Bandwidth limit on VLANS using Cisco 3750 Layer 3 Switch
cuartoarcangel
Hi I have been trying to police bandwidth per VLAN on a 3750 Switch (ver 12.2 (44) SE5)
This is what i have:
- 40 Mbps Internet Service
- 10 VLANS
- I need each vlan to have assigned 4Mbps download and 1Mbps upload (that is, each workstation connected to a particular Vlan to download at 4Mbps and 1 Mbps upload).
So far i've only been able to control the upload using the following config (for testing purposes I'm limiting  only Vlan 7 as of now):
Gi 1/0/2 is connected to a Layer 2 Switch (2950) and every user woking in Vlan 7 in that switch (the 2950) is restricted to 1Mbps UPLOAD.
HOW can I restrict DOWNLOAD?, as of now if try to use the command:
LAYER_3(config-if)#service-policy output VLANs
It replies that the command is NOT supported.
LAYER_3#sh run
Building configuration...
Current configuration : 8989 bytes
! Last configuration change at 07:56:23 UTC Mon Mar 8 1993
version 12.2
service config
hostname LAYER_3
boot-start-marker
boot-end-marker
ip routing
mls qos
vlan internal allocation policy ascending
class-map match-all VLAN7
  match access-group 7
class-map match-all PORTS
  match input-interface  GigabitEthernet1/0/2
policy-map PORT
class PORTS
  police 1024000 192000 exceed-action drop
policy-map VLANS
class VLAN7
   set dscp ef
   service-policy PORT
interface GigabitEthernet1/0/1
switchport access vlan 192
switchport mode trunk
description LINK_SW_2_Floor
mls qos vlan-based
interface GigabitEthernet1/0/3
description INTERNET_LINK
no switchport
ip address 172.31.1.2 255.255.255.248
interface GigabitEthernet1/0/4
switchport access vlan 4
interface GigabitEthernet1/0/5
switchport access vlan 5
interface GigabitEthernet1/0/6
switchport access vlan 6
interface Vlan1
no ip address
shutdown
interface Vlan2
ip address 172.31.2.1 255.255.255.0
interface Vlan3
ip address 172.31.3.1 255.255.255.0
interface Vlan4
ip address 172.31.4.1 255.255.255.0
interface Vlan5
ip address 172.31.5.1 255.255.255.0
interface Vlan6
ip address 172.31.6.1 255.255.255.0
interface Vlan7
ip address 172.31.7.1 255.255.255.0
service-policy input VLANS
interface Vlan8
ip address 172.31.8.1 255.255.255.0
interface Vlan9
ip address 172.31.9.1 255.255.255.0
interface Vlan10
ip address 172.31.10.1 255.255.255.0
interface Vlan11
ip address 172.31.11.1 255.255.255.0
ip default-gateway 172.31.1.1
ip route 0.0.0.0 0.0.0.0 172.31.1.1
logging esm config
access-list 7 permit 172.31.7.0 0.0.0.255
Thanks in advance for your time reading this
16 Replies 16
paolo bevilacqua
You should use a router for that, not a switch.
Thanks Paolo,
By suggesting to use a router you mean i should re-design the VLAN Interfaces (move them to the router?)
or, use the actual Cisco 2821 router (i have on TOP of the L3 switch), to manage bandwidth for the VLAN interfaces created and managed in the Layer 3 sw? I don't have a clue, on how to do the latter.
Thanks and Regards,
Luis
tobyarnett
So a question to your design. Why would you want to potentailly allocate 40 Mbps combined usage across all of your VLAN's when your total bandwidth is 40 Mbps? You run the risk of maxing out your circuit and then you can lose your BGP peers because they cannot use the link to communicate with the neighbor. There is other data that needs to flow through there as well. Why not just create a single policy and apply it to the physical interface where all your VLAN's leave the switch from? The policy would give all VLAN's up to a designated bandwidth (i.e. 35 Mbps d/l, 5 Mbps u/l). Then you would reserve the other 5 Mbps for your other data traffic. Such as email, routing protocol messages, server FTP, server www, and other various data. Would this not serve the same goal?
