05-22-2013 01:28 PM - edited 03-14-2019 11:46 AM
I started a new position and am learning CUIC now. I heard the server our CUIC is on is unable to send emails for whatever reason,
When I create da schedule to push a test report, I was given a failure icon but no reason. Does anyone have insight on this problem or work arounds? I really appreciate any help.
05-22-2013 02:43 PM
Did you check the email connection, click on test conneciton and check if the configuration is correct, you can start from there.
You have to login into the oamp link in order to configre/check the email configuration.
Amer
05-23-2013 09:09 AM
Amer, thank you for the reply! I went to oamp and learned that the linux server our cisco cuic is on doe snot have SMTP setup, which explains the error. Am I able to work around this by having the scheduler push from another smtp? This is not really my area of knowledge. I have read all the related Cisco documentation without any solution. THanks agian.
