Nexus monitor session problem
aducey01
Why is it saying not hardware resource?  What am I doing wrong?
   session 2
description       : ****OpnetSPAN****
type              : local
state             : down (No hardware resource)
source intf       :
    rx            : Po1000
    tx            :
    both          :
source VLANs      :
    rx            :
    tx            :
    both          :
filter VLANs      : filter not specified
destination ports : Eth3/30
Steve Fuller
Level 9
Level 9
How many SPAN sessions do you have configured across all VDC on the switch? You can only have two active sessions per system and so may need to shutdown other monitor sessions to make hardware resource available.
nlduarteh
To do that, you need to configure "mode extended" under every new session beyond the second, here is an example:
N7K-1(config)# monitor session 3
N7K-1(config-monitor)# mode extended
Configuration for Extended Session: SPAN Configuration
Nexus(config)# interface <enter interface where you want span (dest)>
Nexus(config-if)# switchport
Nexus(config-if)# switchport mode trunk
Nexus(config-if)# switchport monitor
Nexus(config-if)# monitor session 3
Nexus(config-monitor)# mode extended
Nexus(config-monitor)# source interface <enter (source) interfaces>
Nexus(config-monitor)# destination interface <enter (dest) interface>
Nexus(config-monitor)# no shut
Nexus(config-monitor)# sh monitor
Session                       State                   Reason                 Description
1                                   up                   The session is up
2                                   up                   The session is up
3                                   up                   The session is up
Nexus(config-monitor)# sh monitor session all
