Guest Vlan - Assignment Error 3560
ricardorojas123
I am configuring 802.1X in a 3560 Switch, my Radius server is a Microsoft IAS, when I connect a station of a guest user, the guest-vlan is not assigned in the port, and I have these logs:
May  8 21:23:02: dot1x-ev:Received an EAP Timeout on FastEthernet0/8 for mac 0000.0000.0000
May  8 21:23:02: dot1x-ev:dot1x_guest_vlan_applicable: Guest VLAN not applicable.  Supplicant disabled and EAPOL seen on port FastEthernet0/8.
May  8 21:23:02: dot1x-ev:Resetting the client 0000.0000.0000
May  8 21:23:03: dot1x-ev:Resetting the client 0000.0000.0000
May  8 21:23:04: dot1x-ev:FastEthernet0/8:Sending EAPOL packet to group PAE address
May  8 21:23:04: dot1x-ev:dot1x_mgr_pre_process_eapol_pak: Role determination not required on FastEthernet0/8.
May  8 21:23:04: dot1x-ev:dot1x_mgr_send_eapol: Sending out EAPOL packet on FastEthernet0/8
The configuration of Switch:
vlan 7
name data
vlan 31
name guest
aaa new-model
aaa authentication dot1x default group radius
aaa authorization network default group radius
aaa session-id common
dot1x system-auth-control
radius-server host <ip>  auth-port 1645 acct-port 1646 key <key>
radius-server source-ports 1645-1646
interface FastEthernet0/8
switchport access vlan 7
switchport mode access
dot1x pae authenticator
dot1x port-control auto
dot1x timeout quiet-period 5
dot1x timeout tx-period 5
dot1x timeout supp-timeout 5
dot1x max-req 1
dot1x max-reauth-req 1
dot1x guest-vlan 31
dot1x auth-fail vlan 200
dot1x auth-fail max-attempts 1
dot1x critical vlan 200
spanning-tree portfast
Additional Information: IOS: c3560-ipbase-mz.122-25.SEE3, Model: WS-C3560-48PS-S
I hope you can help me with the problem and I appreciate your help!
Note: the authentication of the corporative stations is succesfull:
7 Replies 7
ricardorojas123
Hi, friends any suggestions?
When you configure a guest VLAN, clients that are  not 802.1x-capable are put into the guest VLAN when the server does not  receive a response to its EAP request/identity frame. Clients that  are 802.1x-capable but that fail authentication are not granted network  access. The switch supports guest VLANs in single-host or multiple-hosts  mode.
Few questions:
1.] What dot1x mode have you configured on interface fa0/8. I don't see any.
2.] What kind of end-client we have connected on this port? Is that dot1x capable?
With Cisco IOS Release 12.1(22)EA2 and later, the  switch maintains the EAPOL packet history. If an EAPOL packet is  detected on the interface during the lifetime of the link, the switch  determines that the device connected to that interface is an  802.1x-capable supplicant, and the interface does not change to the  guest VLAN state.
Jatin Katyal
- Do rate helpful posts -
~Jatin
You can enable optional guest VLAN behavior by using the dot1x guest-vlan supplicant global configuration command. When enabled, the switch does not  maintain the EAPOL packet history and allows clients that fail  authentication access to the guest VLAN, regardless of whether EAPOL  packets had been detected on the interface.
Jatin Katyal
~Jatin
Hi Jatin,
My answers to your questions:
dot1x host-mode multi-host
The end-client is a Windows 7 not 802.1x-capable.
I wanted to know the dot1x mode because Guest VLANs are   supported on 802.1x ports in single-host or multiple-hosts mode. Could   you please delete the configuration from the port and configure it only   for below listed config
dot1x guest-vlan 31
dot1x host mode could be single or multi host.
shutdown the port and unshutdown it again.
capture the debugs and command output.
show dot1x interface details
Jatin Katyal
Jatin Katyal
~Jatin
Hi Jatin,
I have uploaded the IOS to c3560-ipbase-mz.122-35.SE5, and now the guest vlan is working.
Thank you very much for your help
Now I will start to work with Cisco 2960 LAN Lite.
Thanks for keep the thread updated.
Jatin Katyal
~Jatin
