DMP 4310G Disable USB ports
cjoseph23
We have a couple of hundred DMPs in our network right now. Our internal security team did an audit and is requested that I disable the USB ports on the back of these devices.   Does anyone know if this is possible through the GUI or any other way?
firmware version - v5.4
all are the same hardware - DMPs-4310G-54-K9
cj
Mike Assel
Level 4
Level 4
I would think that you could create an advanced task to disable the USB port of the DMP in the DMM.  Then you can run that task on your DMPs.
has anyone tried this?  i have a customer asking me the same question for the same reason and i dont have any gear to test this out with.  we will be deploying DMM 5.4 with 4310G DMPs.  thanks!
Tomas de Leon