As per the design you currently have I am looking up the specs on your code, but I don't think what you are trying to do is supported by that switch and IOS. You maybe able to do this with another IOS type, but as the previous post stated you may be at a hardware limitation as well. Moving those policy routes to your router would be the better option, or you could use a higher end switch. At this point, look at my first paragraph and see if that thought process may be beneficial to you. I will look for your code and see if your current design is supported.
-Toby
Please don't forget to rate any helpful post.
_____________________________________
There are no great limits to growth because there are no limits of human intelligence, imagination, and wonder.
- Ronald Reagan
-Toby
- Ronald Reagan
Thanks Toby,
Since we have 10 clients and each client has aproximetly 8-10 users, I wanted to deliver a dedicated bandwidth (i.e. 4Mbps) to each area/dept. so if a user starts utilizing more bandwidth it wouldnt affect other processes (vlans).
I found that utilizing hierarchycal policing i could have accomplish that, hence my code.
   "Why not just create a single policy and apply it to the physical interface where all your VLAN's leave the switch from?"
Is that possible? on a port configured for routing ( i.e. "no switchport) ???
Again, Thank you
Luis
Bilal Nawaz
Hello, you are already policing for download. Service policy input means anything coming in the interface (I.e. towards your vlan) is being policed. You cannot police on outbound.
The 3750 has limited qos features only for ingress.
Output means anything leaving the vlan that needs to be routed. This is the upload. This is egress, I.e. outbound.
I agree with Paolo, a router would be best to handle this kind of thing, I would configure shaping instead of policing too.
Hope this helps
Please rate useful posts & remember to mark any solved questions as answered. Thank you.
Thanks for the comment
Is output available in SHAPING for SVI's (VLan interfaces)???
Or will i face the same problem as policing? (only input traffic)?
Luis
Hello, Shaping is not available on the 3750 I think. I have only been able to configure policing on inbound direction just like you. The switch is very limited in that aspect. A router could do this for you.
Good document for qos on 3750 outlines what we could do, but there's nothing here that can truly work for you.
http://www.cisco.com/en/US/products/hw/switches/ps5023/products_tech_note09186a0080883f9e.shtml
Hope this helps
Hi All,
Thank you all for your support.
I ended up redesigning it using a "Router on a Stick" solution and applying rate-limit on the router's subinterfaces instead of the SVI's in the Layer 3 (which i ended up using it as Layer 2)
With the following configuration I've limit the bandwidth for Vlan 7 (4Mbps fo downloading and 1Mbps upload - end-user point-of-view)
- I created the Vlans in the switch
- DHCP service for Vlans were made in the router
- Sub-interfaces were created in the router (1 sub-interface as gateway per Vlan).
