05-25-2013 02:48 PM - edited 03-01-2019 02:40 PM
Hello
I want to use qinq tunnelling in my network. I have 2 cisco 3750 on the edge terminating the qinq tunnels, but in between i have cisco 2960.
My question is does cisco 2960 pass qinq traffic
Thank u
05-26-2013 05:29 AM
Sure, as long as you configure the proper MTU to cope with the extra tag, 1504 would probably suffice.
05-26-2013 07:16 AM
Hi there
I tried to configure the system mtu to 1998 and the routing mtu to 1998, but still it wouldnt come up.
05-26-2013 07:19 AM
You wont be needing the routing MTU just to pass QinQ frames. Try the mtu system jumbo command: http://www.cisco.com/en/US/products/hw/switches/ps700/products_configuration_example09186a008010edab.shtml#c4a
05-26-2013 07:25 AM
I also treid that. It ddnt work. The funny thing is if you substitute the cisco switch for a huawei switch with default configs it works.
Whats on huawei switch thats not on cisco switch.
05-26-2013 07:28 AM
Can you pastebin the configurations? Maybe there's something else other than MTU that's in the way. Generally this should work.
05-26-2013 08:05 AM
the setup is like this SW1<>SW2<>SW3. SW1 and SW3 are the ones terminating the QinQ tunnels. SW2 is just forwardingn the QinQ vlan
configs for SW1 - Huawei CX 300A
interface Ethernet2/0/4
description XXX
port link-type dot1q-tunnel
port default vlan 106
trust 8021p
qos queue be cir 80 pir 90
qos queue af1 cir 80 pir 90
qos queue af2 cir 80 pir 90
qos queue af3 cir 80 pir 90
qos queue af4 cir 80 pir 90
qos queue ef cir 90 pir 100
qos queue cs6 cir 80 pir 90
qos queue cs7 cir 80 pir 90
interface Ethernet2/0/5
description to-cisco-2960
port link-type trunk
port trunk allow-pass vlan 106
trust 8021p
SW2 configs - cisco 2960
SSC_2960#sh system mtu
System MTU size is 1998 bytes
System Jumbo MTU size is 9000 bytes
Routing MTU size is 1998 bytes
interface FastEthernet0/4
description QinQ_Vlan_to_huawei-CX-300A-Ethernet2/0/5
switchport trunk allowed vlan 106
switchport mode trunk
interface FastEthernet0/6
description QinQ_Vlan_to_huawei-CX-300A-Ethernet3/0/7
SW3 configs - Huawei CX300A
interface Ethernet1/0/10
description XXX
trust 8021p
interface Ethernet3/0/7
trust 8021p
05-26-2013 08:11 AM
Looks fairly straight forward. What exactly isnt working? Do you see mac addresses in the 2960 and in the remote Huawei?
05-26-2013 08:22 AM
Yes i can see macs on all devices. What is not working is that if i connect 2 laptops on my qinq ports on the huawei switches i cant ping end to end. If i sustitute the cisco switch with a huawei cx300A it works.
05-31-2013 02:19 AM
can you span fa0/4 and fa0/6 on the cat2960 (making sure you capture vlan tags) while you ping end to end from your laptops? so we can sure that the double tag imposed by huaweii switch is compliant with specs.
Riccardo
