05-12-2013 08:37 PM - edited 03-11-2019 06:42 PM
hi all,
just wanna ask if i could swap around the bootvar on my 5505 without affecting the activation key.
this is to learn different NAT on pre and 8.3+ IOS. TIA!
# sh bootvar
BOOT variable = disk0:/asa825-26-k8.bin
Current BOOT variable = disk0:/asa825-26-k8.bin
CONFIG_FILE variable =
Current CONFIG_FILE variable =
# sh run boot
boot system disk0:/asa825-26-k8.bin
Directory of disk0:/
125 -rwx 14812604 07:52:37 Mar 04 2013 asdm-635.bin
103 -rwx 1868412 09:45:54 Nov 13 2007 securedesktop-asa-3.1.1.29-k9.pkg
104 -rwx 398305 09:46:08 Nov 13 2007 sslclient-win-1.1.0.154.pkg
12 drwx 4096 09:47:52 Nov 13 2007 crypto_archive
135 -rwx 4675549 02:59:56 Mar 06 2013 anyconnect-win-2.5.2010-k9.pkg
3 drwx 4096 17:53:54 May 19 2008 log
151 -rwx 2010 14:15:31 Mar 14 2013 wbgsslvpn.xml
110 -rwx 11491880 15:25:30 Nov 01 2010 asdm-623.bin
111 -rwx 16459776 15:41:06 Nov 01 2010 asa822-k8.bin
112 -rwx 3203909 15:56:46 Nov 01 2010 anyconnect-win-2.4.1012-k9.pkg
13 drwx 4096 13:56:30 Nov 03 2010 coredumpinfo
113 -rwx 15409152 00:52:34 Jul 09 2012 asa825-26-k8.bin
114 -rwx 15390720 00:56:14 Jul 09 2012 asa845-k8.bin
119 -rwx 30720326 01:59:49 Feb 26 2013 anyconnect-win-3.1.02040-k9.pkg
Solved! Go to Solution.
05-13-2013 06:54 AM
Yes, the usual ploy would be to set up the new image as first in the boot order, with the older image as a fallback. However, the fact that the NAT configuration completely changed at 8.3 matters; also, 8.4 would need more memory than 8.2. E.g.
configure terminal
boot system disk0:/asa845-k8.bin
no boot system disk0:/asa825-26-k8.bin
end
should give you a configuration where "show run boot" yields:
-- Jim Leinweber, WI State Lab of Hygiene
05-13-2013 06:54 AM
configure terminal
end
05-13-2013 08:26 AM
As James mentioned, 8.3 or later will need more memory and also there is significant difference in the way ASA handles NAT and acl. In case you've not checked the related info already, this link can help:
https://supportforums.cisco.com/docs/DOC-12690
Sourav
05-13-2013 04:13 PM
Thanks for your inputs! I've got 512 MB RAM so I believe this won't be any issue.