- Rate limit command applied in the sub-interface
This was my final configuration for the 3750 switch
MIND_L3_SW#
MIND_L3_SW#sh run
Current configuration : 4275 bytes
hostname MIND_L3_SW
no ip domain-lookup
spanning-tree mode pvst
description LINK_SW_1st_Floor
description LINK_SW_2nd_Floor
description I N T E R N E T _ L I N K
switchport access vlan 7
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
interface GigabitEthernet1/0/12
interface GigabitEthernet1/0/13
interface GigabitEthernet1/0/14
interface GigabitEthernet1/0/15
interface GigabitEthernet1/0/16
interface GigabitEthernet1/0/17
interface GigabitEthernet1/0/18
interface GigabitEthernet1/0/19
interface GigabitEthernet1/0/20
interface GigabitEthernet1/0/21
interface GigabitEthernet1/0/22
interface GigabitEthernet1/0/23
interface GigabitEthernet1/0/24
interface GigabitEthernet1/0/25
interface GigabitEthernet1/0/26
switchport access vlan 8
interface GigabitEthernet1/0/27
interface GigabitEthernet1/0/28
interface GigabitEthernet1/0/29
interface GigabitEthernet1/0/30
switchport access vlan 10
interface GigabitEthernet1/0/31
interface GigabitEthernet1/0/32
interface GigabitEthernet1/0/33
interface GigabitEthernet1/0/34
interface GigabitEthernet1/0/35
interface GigabitEthernet1/0/36
interface GigabitEthernet1/0/37
interface GigabitEthernet1/0/38
interface GigabitEthernet1/0/39
interface GigabitEthernet1/0/40
interface GigabitEthernet1/0/41
interface GigabitEthernet1/0/42
interface GigabitEthernet1/0/43
interface GigabitEthernet1/0/44
interface GigabitEthernet1/0/45
interface GigabitEthernet1/0/46
interface GigabitEthernet1/0/47
switchport access vlan 20
interface GigabitEthernet1/0/48
interface GigabitEthernet1/0/49
interface GigabitEthernet1/0/50
interface GigabitEthernet1/0/51
interface GigabitEthernet1/0/52
interface Vlan1
no ip address
no ip route-cache cef
no ip route-cache
shutdown
interface Vlan10
no ip route-cache
ip default-gateway 172.31.10.254
logging esm config
end
MIND_L3_SW#
This was my 2821 router final configuration:
ARKUS2821#
ARKUS2821#
ARKUS2821#
ARKUS2821#
ARKUS2821#
ARKUS2821#sh run
Current configuration : 11821 bytes
version 12.4
hostname ARKUS2821
boot-start-marker
boot system flash c2800nm-adventerprisek9-mz.124-22.T5.bin
boot-end-marker
logging message-counter syslog
logging buffered 51200 warnings
no aaa new-model
ip cef
ip dhcp excluded-address 172.31.2.1
ip dhcp excluded-address 172.31.3.1
ip dhcp excluded-address 172.31.4.1
ip dhcp excluded-address 172.31.5.1
ip dhcp excluded-address 172.31.6.1
ip dhcp excluded-address 172.31.7.1
ip dhcp excluded-address 172.31.8.1
ip dhcp excluded-address 172.31.9.1
ip dhcp excluded-address 172.31.11.1
ip dhcp excluded-address 172.31.12.1
ip dhcp excluded-address 172.31.13.1
ip dhcp excluded-address 172.31.14.1
ip dhcp excluded-address 172.31.15.1
ip dhcp excluded-address 172.31.16.1
ip dhcp excluded-address 172.31.17.1
ip dhcp excluded-address 172.31.18.1
ip dhcp excluded-address 172.31.19.1
ip dhcp excluded-address 172.31.20.1
ip dhcp excluded-address 192.168.1.1
ip dhcp pool VLAN21
   network 172.31.21.0 255.255.255.0
   dns-server 200.38.100.210 207.83.200.201
   default-router 172.31.21.1
ip dhcp pool VLAN2
