Warning message
Business Edition 3000 AutoAttendant with VM Box
I  am attempting to configure an auto attendant in BE3000 version 8.6.4. The goal is for the caller be able to leave a message. Whether its's a caller input option so that pressing 1 leaves a  message or it goes to VM after the AA greeting I dont care.   I tried a user for option 1 that transfers to a new user extension that is not on a phone.  but when I do that there is no way to make it go direct to VM it just loops the AA greeting.
Please Help
sanjsinh Thu, 04/11/2013 - 06:28
  • Bronze, 100 points or more
You can configure a user, assign that user an unassigned extension. Then you can set Call Forward All to Voicemail.
Assign this user as one of the keys in AA menu.
sanjsinh Thu, 04/11/2013 - 21:32
Another option to do it, and probably better one is, when the AA greeting is being played, the caller can dial *extension number. The call will route directly to VM.
Sanjay
