determine which CA cert using while connecting to anyconnect
gavin han
I've two cert installed on our ASA..ca1, ca2. my laptop has two certs intall as well, ca1, ca2.
I need to find our which cert (ca1 or ca2) my laptop is using while connecting to anyconnect. how do I determin that?
Rudy Sanjoko
Level 4
Level 4
one easy way is by deleting those certificates on your laptop, then  try to connect again. the other way is by checking on the asa using  asdm, in connections profiles section, you can check which certificate  that is being used by the ASA to identifies itself to the client.
hope this helps.
Disabling Automatic Certificate Selection But anyconnect is selecting Certificate automatically
Hi guys,
i  am having anyconnect version 3.1.03103, windows7 & 8 and asa 5520  (8.4). I have gone through alot of work to solve this issue but it not  hapening.
On clientless ssl vpn it prompts me for manual  certificate selection but on anyconnect client it is not. profile  configuration is mentioned below.
In the highlighted line below i have changed UserControllable="true" still no results.
-http://schemas.xmlsoap.org/encoding/ AnyConnectProfile.xsd" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns="http://schemas.xmlsoap.org/encoding/">-false
false
falseAllfalseNativetrue12falsetruefalsetrueIPv4,IPv6-true DisconnectOnSuspendtrueAutomaticSingleLocalLogonLocalUsersOnlyfalse-Disable false-false  204false
