PoE over SFP port on Cisco 3750 with GLC-T 1000Base-T Copper SFP Module
Sam Brynes
I was looking on Cisco for a 3750 switch with PoE and gigabit ethernet (not SFP) ports, but they are few and far between. I want to connect a Cisco VoIP phone and a Cisco PoE access point via cat5e to the switch and have them powered by PoE.
Since Cisco 3750s with non-SFP gigabit Ethernet ports are hard to find, I was wondering if I could buy a 3750 with SFP ports and buy two
GLC-T 1000Base-T SFP transceivers to get two gigabit Ethernet ports and then power the VoIP phone and access point that way? Is PoE supported on SFP ports like that with the copper SFPs inserted?
Reza Sharifi
There are a few Cisco 3750 POE with 10/100/1000 ports
here is one
WS-C3750G-24PS-S
This switch will give you 24 POE port at 10/100/1000 speed copper.  It also comes with 4 SFP ports for uplink.
POE is only through copper ports.  Fiber ports don't provide POE.
Here is the data sheet:
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps5023/product_data_sheet0900aecd80371991.html
Innovations in Cisco Full Stack Observability - A new webinar from Cisco
