04-17-2013 01:06 AM - edited 03-16-2019 04:50 PM
We want to upgrade from CCM 4.3(2) to BE6000.
Is it possible to upgrade directly from 4.3(2) to BE6000?
Someone claims there is a problem upgrading phone firmware from CCM4.3(2) to BE6000. Is this correct?
Torleif
Tjome Municipality, Norway
04-17-2013 03:36 AM
Hi.
It depends on actual firmware version installed on your phones.
If you have a firmware version earlier than 8.3(3), you have first upgrade to firmware version 8.5(2) before you can upgrade to 9.1
Carlo
Please rate all helpful posts
04-17-2013 03:42 AM
Is it possible to use firmware 8.5(2) with ccm4.3(2)?
Torleif
04-17-2013 03:55 AM
Please refer the URL
For BE6000, u require UCS C220 M3 platform.
regds,
aman
04-17-2013 03:59 AM
I can also suggest you, to upgrade your phone firmware to the latest available version per model in order to avoid issues when you'll migrate to 9.1
Carlo
04-18-2013 05:24 AM
Thank you all for your replies!
I will start with making sure I have the latest CCM 4.3 firmware.
It seems like my 7960 havs firmware version 8.1(2.0). I am not sure if there is a newer version availible for CCM4.3.
Torleif
04-18-2013 06:13 AM
You can download cmterm-7940-7960-sccp.8-1-2SR2.exe from below link which is the latest available
regds,
aman
