Warning message
SPA502G LDAP setup problems
Apr 30th, 2013
Wondering if anyone can help me.
I am trying to get the LDAP Corporate Directory working on our SPA502G phones but am having a problem.
As soon as I hit submit to search it says "LDAP Error: cannot connect to server"
Now I have tried everything under the sun for this.  I have rolled back the firmware to 7.5.2b
Attached is the SIP setup Config Utility.
I jsut want someone to check it out and see if I havent done anything silly.
We use AD on Windows Server 2008 R2.
Have tried turning the firewall off and also virus protection on the server.
Thanks in advance!
nseto Wed, 05/01/2013 - 09:56
  • Silver, 250 points or more
It doesn't look much different from my working setup.
Only thing I notice is that LDAP Corp Dir Name is using two words while mine is using one.  Can you try your LDAP name using one word?  Maybe there's an issue with using two names due to the space between the words.
Related Content
