04-18-2013 06:09 AM - edited 03-16-2019 04:52 PM
Hello to all ,
We have a CUCM 8.6.2.22900-9 , and a Cisco 7931 ( Secretary of head person ) and the next situation :
The secretary take a call at the first line ( A ) for the boss , and put the call in hold .
Next , the boss , for other floor , call to the second line ( B ) .
The secretary needs to transfer the call , but she refuses to terminate the call at line B , she needs to combine the audios , it is possible ?
I tried this with the JOIN button , but the test fails .
Can you help me with this problem ?
Thanks a lot !!
Hugo
Solved! Go to Solution.
04-18-2013 12:00 PM
Hi Hugo,
Can you please double check you have the Join Across Lines Policy service parameter set to True?
Tere.
If you find this post helpful, please rate!
04-18-2013 12:00 PM
Hi Hugo,
Tere.
04-18-2013 01:30 PM
testeven :
This is the solution , i tried and works !!
Thanks a lot !