   network 172.31.2.0 255.255.255.0
   default-router 172.31.2.1
ip dhcp pool VLAN3
   network 172.31.3.0 255.255.255.0
   default-router 172.31.3.1
ip dhcp pool VLAN4
   network 172.31.4.0 255.255.255.0
   default-router 172.31.4.1
ip dhcp pool VLAN5
   network 172.31.5.0 255.255.255.0
   default-router 172.31.5.1
ip dhcp pool VLAN6
   network 172.31.6.0 255.255.255.0
   default-router 172.31.6.1
ip dhcp pool VLAN7
   network 172.31.7.0 255.255.255.0
   default-router 172.31.7.1
ip dhcp pool VLAN8
   network 172.31.8.0 255.255.255.0
   default-router 172.31.8.1
ip dhcp pool VLAN9
   network 172.31.9.0 255.255.255.0
   default-router 172.31.9.1
ip dhcp pool VLAN11
   network 172.31.11.0 255.255.255.0
   default-router 172.31.11.1
ip dhcp pool VLAN12
   network 172.31.12.0 255.255.255.0
   default-router 172.31.12.1
ip dhcp pool VLAN13
   network 172.31.13.0 255.255.255.0
   default-router 172.31.13.1
ip dhcp pool VLAN14
   network 172.31.14.0 255.255.255.0
   default-router 172.31.14.1
ip dhcp pool VLAN15
   network 172.31.15.0 255.255.255.0
   default-router 172.31.15.1
ip dhcp pool VLAN16
   network 172.31.16.0 255.255.255.0
   default-router 172.31.16.1
ip dhcp pool VLAN17
   network 172.31.17.0 255.255.255.0
   default-router 172.31.17.1
ip dhcp pool VLAN18
   network 172.31.18.0 255.255.255.0
   default-router 172.31.18.1
ip dhcp pool VLAN19
   network 172.31.19.0 255.255.255.0
   default-router 172.31.19.1
ip dhcp pool VLAN20
   network 172.31.20.0 255.255.255.0
   default-router 172.31.20.1
ip dhcp pool VLAN192
   network 192.168.1.0 255.255.255.0
   default-router 192.168.1.1
no ip domain lookup
interface GigabitEthernet0/0
description LOCAL_AREA_NETWORK
no ip address
ip virtual-reassembly
duplex auto
speed auto
interface GigabitEthernet0/0.2
encapsulation dot1Q 2
ip nat inside
interface GigabitEthernet0/0.3
encapsulation dot1Q 3
ip nat inside
interface GigabitEthernet0/0.4
encapsulation dot1Q 4
ip nat inside
interface GigabitEthernet0/0.5
encapsulation dot1Q 5
ip nat inside
interface GigabitEthernet0/0.6
encapsulation dot1Q 6
ip nat inside
interface GigabitEthernet0/0.7
encapsulation dot1Q 7
ip nat inside
rate-limit output 4096000 768000 1536000 conform-action transmit exceed-action drop
rate-limit input 1024000 192000 384000 conform-action transmit exceed-action drop
interface GigabitEthernet0/0.8
encapsulation dot1Q 8
ip nat inside
interface GigabitEthernet0/0.9
encapsulation dot1Q 9
ip nat inside
interface GigabitEthernet0/0.10
encapsulation dot1Q 10
ip address 172.31.10.254 255.255.255.0
ip nat inside
interface GigabitEthernet0/0.11
encapsulation dot1Q 11
ip nat inside
interface GigabitEthernet0/0.12
encapsulation dot1Q 12
ip address 172.31.12.1 255.255.255.0
ip nat inside
interface GigabitEthernet0/0.13
encapsulation dot1Q 13
ip address 172.31.13.1 255.255.255.0
ip nat inside
interface GigabitEthernet0/0.14
encapsulation dot1Q 14
ip address 172.31.14.1 255.255.255.0
ip nat inside
interface GigabitEthernet0/0.15
encapsulation dot1Q 15
ip address 172.31.15.1 255.255.255.0
ip nat inside
interface GigabitEthernet0/0.16
encapsulation dot1Q 16
ip address 172.31.16.1 255.255.255.0
ip nat inside
interface GigabitEthernet0/0.17
encapsulation dot1Q 17
