation Status Native vlan
Fa0/2 off 802.1q not-trunking 11
Port Vlans allowed on trunk
Fa0/2 11-12
Port Vlans allowed and active in management domain
Fa0/2 11-12
Port Vlans in spanning tree forwarding state and not pruned
Fa0/2 11-12
However if I do a "sho int trunk" to show all the trunk ports on the switch IOS does not include the phone ports in the output.
Switch#sho int trunk
Fa0/45 on 802.1q trunking 12
Fa0/46 on 802.1q trunking 12
Gi0/1 on 802.1q trunking 11
Gi0/2 on 802.1q trunking 11
Fa0/45 2,10-19
Fa0/46 2,10-19
Gi0/1 2,10-19
Gi0/2 2,10-19
Fa0/45 2,11-13,16-17
Fa0/46 2,11-13,16-17
Gi0/1 2,11-13,16-17
Gi0/2 2,11-13,16-17
Gi0/1 2,11-13,16-17
Gi0/2 2,11-13,16-17
So on one hand IOS says "Yes, it is a trunk" and on the other it says "Nope, no trunks here!". So notice that "spanning-tree portfast" is configured on f0/2, not "spanning-tree portfast trunk". Portfast is still active on this port.
Switch#sho span int f0/2 portf
VLAN0011 enabled
VLAN0012 enabled
Conversely on port 45 we have a VG-224 connected and it is configured with "switchport mode trunk" and "spanning-tree portfast trunk". If I change that to just "spanning-tree portfast" we see this:
Switch#sho span int f0/45 portf
VLAN0002 disabled
VLAN0011 disabled
VLAN0012 disabled
VLAN0013 disabled
VLAN0016 disabled
VLAN0017 disabled
Cisco has confused the issue here. I would prefer it if we called a trunk a trunk but for whatever reason they do not.
Cheers,
-Jeff
Posted by WebUser Jeff Davis from Cisco Support Community App
12 Replies 12
Bilal Nawaz
The switchport voice vlan command instructs the Cisco IP phone to forward all voice traffic through a specified VLAN. The Cisco IP phone forwards the traffic with an 802.1p priority of 5.
The switchport access vlan is the data vlan which can be on the same port as voice.
I haven't ever seen an access port for a phone and PC set up as a trunk. So I do not think the switchport mode dynamic/auto etc... command is needed. Its only used as an access port so should be switchport mode access. As far as i know, there is no trunking required to a ip phone.
I hope this helps
Please rate useful posts and remember to mark any solved questions as answered. Thank you.
Please rate useful posts & remember to mark any solved questions as answered. Thank you.
To Raj, Did you configure QoS for the Voice. When QoS setup with EF class voice traffic get first priority.
Hello Skahawala,
Thanks for your reply, basically I don't know about voice part. I didn't configure the QoS for the voice.
Please guide how can I configure the required configurations.
And also now I am facing the issue is RTP and voice ports 5060, 5061 & 5070 etc. these voice ports are my ISP already enabled but they said I need to enable the voice ports on my end. Even they didn't support for enable the voice ports on my router, that's why I am asking you.
Please guide me how can I enable the above ports on my cisco 2911 router.
Raj
Hello raj
You can setup QoS setting in router to give voice packet expedite forwarding. please read following  Cisco  guide
http://www.cisco.com/c/en/us/td/docs/ios/12_2/qos/configuration/guide/fqos_c/qcfmcli2.html
http://www.cisco.com/c/en/us/td/docs/ios/12_2/voice/configuration/guide/fvvfax_c/vvfqos.html
Hopes this will help you
Reza Sharifi
Pat,
Only when you are connecting to a Cisco phone you can use access mode for both vice and data since Cisco switches use CDP to identify the phone.  If your phone is not a Cisco phone, you would need to trunk the port.
