04-10-2013 07:58 AM
I Have A Cisco Access Point. The exact model is C1142(AIR-AP1142N-E-K9) and firmware c1140-k9w7-mx.152-2.JB
As you know it has two Radio interface, one for 2.4Ghz and one for 5Ghz
I have set mbssid on both of them and turned the guest mode On in two SSID (one in each of them)
so, normally both of them should be broadcasted and discovered by wireless adapters
and i should add the configuration (authentication method profile and ...) is exactly the same for all of them and both interfaces are up
but the problem is that the SSID set on 5GHz Radio is not broadcasted and worse than that, it is not even functioning when i try to add it manually on a windows client
Am i missing anything in my configuration or ... ?
here is the configuration lines which may be necessary for your troubleshoot
no ip routing
no ip cef
dot11 syslog
dot11 ssid TEST
vlan 400
authentication open eap eap_methods
authentication network-eap eap_methods
authentication key-management wpa version 2
accounting acct_methods
dot1x eap profile TEST
mbssid guest-mode
dot11 ssid TEST-Guest
vlan 450
authentication open
mbssid guest-mode
dot11 ssid TEST5
vlan 440
mbssid guest-mode
eap profile TEST
method peap
method mschapv2
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption vlan 400 mode ciphers aes-ccm
encryption vlan 440 mode ciphers aes-ccm
encryption vlan 450 key 1 size 40bit CISCOCISCO transmit-key
encryption vlan 450 mode wep mandatory
ssid TEST
ssid TEST-Guest
antenna gain 0
mbssid
station-role root
no cdp enable
interface Dot11Radio0.5
encapsulation dot1Q 5 native
no ip route-cache
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Dot11Radio0.400
encapsulation dot1Q 400
no ip route-cache
bridge-group 255
bridge-group 255 subscriber-loop-control
bridge-group 255 spanning-disabled
bridge-group 255 block-unknown-source
no bridge-group 255 source-learning
no bridge-group 255 unicast-flooding
interface Dot11Radio0.440
encapsulation dot1Q 440
no ip route-cache
bridge-group 254
bridge-group 254 subscriber-loop-control
bridge-group 254 spanning-disabled
bridge-group 254 block-unknown-source
no bridge-group 254 source-learning
no bridge-group 254 unicast-flooding
interface Dot11Radio0.450
encapsulation dot1Q 450
no ip route-cache
bridge-group 253
bridge-group 253 subscriber-loop-control
bridge-group 253 spanning-disabled
bridge-group 253 block-unknown-source
no bridge-group 253 source-learning
no bridge-group 253 unicast-flooding
interface Dot11Radio1
no ip address
no ip route-cache
ssid TEST-Guest
ssid TEST5
antenna gain 0
mbssid
station-role root
no cdp enable
interface Dot11Radio1.5
no ip route-cache
bridge-group 1
interface Dot11Radio1.400
no ip route-cache
bridge-group 255
interface Dot11Radio1.440
no ip route-cache
bridge-group 254
interface Dot11Radio1.450
no ip route-cache
bridge-group 253
Power inline negotiation injector installed
04-10-2013 09:18 AM
It appears this post is in the wrong area. This area is for the Cisco Intelligent Automation for Cloud and Cisco Intelligent Automation for SAP solutions. You should probably repost the item in another area which the appropriate experts monitor.
04-10-2013 04:48 PM
Boot the AP and post the bootup process.
04-10-2013 09:02 PM
04-10-2013 09:07 PM
plz answer me in my new post
No, I won't.
I won't respond to your duplicate post(s).
