Help setting up a Cisco 871 Router for Home...
andrewyoon33
2 Accepted Solutions
Hello Andrew,
Alain provided you entire configuration of what you requested, but I think that you also need to configure NAT to be able to access internet from LAN PCs.
Reason for this is that you obtain WAN IP address and default route from ISP, for example:
IP: 10.0.0.1
Mask: 255.255.255.0
Gateway: 10.0.0.254
But your ISP assume that you have connect only one PC, so only 10.0.0.1 IP address will have acces to internet. ISP will drop all traffic from 192.168.10.0/24 and 192.168.20.0/24 because these networks are unknow for ISP. So you need to NAT your internal networks to your WAN IP 10.0.0.1.
Here is configuration:
ip access-list extended NAT_ACL
deny   ip 192.168.10.0 0.0.0.255 192.168.10.0 0.0.0.255
deny   ip 192.168.10.0 0.0.0.255 192.168.20.0 0.0.0.255
deny   ip 192.168.20.0 0.0.0.255 192.168.10.0 0.0.0.255
deny   ip 192.168.20.0 0.0.0.255 192.168.20.0 0.0.0.255
permit ip 192.168.10.0 0.0.0.255 any
permit ip 192.168.20.0 0.0.0.255 any
deny   ip any any
route-map NAT_MAP
match ip address NAT_ACL
ip nat inside source route-map NAT_MAP interface FastEthernet4 overload
interface Vlan10
ip nat inside
interface Vlan20
ip nat inside
ip nat outside
Last thing, it is not necessary, but maybe you would like to restrict users from Guest VLAN to access your internal network:
ip access-list extended Restrict_GUESTS
deny   ip any any
interface Vlan20
  ip access-group Restrict_GUESTS in
Best Regards
Please rate all helpful posts and close solved questions
Best Regards Please rate all helpful posts and close solved questions
Try adding:
ip route 0.0.0.0 0.0.0.0 192.168.1.1
If this doesn't work please post the output of:
sh ip route
10 Replies 10
cadet alain
config t
vlan 10
name Staff
vlan 20
name Guest
2)
  config t
  int vlan 10
  ip address 192.168.10.254 255.255.255.0
  int vlan 20
  ip address 192.168.20.254 255.255.255.0
no ip dhcp conflict-logging
ip dhcp excluded-address 192.168.10.201 192.168.10.254
ip dhcp excluded-address 192.168.20.201 192.168.20.254
ip dhcp excluded-address 192.168.10.1 192.168.10.99
ip dhcp excluded-address 192.168.20.1 192.168.20.99
ip dhcp pool vlan10-pool
network 192.168.10.0 /24
default-router 192.168.10.254
dns-server 8.8.8.8
ip dhcp pool vlan20-pool
network 192.168.20.0 /24
default-router 192.168.20.254
dns-server 8.8.8.8
3)
config t
int fa4
ip address dhcp
4)
   config t
   int fa0
   switchport mode access
   switchport access vlan 20
   int fa1
   switchport access vlan 10
   int fa2
   int fa3
Alain
Hello Andrew,
IP: 10.0.0.1
Mask: 255.255.255.0
Gateway: 10.0.0.254
deny   ip any any
route-map NAT_MAP
interface Vlan10
ip nat inside
interface Vlan20
ip nat inside
ip nat outside
deny   ip any any
interface Vlan20
Best Regards
Didnt work...  Couldnt get to the internet or ping 8.8.8.8
My current setup for this would be:
I have my Cisco 871 connected to the LAN port off the Verizon Router... (Verion Router IP: 192.168.1.1)
The IP Address I am using on the Cisco WAN fa4 port is 192.168.1.2 /24, My machine wont reach out to the internet from the computer...DHCP is working fine and I can get an IP of 192.168.10.x or 192.168.20.x also able to ping the interface 192.168.10.x or 192.168.20.x
Still confused on why I cant reach out to the internet...
Below is my current config:
Building configuration...
Current configuration : 4260 bytes
version 12.4
no service pad
service password-encryption
hostname P1-Router
boot-start-marker
boot-end-marker
enable secret 5
enable password 7
aaa new-model
aaa authentication login default local
aaa authorization exec default local
aaa session-id common
crypto pki trustpoint TP-self-signed-
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-
crypto pki certificate chain TP-self-signed-
        quit
dot11 syslog
ip cef
no ip dhcp use vrf connected
no ip dhcp conflict logging
   network 192.168.10.0 255.255.255.0
   default-router 192.168.10.1
   dns-server 192.168.1.1 8.8.8.8
   network 192.168.20.0 255.255.255.0
   default-router 192.168.20.1
no ip domain lookup
ip domain name P1.COM
ip inspect name MYFW tcp
ip inspect name MYFW udp
username admin privilege 15 password
archive
log config
  hidekeys
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
ip address 192.168.1.2 255.255.255.0
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
interface Vlan1
ip address 192.168.2.1 255.255.255.0
interface Vlan10
ip address 192.168.10.1 255.255.255.0
ip nat inside
interface Vlan20
ip address 192.168.20.1 255.255.255.0
ip nat inside
ip forward-protocol nd
ip http server
ip http secure-server
ip access-list extended NAT-ACL
deny   ip any any
deny   ip any any
route-map NAT_MAP permit 10
match ip address NAT-ACL
control-plane
line con 0
password 7
no modem enable
line aux 0
line vty 0 4
password 7
scheduler max-task-time 5000
end
Hello Andrew,
Can you provide output of #tracert 8.8.8.8, can you also provide output of ping and traceroute 8.8.8.8 from router?
Configuration seems OK.
Best Regards
Try adding:
sh ip route
I think so DNS and WAN Ips are not corect.
Can you provide me detials how you are connected to ISP.
Router > ISP (if i am correct)
If you are connecte like above scenerio verify from ISP what DNS and WAN IP you will use..
Jawad
Hello!
For waht do you need this line?
it almost work, i could ping 8.8.8.8 from the router, but internet doesn't work anyway on my laptop
Hello, thanks for all this useful information. My plan is to get rid of my BT home router, but I have a few questions:
if you dont mind:
1. How do you go about setting up the wireless ssids etc on same router? If you could point me on the right direction? I understand the logic of all these commands and the logic on why you did the subnetting between 192.168.10.254 and 192.168.20.254, but Im quite lost in regards wireless settings.
2. How do you go about firewalling this router? Because at the moment, I have a BT home router who does basic firewal function?
Many thanks in advance, and thanks everyone on this post; there is lot of useful information in here.
For Firewalling you can use CBAC or Zone Based Firewall, here are some docs about these:
http://www.cisco.com/en/US/products/sw/iosswrel/ps1835/products_configuration_guide_chapter09186a00800ca7c5.html
http://www.cisco.com/en/US/docs/ios-xml/ios/sec_data_zbf/configuration/12-4t/sec-zone-pol-fw.html
For Wireless it all depends on the router model.
Alain
Hello Roberto,
Here are links to configure wifi on 871:
- https://supportforums.cisco.com/docs/DOC-16020
- http://www.piglet-net.net/tech/cisco/cisco-871W-simple.html
Zone-Based Policy Firewall
- http://www.cisco.com/en/US/products/sw/secursw/ps1018/products_tech_note09186a00808bc994.shtml
Hope this helps you.
Best Regards
