Login failed due to a configuration error. Please ask your system administrator to associate your phone with the RM JTAPI provider user ID according to the instructions in the administrator guide.
Apr 10th, 2013
                  Cisco Agent Desktop Version 8.5
Please suggest.
Thanks & Regards,
Sasi G
1 vote
Overall Rating: 5 (5 ratings)
Chakshu Piplani Wed, 04/10/2013 - 12:55
Hi Sasi,
On CUCM:
User Management->Application Users->select the RmCm application user
click on find more phones, search by using the extension of the user.
Add the phone to the Controlled Devices on that RmCm application user.
If you do not know the RmCM user :
On CCX
go to subsystems->RmCm->RmCm Provider->User ID will have the ID created on CUCM application user.
If the user is already associated try dissassociating it from CUCM and reassociating it back.
Let me know how it goes.
Sasikumar Gunas... Thu, 04/11/2013 - 12:33
Thanks Chakshu...
Tried the solution you have provided. Still getting the same error message. For some users we are having this..
if you have any other options to try let me know.
Thanks & Regards,
Sasi G
Chakshu Piplani Sat, 04/13/2013 - 05:21
Hi Sasi,
Are you using Extension Mobility by any chance?
If yes you might need to assosiate the EM profile as well the the RmCm user.
If you are still getting this message, try deleting the phone completely and re-adding it again to CUCM.
Binu Savariyar Fri, 12/13/2013 - 16:29
I have also faced the similar issue and found a fix.
In my case i faced this issue while swapping the phone.
1. Associate phone to rmcm user -- no luck
2. did a Jtapi resync -- no luck
3. Disassociate the old phone mac address from the rmcm - it worked !!!!!
Binu
layla.abunejem Thu, 12/15/2016 - 05:53
Worked for me too. Thank you.
Related Content