Abzal
Level 7
Level 7
Actually if Cisco IP Phone is connected to access as well as PC it is a switchport voice vlan command enables to separate Voice and Data traffic. Think it as mini-trunk. IP phone connected access port and with voice vlan defined learns by CDP protocol it's VLAN id. And as Bilal mentioned there is no need any trunk configuration.
Best regards,
Abzal
Thank you
I don't want to configure a trunk. I want to dynamically create a special case trunk when the phone connects. My question is:
If I configure a port using "sw mode access" as a part of the port configuration, along with "switchport voice vlan vlan", will the switch still direct the phone to create a special case trunk, so voice is on the Voice VLAN and data is on the native VLAN.
Thank you, Pat.
Hello Patrick,
Your understanding is correct. The phones have very similar hardware as what is in the switch, so trunking capabilities are very possible, this is what the voice vlan is used for, to segregate the traffic from data traffic. The phone has the ability to tag and untag the 802.1q header, and any untagged traffic is for data.
I found the following explanation from a ccna voice - understanding concepts book. Extract:
You might call the connection between the switch and IP phone a "mini-trunk" because a typical trunk passes a large number of VLANs (if not all VLANs). In this case, the IP phone tags its own packets with the correct voice VLAN (VLAN 25, in the case of Figure 3-6). Because the switch receives this traffic on a port supporting tagged packets (our mini-trunk), the switch can read the tag and place the data in the correct VLAN. The data packets pass through the IP phone and into the switch untagged. The switch assigns these untagged packets to whatever VLAN you have configured on the switchport for data traffic.
NOTE
Traditionally, a switchport on a Cisco switch that receives tagged packets is referred to as a trunk port. However, when you configure a switchport to connect to a Cisco IP Phone, you configure it as an access port (for the untagged data from the PC) while supporting tagged traffic from the IP phone. So, think of these ports as "access ports supporting tagged voice VLAN traffic."
Hope this helps
fb_webuser
Level 6
Level 6
priority-queue out
mls qos trust cos
no mdix auto
end
Fa0/2 11-12
Fa0/2 11-12
Fa0/2 11-12
Fa0/45 2,10-19
Fa0/46 2,10-19
Gi0/1 2,10-19
Gi0/2 2,10-19
Gi0/1 2,11-13,16-17
Gi0/2 2,11-13,16-17
Gi0/1 2,11-13,16-17
Gi0/2 2,11-13,16-17
VLAN0011 enabled
VLAN0012 enabled
VLAN0002 disabled
VLAN0011 disabled
VLAN0012 disabled
VLAN0013 disabled
VLAN0016 disabled
VLAN0017 disabled
Cheers,
-Jeff
Great post and thanks for labbing it - Jeff!
When you did a show int fa0/2 trunk, it says it is not trunking and the mode is off. Why do you think the IOS is stating that it is a trunk?
Thanks, Pat.
Pat,
Cisco switches have special feature and that is called auxiliary VLAN.  It basically let you configure 2 vlans (one data and one voice) to an access port. So, even through we have more then one vlan attached to this port and it actually trunking, Cisco does not call it trunk and call it "Multi-vlan access port" (see link below). That is why in the show interface trunk it shows the interface as not trunking
Here is another example this port is configured with 2 vlans (12 (voice) and 13 (data))
and here is the output of sh int gi1/0/23 trun
3750-Switch(config-if)#do sh int gi1/0/23 trun
Gi1/0/23    off              802.1q         not-trunking  1
As you can see, it says not trunking
now, I will change the port to trunk mode:
Gi1/0/23    on               802.1q         trunking      1
https://supportforums.cisco.com/docs/DOC-4542
Hi Pat,
I am using voip services for my business, for that I am using IP phone(soft calling). But now I am getting line disturbance and voice crackling.
Exactly customer unable to here our agents voice because of some noise is there in the line.some times agents also having the same problem.
I am using the cisco 2911 router  and (SRW224G4 v1.1 business series) Switches I am using rigth now. Is there any thing to configure in switches for VIOP services.
Please let me know any suggestions, because it is very hard. every time line issue came to the picture.
Raj
