Warning message
Integration of SPA500DS with SPA509 in conjunction with a UC560
May 6th, 2013
Need to use a SPA500DS with SPA509. are working with a UC560.
what are the commands that I put in the UC560 to monitor an extension in SPA500DS buttons?
Ian Brennan Mon, 05/06/2013 - 20:25
Basically you can't if you are using CCA as the SPA phones only support SPCP with the UC500 series.  If you were to use the SIP firmware you could make it work, but it would be CLI only.
Cisco doesn't make this clear at all on the data sheet, confusing many customers including me.
Related Content
