UCCX 9 Wallboard
Answered Question
Apr 12th, 2013
Hi everyone,
Was wondering if anyone could recommend a wallboard solution for UCCX 9 that would show realtime stats on the wallboard screen?
I  know of the Cisco Intelligence Centre but apparently it only supports  historical reports for UCCX 9 and we are after realtime agent/csq stats. I also see some suggestions for up to UCCX 8.5 but I am assuming these are not relevant to uccx 9 due to some change? (possibly why intelligence centre doesnt support realtime stats either on ver 9?)
Any advice would be much appreciated.
Thanks in advance.
Kamran
Correct Answer by thomascollins about 3 years 10 months ago
For the do-it-yourself variety, check out the community developed version at https://supportforums.cisco.com/thread/269435?start=0&tstart=0
Unfortunately it's 39 pages of comments/updates, and I'm not sure if it's been tested with v9.  (We use it with v8.5).  It also really helps if you have a web developer or SQL knowledge.
It looks like it was based on similar code to the IPCC Wallboard (Sourceforge) -- but that one hasn't been updated since IPCC v4.
Correct Answer by Jonathan Schulenberg about 3 years 10 months ago
Nothing has changed in 9.0 from this perspective. The wallboard application is given an ODBC login to the database and has access to read two real-time tables in Informix. The BU provides guidence that the wallboard app should not query the database more than once every 10 seconds so in reality it's near realtime like CSD is.
There are two options in the compatibility matrix (Spectrum and Inova) as well as offerings from 2Ring, TASKE, VSR2, IPCC Wallboard (Sourceforge), and Aceyus in no particular order. Of course, the only ones TAC will even remotely support are those listed on the compatibility matrix.
Please remember to rate helpful responses and identify helpful or correct answers.
Overall Rating: 5 (3 ratings)
Correct Answer
Jonathan Schulenberg Fri, 04/12/2013 - 04:30
Correct Answer
thomascollins Fri, 04/12/2013 - 05:29
kkhanis Fri, 04/19/2013 - 02:48
Many thanks for the pointers guys!
We ended up choosing one of the TAC supported options just for the matter of support etc.
Thanks again.
Kamran
Vladimiro Lerena Tue, 09/17/2013 - 20:42
Hi, I'm having similar need for a customer, can you share with me which was the solution supported by TAC that you finally chose ?
thanks
Vladimiro
grebac.2ring Tue, 10/08/2013 - 06:59
Hi there,
Have a look at a user-friendly solution 2Ring DASHBOARDS & WALLBOARDS - www.2Ring.com/DW - there is a free trial available that you can have up and running on 5 minutes or less.
Michal, 2Ring
Nelson Alonso Mon, 11/18/2013 - 06:40
How long does it take to get the download link, I want to try this for a client who is upgrading to uccx 9.
grebac.2ring Mon, 11/18/2013 - 06:44
Hi, there is an automated email reply, so you should get it in less than a minuted. Just go to www.2Ring.com/DW and look for a "TRY IT FOR FREE .." tab on the right. Michal, 2RIng
Nelson Alonso Mon, 11/18/2013 - 07:06
Had to do it a second time. Maybe I made a typo on my email. Do you have a simple guide on how to create a realtime wallboard for UCCX? Just something simple to show the client. Right now everything is running on your demo.
grebac.2ring Mon, 11/18/2013 - 07:12
Good, I saw the request to come in, so let's continue this conversation via email. Michal
richard.grey Fri, 01/31/2014 - 12:55
Hello Jonathan,
Do you know where I may locate the Wall Board compatibilty Matrix
Ricahrd
karen00017 Wed, 06/03/2015 - 02:44
If you're still interested, Comstice has a great Wallboard. It shows real time stats and has different views to show: box view/ agent states/ dashboard view/ team view. And, it offers Team Voicemail.
There's complementary apps for Android and IOS showing Charts, Table view, Agent states, Alerts etc. You can run the app in demo mode or request a trial of the wallboard to showcase it to your clients. comstice.com/wallboard
Karen, Comstice
Comstice Wallboard
Pranjol Saikia Thu, 02/18/2016 - 23:33
You can check out the solution MARS UCCX Wallboard which give great reports but a very low cost.
MARS UCCX Wallboard displays real time info of Cisco UCCX in contact centers.
Monitor your contact center functions and performance in real-time.
User defined screen layout
Drag drop views as per your choice
If configured thresholds are reached, alarms are raised by changing the colors in the screen as configured
If primary UCCX server goes down then application connects automatically to secondary UCCX server.
sjssolutions Fri, 04/08/2016 - 04:17
SJS Solutions have recently added UCCE and X connectors to their visual communications solution Optymyse, there's an API to pull data from other sources as well. Free Trial is also available from sjssolutions.com
Related Content
