Multiple outgoing CID with SIP trunk?
JOHN THIEN
We're using Broadvox (working great) for our SIP trunk on a UC540.
Would there be a way to have two separate outgoing caller ID's?  It looks like the UC540 only has a single spot to enter a caller ID.
paolo bevilacqua
You can configure on a per-extension basis, eg, some phones send a calling number, others another, etc.
Note I don't know if and how that can be done with CCA. It can surely be done with CLI.
With your encouragement, I found where it is done in CCA.  It is in one of the tabs in the outgoing dial plan.  You can select an extension and then provide a new outgoing CID.  Thank you!
Thank you for the nice rating and good luck!