ip address 172.31.17.1 255.255.255.0
ip nat inside
interface GigabitEthernet0/0.18
encapsulation dot1Q 18
ip address 172.31.18.1 255.255.255.0
ip nat inside
interface GigabitEthernet0/0.19
encapsulation dot1Q 19
ip address 172.31.19.1 255.255.255.0
ip nat inside
interface GigabitEthernet0/0.20
encapsulation dot1Q 20
ip address 172.31.20.1 255.255.255.0
ip nat inside
interface GigabitEthernet0/0.21
encapsulation dot1Q 21
ip address 172.31.21.1 255.255.255.0
ip nat inside
interface GigabitEthernet0/0.192
encapsulation dot1Q 192
ip nat inside
interface FastEthernet0/3/0
description INTERNET_ISP
ip address dhcp
ip access-group 111 in
ip flow ingress
ip nat outside
duplex auto
speed auto
ip forward-protocol nd
ip route 172.31.2.0 255.255.255.0 GigabitEthernet0/0
ip route 172.31.3.0 255.255.255.0 GigabitEthernet0/0
ip route 172.31.4.0 255.255.255.0 GigabitEthernet0/0
ip route 172.31.5.0 255.255.255.0 GigabitEthernet0/0
ip route 172.31.6.0 255.255.255.0 GigabitEthernet0/0
ip route 172.31.7.0 255.255.255.0 GigabitEthernet0/0
ip route 172.31.8.0 255.255.255.0 GigabitEthernet0/0
ip route 172.31.9.0 255.255.255.0 GigabitEthernet0/0
ip route 172.31.10.0 255.255.255.0 GigabitEthernet0/0
ip route 172.31.11.0 255.255.255.0 GigabitEthernet0/0
ip route 172.31.12.0 255.255.255.0 GigabitEthernet0/0
ip route 172.31.13.0 255.255.255.0 GigabitEthernet0/0
ip route 172.31.14.0 255.255.255.0 GigabitEthernet0/0
ip route 172.31.15.0 255.255.255.0 GigabitEthernet0/0
ip route 172.31.16.0 255.255.255.0 GigabitEthernet0/0
ip route 172.31.17.0 255.255.255.0 GigabitEthernet0/0
ip route 172.31.18.0 255.255.255.0 GigabitEthernet0/0
ip route 172.31.19.0 255.255.255.0 GigabitEthernet0/0
ip route 172.31.20.0 255.255.255.0 GigabitEthernet0/0
ip route 172.31.21.0 255.255.255.0 GigabitEthernet0/0
ip route 0.0.0.0 0.0.0.0 dhcp
no ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip flow-cache timeout active 1
ip flow-export source FastEthernet0/3/0
ip flow-export version 5
ip nat inside source list 1 interface FastEthernet0/3/0 overload
access-list 1 permit 172.31.1.0 0.0.0.255
access-list 1 permit 172.31.2.0 0.0.0.255
access-list 1 permit 172.31.3.0 0.0.0.255
access-list 1 permit 172.31.4.0 0.0.0.255
access-list 1 permit 172.31.5.0 0.0.0.255
access-list 1 permit 172.31.6.0 0.0.0.255
access-list 1 permit 172.31.7.0 0.0.0.255
access-list 1 permit 172.31.8.0 0.0.0.255
access-list 1 permit 172.31.9.0 0.0.0.255
access-list 1 permit 172.31.10.0 0.0.0.255
access-list 1 permit 172.31.11.0 0.0.0.255
access-list 1 permit 172.31.12.0 0.0.0.255
access-list 1 permit 172.31.13.0 0.0.0.255
access-list 1 permit 172.31.14.0 0.0.0.255
access-list 1 permit 172.31.15.0 0.0.0.255
access-list 1 permit 172.31.16.0 0.0.0.255
access-list 1 permit 172.31.17.0 0.0.0.255
access-list 1 permit 172.31.18.0 0.0.0.255
access-list 1 permit 172.31.19.0 0.0.0.255
access-list 1 permit 172.31.20.0 0.0.0.255
access-list 1 permit 172.31.21.0 0.0.0.255
access-list 1 permit 192.168.1.0 0.0.0.255
end
ARKUS2821#
Hi Luis
I think your solution has a negative point! Because with using rate-limit command, your traffic from VLAN 7 to other VLANs is also limited to 4Mbps download and 1Mbps upload!
-Amir
Hi Amir,
I think you are completely right.
