CDR Not working
Apr 11th, 2013
we activated the services but CDR not working and showing followign massage
* For the following Nodes, CDR Enabled Flag is not activated though CallManager Service is activated. Hence no CDRs will be generated on these nodes.
* Cluster wide parameter 'Call Diagnostics Enabled flag' is set to false. Hence no QoS information will be generated on calls. If required, please configure the same from service parameter page for Call Manager service.
please suggest.
Overall Rating: 4.7 (5 ratings)
Ayodeji Okanlawon Thu, 04/11/2013 - 02:54
  • Cisco Designated VIP,
    2017 IP Telephony
You need to go CUCM and enable those parameters.
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
Jayesh Prajapati Thu, 04/11/2013 - 03:00
thanks for reply.
as I have checked , it's activated .
can you suggest me steps for where I can verify it ?
thanks
Ayodeji Okanlawon Thu, 04/11/2013 - 03:04
    2017 IP Telephony
Go to CUCM>Service parameters>Select the servers you want CDR enabled on> then select CUCM service
Scroll down to ...
System:
CDR enabled....Set it to True
Cluster wide parameters:
Call Diagnostics Enabled: Enabled when CDR flag is set to True
islam.kamal Thu, 04/11/2013 - 03:01
  • Red, 2250 points or more
Hello
you have to do the below
1-Check in Serviceability -> Tools -> CDR Management what your settings are under "General Parameters". CUCM is purging the records out of it's database based on parameters set there.
2-
Check that CDRs haven't become disabled. System -> Service Parameters -> (Server) -> CallManager -> CDR Enabled Flag
Thank you
please rate if this will help
issofunky Fri, 01/08/2016 - 08:51
One remaining question:  is this change service impacting?