Nonetheless i haven't been able to figure out any other possible config to accomplish this:
Bandwidth Shaping/policing per Vlan for external traffic without affecting inter-Vlan speeds.
any suggestion is greatly appreciated.
regards,
Luis
Bonjour @cuartoarcangel , je trouve ta préoccupation très intéressante.
Puis-je avoir un aperçu de ton schéma de principe?
Cordialement
Aldène
Bonjour @Aldene Pinet KOUMBA
Étant donné que cela fait environ neuf ans depuis la dernière réponse de @cuartoarcangel, il est possible que vous n'obteniez pas de réponse.
Donc, je me demande simplement ce que vous trouvez intéressant et s'il y a une question sur laquelle je pourrais vous aider.
Bonjour @Joseph W. Doherty .
Merci la pour la mise à jour  de l’information.
En fait j’ai un souci à propos d’un projet.
Je souhaite transporter un client qui utilise une application web dans mon réseau.
Le but est de savoir comment séparer le client de mon réseau, tout en le transportant sur des milliers de kilomètres ?
Comment quantité le débit à allouer au client ?
Quelles sont les équipements réseaux à définir avant toutes installations ?
Merci.
Aldène,
Votre préoccupation et le type de projet sont partagés par beaucoup. Bien qu'il s'agisse d'une question simple, trouver la "bonne" réponse n'est souvent pas si simple.
Je vous suggère fortement de publier ceci en tant que nouveau sujet, afin d'obtenir la réponse la plus large possible.
Je noterai que la dérivation d'une réponse dépend beaucoup de ce qui est défini comme "performance acceptable". Malheureusement, les "performances acceptables" commencent souvent par une ligne de base d'un client Web accédant à un serveur Web dans la "pièce voisine". Il est souvent très, très difficile, voire impossible, d'obtenir des performances similaires lorsque le client Web et le serveur Web sont séparés par des milliers de kilomètres, quel que soit l'équipement réseau et/ou la bande passante allouée par flux. (Il existe cependant des approches d'atténuation.)
Il y a des années, j'ai travaillé dans une entreprise internationale, avec des bureaux, littéralement, partout dans le monde. Une plainte courante était que les utilisateurs du réseau accédant aux serveurs (encore une fois littéralement) à l'autre bout du monde étaient "lents". Fondamentalement, une grande partie des performances « lentes » est due à la latence basée sur la distance.
(Wiki)
Grace Hopper est célèbre pour son aide visuelle en nanosecondes. Les gens (tels que les généraux et les amiraux) lui demandaient pourquoi la communication par satellite prenait si longtemps. Elle a commencé à distribuer des morceaux de fil d'un peu moins d'un pied de long - 11,8 pouces (30 cm) - la distance parcourue par la lumière en une nanoseconde. Elle a donné à ces morceaux de fil la métonymie "nanosecondes." [31] Elle a pris soin de dire à son auditoire que la longueur de ses nanosecondes était en fait la distance maximale que les signaux parcourraient dans le vide, et que les signaux se déplaceraient plus lentement à travers le fils réels qui étaient ses aides pédagogiques. Plus tard, elle a utilisé les mêmes morceaux de fil pour illustrer pourquoi les ordinateurs devaient être petits pour être rapides. Lors de plusieurs de ses conférences et visites, elle a distribué des « nanosecondes » à tout le monde dans le public, les opposant à une bobine de fil de 984 pieds (300 mètres) de long, [43] représentant une microseconde. Plus tard, alors qu'elle donnait ces conférences alors qu'elle travaillait pour DEC, elle a distribué des paquets de poivre, appelant les grains individuels de poivre moulu des picosecondes.[44]
Une partie de la présentation de l'amiral Hopper consistait à empiler visuellement ces segments de fil pour atteindre un satellite à 35 800 km au-dessus de la terre et permettre une communication bidirectionnelle. Les réseaux terrestres n'ont pas des sauts aussi énormes, mais ils ne sont pas non plus sur la ligne la plus courte, et plusieurs sauts ajoutent également du retard.
